Wow, I never expected this. Is there even demand for this instruction set at this point?
so...No, its a design that can still scale relatively easy.
poulsonNow just waiting for IBM to release Power 8 in response.
so...
they doubled the performance because of "yes, we can" ?, or because itanium was losing suport?
Ivy Bridge doesn't have twice the cores and the benchmark data that Intel's
own press release is showing are for server benchmarks which love moar cores.
So by your logic Intel should have doubled performance from P4 to Core 2? Yet it was "only" 40%? And actually only 20% compared to Pentium-M. Not exactly fitting into competition conspiracy is it?
Numbers please.Intel says that in its internal benchmarks on a variety of commercial workloads that matter for Itanium, the eight-core Poulson are seeing somewhere between 2 and 2.4 times the performance of a quad-core Tukwila chip. But HP says it can do better than that, thanks to software tuning. "We have systems in the labs that are significantly above 3X," bragged Lewis. So you could get something on the order of three times the bang for the buck.
Thats one epic update. Very nice to see Itanium still kicking. It was wierd to see they jumped over 45nm.
But damn, Poulson basicly moves Itanium up in the top again. And 54MB cache 😱
Soon(tm) you can freely change between Itanium and Xeons on a board. Thats pretty amazing too.
wtf .. 2x performance increase? And on x86 we're struggeling to get another 10%?
Envy much?
Yes.
nop.... 40% is alot
and, i would be very happy with a 20% increase with haswell to ivy
but 8, 9, 10%..... booooo!
If competition is the reason, why are ARM cores so dull and turtle slow in terms of performance increase? Or AMD chips for that matter?
I mean obvious you must have the answer to back up the "conspiracy", so please, explain.
conspiracy? WHAT? WHERE?
LOL, create a thread and try to explain why the lack of competition is good for the consumers...(oh...don't forget to use lub)
Its you who claims that its the lack of competition that holds us back. yet you cant prove it does, since high competition segments shows exactly the same behaviour. So how does that work out? 🙄
yes...Its you who claims that its the lack of competition that holds us back. yet you cant prove it does, since high competition segments shows exactly the same behaviour. So how does that work out? 🙄
yes...
atom
tick-tock model of 2 years cadence
but for some odd reason, intel accelarated it to 1 year...
i am sure that bobcat and ARM progress have nothing to do about it 🙄
Itanium: A solution in search of a problem.
What are you talking about? Intel is still on a 2 year cadence, Tock every 2 years and Tick every 2 years.
this:
I did, but only after reading a few months back that HP is basically bankrolling Itanium development due to having quite a few eggs in the basket. If not for that, I think it would be dead.
I will believe it when I see it. Atom has been slower than 2 years for awhile. If 2014 gets Atom to 14nm, then I will agree with you. Until that happens, I disagree 🙂
- I have a counter-proposal for you: Prove that lack of competition is good for innoivation.
I dunno, to me it seems simple, but you may have an illuminating argument?
