It is comparing apples to oranges, but I'd think the same scenario would hold for bulk purchases too. About the only advantage HDDs have are slightly increased capacity for a given price. But that is more then offset by the performance disadvantage.
Yes, Notebooks are outselling desktops by a fair margin, but then traditional tower desktops are dying too. Especially in corporate. Most newer equipment tend to be small form factor, or even NUCs. Which don't have room for a traditional 3.5" HDD.
My own opinion is that in 2019, nobody should be made to suffer a HDD based system.
You can not compare a 3.5" HDD to a 2.5" HDD when disk storage size is involved, the max a single 3.5" HDD can currently hold is always greater than the max that a 2.5" HDD can hold.
On another note, a 1 TB 2.5" SSD is never going to be cheaper than a 1 TB 3.5" SSD, a lot less miniaturization and microness of the components are involved in 3.5"SSD.
SSD's do have down sides compared to HDD's. SSD's can not be used for applications that involve large number of deletions or overwrites. It's a proven fact that Uncorrectable Bit Error Rate is much larger than that of a HDD. Another issue that SSD's have is that they are more likely to fail, in a more unforgiving manner than HDD's, in terms of water damage occurring. The same statement can be given for an electrical surge. This is due to the fact that, SSD's have more electrical circuitry components when compared to a HDD's. It is also much more easier to retrieve data from a malfunctioning HDD, than it is for a SSD. The reason being is that data on a HDD is written on a magnetic medium which could be removed, from its casing, and read in other ways or forms; albeit maybe in a theoretical sense, of placing these magnetic disks in another casing. With SSD's, one needs knowledge of how the specific circuitry is created, to understand which data bit is where. As in the previous scenario of water damage or an electrical surge, the memory containing components (chips) could be damaged such that data is not retrievable from it. This is not the case with HDD's, more especially in the scenario of an electrical surge, where only a small portion of the magnetic plate might get over magnetized, or the arm could get damaged. Now these are the issues with SSD's when compared to HDD's overall, however in a business environment there will are actually a lot more issues.
In a business environment, when a data storage device is upgraded or if it is needed disposal off, the data in the drive needs to cleared and unreadable. If that is not done, then it could cause harm or a breach in security and policy, if the improperly disposed drive contains trade secrets or any classified data. In reality, it is actually costs more to destroy a SSD than it does to destroy a HDD. A HDD can be disposed of by opening it up and placing it in a microwave for a few minutes.
This is not the case with a SSD. It would take a lot of more lucrative work to destroy such media and/or make its data gone or inaccessible. Basically... a new job requirement in security field would be... must be stong enough to destroy things with hammers (Advil or Tylenol not paid for). Now that would probably be unfair for those with physical disabilities.
