fijianalky86
- Dec 23, 2008
- 29
- 0
- 0
M2N-E 570 (non-sli)**latest bios** works perfectly fine with Phenom 720 and 4 sticks of ram (4gb) on Win XP 32-bit....
Edit2: found it, though its a dodgy looking site.
http://www.lejabeach.com/Biostar/TA790GX/
I really wish Newegg would put another search feature in to filter boards by PhII support...
Originally posted by: jmadams
I'd have to say no for Asus M2N-SLI Deluxe. I can boot into windows only if I take out two of four dimms and I had some other random problems. Although I've heard many people with the same issues, some have reported that it works fine. If you like experimenting, I say give it a try. If you're like me, and want to plug and play, don't do it until a BIOS update is available. But from what evidence I can gather, Asus is doing no BIOS updates for any AM2 based boards to support Phenom II.
John
Originally posted by: ultimahwhat
Gigabyte GA-MA78GM-S2H rev1.0, F7 bios
Works, but I'm cautious:
PII X4 940 is working fine so far at stock. Stress testing with OCCT just to check for temps. I'm kind of afraid to overclock it much though because of the 125W TDP (and previous non-support of 125W Phenom I CPUs).
Note: this is the board with the crazy NB temp readings. With the PII running the NB at 1.8 GHz up from 1.0 GHz with an X2, the temps are soaring!
