Audiophile1980
- Sep 6, 2004
- 168
- 0
- 0
theres socket 478(the original pentium 4 platform)
Wrong. Socket 423 was the first P4 platform. Socket 478 was the second.
Anyway, Prescots run too hot. Here we can see the maximum thermal power of the top end prescot at:
119.0A * 1.27V = 151.13W 3.6 GHz (PRB 1)
That's the max thermal power, not the BS TDP that Intel uses. AMD uses the MTP aswell so these numbers are directly comparable. A top end hammer is pegged at 89watts although that's where AMD limits them. They likely don't go that high.
So you're comparing 90watts to 151watts. That's a HUGE difference.
There are other things to consider too. The prescot does NOT support the NX bit which is hardware support against buffer over-run. It's like buying a car without airbags right before all cars come with airbags.
Not a wise move. It'll also never run windows 64 where the hammer will. This has been shown to provide a 5-7% boost in 32bit apps and a signifigantly larger boost to 64bit apps, especially those that most benefit from that architecture. True, there are some 64bit NX bit prescots coming but that doesn't help you much today and the thermals will be similarly insane.
Honesly, buying a P4 of any flavour now is not a wise move.
