Originally posted by: sash1
Running builds leg muscle and burns fat?
You still need a surplus of calories to build ANY muscle.
Actually, you need protein to build muscles. Hence the very existence of the whey protein.Originally posted by: Special K
Building muscle requires eating more calories than you burn. Losing fat requires burning more calories than you consume. These two requirements are kind of at odds with each other, unfortunately.
so am I not correct in saying running builds leg muscle and burns fat?
Originally posted by: ahurtt
I don't see why it isn't possible. If you are already fat somewhat, execising your muscles will burn that fat. All you need to eat to build more muscles is high protien. That will provide the building blocks for building new muscle cells (which are more dense and weigh more than fat cells). The existing fat you have in your body can be used as energy for those muscles to burn. In fact, the more muscle you have, the more fat your body burns. . .that's assuming you don't substitute by eating a lot of carbs. I see no reason why with a diet high in protien and low in fat and carbs, you cannot both loose fat and gain muscle at the same time.
True, but at the end of the day you have to be eating above your maintenance level of calories to gain any weight.
I was under the impression that muscle weight would replace muscle weight on a careful diet.
For me, I cut my calories to 1,500 a day. I eat carefully balanced meals with an occasion Whey protein smoothie.
I have lost fat and built muscle.
No. Sorry. Your body normally uses protiben to build. It normally uses carbs and then fat (in that order) for energy. However, in a pinch, assuming your body has no fat or carbs left to metabolize for energy, it CAN convert to using protien for energy. Excess calories, of any kind, get converted to fat. If your body has excess fat, it will resort to tapping into that fat as an energy source before it taps into its supply of protien. This leaves your body free to use the protien as new building blocks for new muscle cells.
The idea that the fat you burn will be used to synthesize new muscle is a good one, but unfortunately unless you are a complete beginner, have exceptional genetics, and/or are on drugs, doesn't work too well in practice.
brikis98 is right on in that you are better off focusing on 1 goal at a time.
I am not saying the fat you burn will be synthesized into new muscle. I am saying fat is excess energy. Muscle can only be built from protien (amino acids more specifically). There is no way to convert fat to protien. But fat can provide the energy your body needs to carry out exercise and do work leaving any protien you consume free to be used to synthesize new muscles.
although you are correct that to get the best results, you should focus on 1 at a time, you can still get results even if you don't fall into the categories you listed above (beginner, genetics, drugs). your progress will be slow, but i can tell you from personal experience, it'll happen.
if you lift 3 days a week and do cardio 3 days a week with healthy diet (favoring more protein and less carbs, fats, etc) i absolutely gaurantee you will lose fat and gain muscle. however, the amount of muscle you will gain will be less than if you just focused on lifting (and the appropriate diet for it). likewise, the amount of fat you'll lose won't be as much as if you focused on cardio (and the appropriate diet for it).
still, it's worthwhile, especially if you are a beginner. going for both is an excellent way to get your body into good shape and set it up for a more focused approach to each of those goals later on.
Even still, the more muscle you have, the more difficult it becomes to add more, especially if you also want to achieve a very low bodyfat.
I have been training for 3 years now and it just keeps getting more difficult to make gains.
