Is it normal for cpu to be this hot?
Status
Not open for further replies.
VirtualLarry
56,587
10,227
Well then that means it has the same mounting holes as s775 right?
In that case I'll just dig up my old Freezer 7 Pro and try that out rather than spend money.
You really don't read very well, do you? No-where in this thread, has anyone said that S1155 is the same as S775. Why? Because they aren't. However, S1150 is the same as S1155, as far as mounting hardware goes. Which, for some reason you won't believe, but you are willing to believe that S775 is the same as S1155, for some dumb reason?
ShintaiDK
20,378
Yep, LGA115x shares mounting holes and coolers. LGA775 however, totally different.
Status
