AtenRa
- Feb 2, 2009
- 14,003
- 3,362
- 136
Your review used an overclocked 4100@4.08Ghz![]()
I have used the FX4100 both at default and OC in my review.
But dont blame me, blame Intel for not letting us OC the i3
But dont blame me, blame Intel for not letting us OC the i3![]()
Forget the i3 even the Pentium G630 pwns all of AMD's line up. The G630 beat the FX-4100, -6100, and -8120 at stock clocks. Im running on a Pentium G850 that Pwns my old phenom X4. Those sandy bridge cores are sweet. At this point no reason to even buy AMD even at the lowest end. The only way I would by an AMD set up would be like what Micro center is doing with the 4100 and that is $99 dollars and a free 970 motherboard now that would be the only situation where it would be worth it.
So lets see some proof that your little Pentium defeats an 6100 or 8120 in a game that matters (such as BF3, which will use up to 6 threads). That little pentium will sit there at nearly 100% CPU utilization delivering sub-par performance. Where as an 8120 will sit down at around 30-40% CPU and cruise along with no issues (unless you are running a hefty multi-GPU setup).
Much less compare them in real work situations like video editing. Sure a 2500K or 2600K will pull ahead. But a dual core with no hyper threading? Give me a break.
Please tell me you're kidding...almost all your benchmarks are GPU limited so of course the performance is almost identical for everything.Are you sure ?? check the link in my sig bellow![]()
This alone makes the FX able to compete. The FX loses at stock, but overclocked (with a lot more power draw and heat/noise) it can match or even slightly beat an i3 at a given pricepoint.
I'm really looking forward to the 55w and 35w TDPs of the next-gen i3's, that's nearing the point where you could passively cool it.
http://www.tomshardware.com/reviews/gaming-cpu-review-overclock,3106-3.htmlAt its stock clock rate, AMD's FX-4100 isn't a particularly compelling gaming product compared to lower-priced options from Intel. However, enthusiasts are sure to appreciate its unlocked ratio multiplier and plenty of headroom to overclock. When it's pushed, this processor helps enable similar frame rates as some of our favorite CORE CPUs, though it uses significantly more power in the process. Nevertheless, with Phenom IIs quickly disappearing from retail, the FX-4100 remains AMD's best value in the gaming CPU space, earning an honorable mention.
The problem is that the extra money you'd have to spend on a PSU to power an overclocked FX kills this solution entirely since you'd be able to simply buy a better intel CPU than an i3 if you're gonna put the money into a high power PSU to feed an FX overclock.
Its not just the oc, how much did the 1600mhz ram you used for the 4100 (vs 1333 for i3) affect your benchmarks?
On another note even if a 4100 is ok for a budget gaming build, I wouldn't recommend the same for a more mainstream 6100/8120 gaming build because the clockspeeds are lower compared the 4100 and games in general don't take advantage of more cores as much as faster cores.
It turns out that the budget-oriented Sandy Bridge-based Pentium family performs very well in games. Specifically, Intel's $80 Pentium G630 beat the FX-4100, -6100, and -8120 in our recent sub-$200 CPU gaming comparison. In fact, it finished right on par with the Phenom II X4 955.
As a result, Intel displaces AMD at the bottom rung of our recommendation list yet again this month. That's something we haven't seen for a very long while. There's not much else to add, except that if you consider the Phenom II to be a capable gaming CPU, Intel's Pentium G630 is just as viable.
All FX CPUs will OC to 4-4.2GHz with default voltage and heat-sink. You dont need to spend more for a PSU to OC any FX CPU. Reread my review and youll see that I have overclocked the FX4100 at 4.08GHz with 220MHz FSB with default voltage and heat-sink.
Do you have any DX9 results? I'd be particularly interested in Skyrim benchmarks (with at least some ultra benchmarks thrown in).
Oh, also, my FX6100 will not do 4GHz at stock voltages. Takes 1.45V to be completely stable at 4.3GHz. So, "all" might not be the best word to use here...
Read the article from Toms Hardware:
http://www.tomshardware.com/reviews/gaming-cpu-review-overclock,3106-2.html
Have a nice day.
Reliable overclocks can be a pain and over time damage your CPU. I don't see why people are saying reducing your CPU's life expectancy just to match stock performance of a competitor is a logical alternative![]()
Its a sad day when Toms is brought up.
They have always been intel biased and now they are worst then ever. It goes beyond not trusting their reviews. More like they have n00bs doing the reviews.
Really? I always thought that Tom's was biased Pro AMD back in the Athlon XP era. Odd that they've gone full circle.
Another note:
Street price of the FX-4100 is about the same as the i3-2100.
At stock, i3-2100 beats the FX-4100.
Overclockers claim that after overclocking the FX-4100 the FX-4100 will match or exceed the i3-2100.
Lets say we stick with stock cooling on the 65w i3-2100 and 95w FX-4100.
An i3-2100 paired with a sub $50 bare bones H61 board can beat an FX-4100.
If we were to introduce current Microcenter pricing,
$99 i3-2100
$55 biostar board
- $40 MC bundle discount on intel boards
$114
What is kinda of motherboard could be paired with an FX-4100 allowing for reliable overclock that can beat an i3-2100+H61 combo?
