Originally posted by: Baked
LOL, noob.
What are the benefits to having Digital Keys installed on my computer?:
1. Each time you place the CD in your computer, your music will automatically begin to play.
2. You can easily move your music onto your computer without the cumbersome process of ripping.
3. You can place your music onto your approved portable digital music player.
Originally posted by: timswim78
I'm not sure if you tried them or not, but here are links to the software that others mentioned:
EAC: http://www.exactaudiocopy.de/
CDEX: http://cdexos.sourceforge.net/
The problem, atleast with the foo fighters CD, is that the invisible driver they install (visible in device manager when active, and easier to find when viewing devices by connection) is it disrupts your ROM's ability to read that particular CD, so even using paranoid modes with CDex and EAC won't work...it'll just take longer to get clipping/scratching sounding songs.
Originally posted by: BooGiMaN
so if you dont have an internet connection or dont want it callign home can you return the cd and get you money back?
Originally posted by: Mojoed
OP, did you try my suggestion? ^
i just checked my driver and its from 7/1/2001
im guessing i should be alright then... right?
Originally posted by: Bootprint
It appears that that album uses a SunnComm protection scheme.
Maybe check this page, 1/3 the way down the page for some instructions on a work around.
Yep, that was the exact protection scheme foo fighters had and that was the page i used to find out how to get around it.
yes, using shift worked and i was able to search through the CD but not get the songs off, ill try something different
(i already saved them to my computer using there horrible little GUI they have for getting the keys and what not so its not a really big deal)
just did it and i can rip the music using WMP
SCORE!
SCORE!
Score one for the good guys! :beer:
Originally posted by: Shawn
Just disable WinXP's autorun completely. I haven't had a problem ripping cds since.
Originally posted by: JLGatsby
Wait, people still use CDs? Buy the digital file and put it on your ipod.
and when your IP hard drive goes out?...
