Is Shin Etsu as effective as Arctic Silver 5 for CPU cooling?
Ranulf
2,898
2,561
I recall reading that shin etsu was making thermal pads or someone was that were very good awhile back but I could never find any place that sold them. I've used the Coolermaster stuff and it was fairly easy to put on but I'm lazy/overcautious and don't like messing around with that stuff on a cpu. :)
Lazien
128
Your right 1313.....I bought the Coolermaster kit for work and it does indead spread waaaayyyy differently than Shin Etsu and it just doesn't have the same "feel", so I dont think it can be 100%. The Coolermaster kit is perty cool with the template and the little credit card thingy but that's all noob stuff there :)
I used to use Shin Etsu all the time because it was the best bar none but.....with the release of AS5 (and the fact that I ran out of Shin Etsu) I bought a tube of AS5 and I've found it to be a touch "cooler" than the shin etsu....not enough to champion the stuff but it is better IMO. The biggest downfall of Shin Etsu is that it's fairly hard to find...it seems whenever I place an order online for some pc goodies the vendor's usually dont sell shin etsu or all they sell is AS stuff so I just bought the AS5 this time to try it out.
On a side note, I thought the Ceramique was way worse than AS5? Are You saying they are similiar 1313?
P.S. I didn't know that AS5 settles out :( anyway to stop that? I bought a 12gram tube so I have lots left over lol
Nov 11, 2004
10,855
The AS5 only has a few degrees advantage from the Ceramique.
1313
201
Shin Etsu pads are good for pads...but no match for thermal compound.
I have to order Shin Etsu pads in huge quantities...in an exact size. So far I've only used them for customers who are in the aerospace industry.
1313
201
P.S. I didn't know that AS5 settles out :( anyway to stop that? I bought a 12gram tube so I have lots left over lol[/q
That's the funny thing about thermal pastes... normally I expect Shin Etsu X23-7783D tp run 1 to 1.2 degree C cooler than AS5 ..........and AS5 to run 1.2 to 1.4 degree C cooler than Ceramique.
Yet, depending on the chip and the heatsink surface flatness and finish...and the clamping pressure..... AS5 can run as cool or slightly cooler than X23-7783D ..... or Ceramique can run as cool as AS5.
I like Ceramique because it is cheap, yet a very good performing thermal grease, non conductive, and very easy to apply.
Ceramique is a popular thermal grease for sub zero overclockers [ like Vapochill ], and seems to do very well.
This is probably because AS5 needs 200 hours of burn-in to hit optimum performance, and Shin Etsu also needs a long burn in, at least 72 hours to hit best performance.
At sub zero, the heat exchanger is quite cold and is keeping the temperature of the thermal grease quite low, so there is no cycle of higher temps to evaporate the more volatile evaporative synthetic oils.
Ceramique hits top peformance quickly, and doesn't need as much burn-in.
AMD doesn't like phase change thermal grease like Ceramique because it can create suction between the heatsink and the processor.
But I don't see this as a problem for an experienced user, since cautiously twisting the heatsink while still quite warm will break the suction.
1313
201
The issue of thermal pumpout was covered by AMD for XP processors in 2003:
>>>For permanent installation AMD only recommends using phase change material with the heatsink/fan. No thermal grease is recommended for anything other than temporary evaluation purposes. And the only thermal grease recommended for that is Shin Etsu G 749. Artic Silver is made up of a matrix with conductive particles. There is the possibility of creating electrical shorts on the package. Any failed processor used w/ Artic Silver or any other thermal grease other than Shin Estu G 749 would be subject to warranty voiding. The concerns with other thermal greases are due to thermal pumpout causing overheating with on off cycling of the PC over time. The above information assumes you are referring to use with Athlon. For Opteron Shin Etsu G 749 also is the only thermal grease recommended for permanent installation. Again the concern is due to pumpout with thermal cycling.<<<
http://www.amd.com/us-en/assets/content...Thermal_Material_vendor_list_ENG-S.pdf
With the A64 processors AMD approved thermal compounds :
>>>Thermal Interface Materials for AMD Opteron? and AMD Athlon? 64 Processors
AMD evaluates thermal interface materials for use with its AMD Opteron? and AMD Athlon? 64 processors. A list of suggested materials is provided in the table below.
Suggested Thermal Interface Materials Manufacturer Interface Material Material Type
Bergquist TIC-3000 Grease
Shin Etsu G751 Grease
Shin Etsu X23-7762 Grease
Shin Etsu X23-7783D Grease
Thermoset, Lord CPD TC-350 Grease
The heatsink makes contact with the top surface of the processor package utilizing the thermal interface material between the processor lid and the heatsink. AMD recommends using a high-performance grease such as those listed in the table above. AMD does not recommend using phase-change materials between the heatsink and the processor.
Phase-change materials develop high adhesion forces between the heatsink and processor when the material is in the solid phase. This strong adhesive force may cause the processor to stick to the heatsink. During heatsink removal, this strong adhesive force may cause the processor to be removed from the socket while it is locked, and this action may result in damage to the socket or to the processor pins.
Most grease should be applied in a 34 - 35 mm square that is 0.06 - 0.08 mm thick. This amount of grease has provided good coverage of the processor lid while not being excessive. If excessive amounts are applied, grease may flow over the edges of the processor and reach the socket . This is not desirable.<<<
I haven't used the Bergquist TIC-3000 Grease or Thermoset, Lord CPD TC-350 Grease...but Shin Etsu compounds take some technique to apply. I think if the Shin Etsu compounds were easier to apply then they would have a problem with thermal pumpout.
Shin Etsu compounds are fairly thick, without much evaporative chemical. Shin Etsu supplies the electronics industry, and is focused on performance and reliability.
As the old Dans Data toothpaste review shows lots of materials [ including ground diatomaceous earth [ silicon from Diatoms ] in toothpaste or yeast fermentation by-products in Vegemite...both in a water based paste ] can post good temps, for a while.
The trick is making a compound that works for years, doesn't pumpout, doesn't corrode, doesn't damage components, and still delivers top perfomance
G751 has varied and larger particle sizes in a thick paste that has a viscosity and consistency much like wood putty..but it works great for chips like GPU's and Northbridge which may not be flat or smooth...and it works well with rough finishes on heatsinks.
Larger particles fill in rougher surfaces better, and in combination with a more viscous formulation, fill in larger gaps and stay put.
X23-7783D has smaller particles, and the particle size is very uniform, and it easier to apply and works well on CPU's, especially newer processors with larger packages, and it woks well on lapped chip/heatsink combinations.
Smaller particles fill in a smooth surface better, and a less viscous formulation with some evaporative chemical spreads thinner and gets even thinner after burn-in ...yet still avoids thermal pumpout.
Shin Etsu applies much better when warmed, and a thin layer [.06mm] works best. The thermal compound doesn't spread as easily, but that is why it stays put.
During thermal cycling, [burn-in] the small amount of evaporative chemical leaves and the boundary layer gets thinner, but more importanly the particles fill in the surface irregularaties and any remaining air leaves the interface.
Thermal Interface materials seem to be like motor oils, easily marketed with lots of hype.
I choose products based on engineering and testing. Good materials, and testing help to determine the best overall choice for a given application.
