jlee
- Sep 12, 2001
- 48,518
- 223
- 106
Originally posted by: fleabag
To the op: If you want to improve anything, try to improve the amount of gas you get per dollar and you can do this by filling up at night or very early morning where the gas is its coldest.
Oh dear God in Heaven not this bullshit again. The storage tanks are underground far enough that there is no significant temperature fluctuation. The fact that this myth keeps getting passed around is a testament to the frightening lack of basic scientific knowledge among the general public.
Something I posted on another forum a long time ago that still holds true:
Ever gone into a root cellar in the middle of summer when it's ~100 out? It'll be ~60 degrees in the root cellar, and a root cellar isn't even completely burried. Put something 10-15 feet underground like a gas station's tanks are and you're talking about maybe, maybe a 15 degree swing in temperature from the coldest time in winter to the hottest time in summer. Daily fluctuation would be less than 1 degree.
For comparison, using measurements from a root cellar in Alberta, outside temperatures were less than -40 Fahrenheit and inside the root cellar the temperature was around 35 degrees (i.e. above freezing) but in the summer when temperatures were in the 90's the root cellar's temperature was around 50 degrees.
A 30 degree increase in temperature (from 60 degrees to 90 degrees) will cause an increase in volume of one gallon of gasoline of 4 cubic inches. (From 231 cubic inches to 235 cubic inches.) Half of that increase, which represents the temperature change at tank depth equivalent to an above-ground swing of a staggering 130 degrees (remember that in the above example the below-ground temp changed from 35 degrees to 50 degrees when the above-ground temp changed from -40 to +90), would mean a change in volume from 231 cubic inches to 233 cubic inches. That's a change of 0.8% (0.008gallons) in volume from the coldest day of winter to the hottest day of summer. Change during the average day will be at most a single degree of fluctuation. Not enough to make any measureable difference.
ZV
It's not a myth, it HAS been proven to be true, there is a reason why in canada they have temperature compensating fuel pumps but not here. Since gasoline is calculated based upon temperatures of 60F, when the temperature goes above that, you get less gasoline that you're paying for, and when the temperature goes below that, you get more gasoline than you paid for which is why they were so eager to install the temperature compensating pumps in canada but not here since it's hotter here and colder there. This is NOT A MYTH you're just uneducated and misinformed about this.
THIS IS NOT A MYTH.
:laugh:
