My Fop-38 surface is not all that smooth and I use artic silver so I thought I would lap it.
Few Questions.
The FOP-38 in annodized, lapping will remove this, is this a problem, what is the purpose of the annodize?
Will I need to start off with a coarse paper, will the bottom of the HS be concave/convex, then work up to a finer grit?
Any tips?
When I took the fan of the fop 38 (changed it for the ys-tech 60mm like on the fop-32) the clip came out and I can't remeber which way round it goes back, will it matter?
Does the end with the movable clip go at the end with the notch in the bottom of the HS or the other end?
PS. Why do the letters written on the chip indent themself in the bottom of the heatsink? Is tis normal, I can read the writing on the bottom of the HS. Are they raised up?
Many thanks.
Few Questions.
Any tips?
Many thanks.
