pocketExistentialist
Right here I've got a 3 1/2 year old 19" Visual Sensations CRT, and it still works great. Best deal I've ever partaken in, $300 back in mid-1999.
Originally posted by: CurtCold
ViewSonic all the way baby!
I was wondering why Evil-Mart, had the 17" KDS monitors for $120.
Originally posted by: Whitedog
I agree KDS are low quality monitors... we were buying them for our company a few years ago and did get many many bad ones... right out of the box.
I've had a VS-21 for four years now and it still looks great... though about two years ago it begin to appear very DARK when I first turned it on. It takes about 20 minutes for it to warm up to full brightness (still like this, but I can live with it)
MAG on the other hand is/was the Worst monitors on the planet! :|
hehe
The only saving grace to this is that I reside in So. Cal; close enough to Will Call RMA the monitor for replacement. Their customer service for RMA are more than happy to help, though. When I initially asked for Will Call RMA, they were more than helpful in doing so. Too bad the ONLY day to do Will Call RMA is on Fridays from 9 am-12 pm.
Originally posted by: WannaZO6
Originally posted by: Dreadogg
I have KDS 19 inch that has had zero problems for me. Lets see what others have to say about this.
Same here. I've had my VS-190i for about a year and a half without problems.
Originally posted by: Mrburns2007
Just thought I'd mention that 17 and 19 CRT monitors can generate a lot heat which can get trapped inside the monitor. Overtime the solider will melt and run and cause a short. They make quiet cooling fans that can reduce the inside temps by as much as 30 degrees.
I highly recommend adding a cooling fan to your CRT....it will last a lot longer if you do.
In my 20 years of being in the monitor business, I have never, not once ever seen or heard of solder melting and causing a short. I have seen poor soldering where solder balls are left on the PCB and cause a short, but melting never!
What you all do not realized is unlike many electronic devices, Monitor assembly and alignment is mostly a manual process. Since humans do most of the aligning, variation is inevitable. For example: The training of the operator adjusting convergence varies person to person. For the most part when you purchase a monitor or any other electronic device, what you are really buying is the company that sold it to you. Most of the big brand names don?t even do the physical manufacturing anymore.
For example: KDS no longer manufactures their own CRT monitors, they are now made by Sampo. Not that this is a bad thing, KDS closed their own monitor lines under a reorganization about a year or two ago. This is when they dropped the line that used the Sony Trinitron CRT?s, because Sampo started doing the manufacturing for them.
