maddogmcgee
Mine just "puked" a moment ago. Monitor suddenly goes blank, in the middle of scrolling, USB wired keyboard and mouse lights go off, cannot even use hardware RESET button, have to force power-off. Power-on, all is fine and dandy again.
I am using 3600 RAM, and had my FCLK set to 1800 to match, so there's that, and of course, the fixed 4000Mhz OC, using a middling voltage that stock uses too, so I don't really see the problem with that.
Are we as end-users expecting too much? Spoiled by Intel platforms, where the "max turbo" is generally easily achievable as an all-core speed, with the right motherboard (Z390, or other overclocking-capable chipset), and sufficient cooling (which, with certain Intel CPUs, meant de-lidding as well).
As opposed to AMD's Zen2 platform, where "max boost" is rarely, if ever, achievable in the Real World, and heaven help you if you want a true all-core OC, running AVX2 loads. Time to underclock, to prevent screen black-outs.
Anyways, I'm back down to stock settings, except for setting XMP (DDR4-3600), not going to even adjust FCLK (defaults to 1600, so mis-matched with DRAM right now). I want to see if I get "black outs" with these settings. If I do, I might ring AMD for an RMA. Or try my luck with a 3700X next month instead.
Edit: This is all under 240mm AIO WC, and I've had the A/C going (recently cleaned my A/C, so it's actually nice and chilly in here now).
Edit: Running 12 threads of PrimeGrid PPS LLR, at "stock" CPU settings, HWMonitor is reporting my Vcore at 1.384-1.395. That's at stock. CPU speed is roughly 3.917Ghz. So not too far off from my fixed manual 4.000Ghz 1.365V manual OC. If anything, I wasn't giving it quite enough voltage, and that's why I got the blank-screen / "puke" symptoms twice thus far.
most people don't overclock so a CPU getting close to its limit at stock is actually a good thing. I still wouldn't call that 1.365 a middling all core voltage. when you are at stock it's checking the current,power and temp limits constantly and adjustingvoltage and clocks many times a second based on its boost table. with an all core overclock you are turning all that off and the letting the sustained current hit higher levels than it would otherwise.
