Question Is it possible to apply efficiency gains and performance gains to separate parts of an SoC ?
FlameTail
4,384
2,762
Let's say I make a hypothetical smartphone SoC called 'Flame 1' on the 7nm Node.
Then I introduce the 'Flame 2' SoC which is identical to the Flame1 in every way (same cpu, same gpu, same npu), except that it is built on the newer 7nm+ node.
Now let's say the 7nm+ Node give x% more performance OR y% more efficiency than 7nm.
So can I apply the performance improvement of the new Node to part of the SoC ( eg : CPU ) and apply the efficiency improvement to another component ( eg: GPU ) of the same SoC ? Is this possible ?
turtile
634
315
I have no idea about different design rules on one chip but this can easily be done with chiplets.
Thala
1,355
653
You control whether you want better performance or power via voltage and clock. So assuming you have different voltage and clock domains in your SoC - you can decide per domain.
Tup3x
1,296
1,434
In that case you'd clock the CPU part higher (get more performance at same power) and keep the GPU part as is (same performance, lower power).
