toyota
- Apr 15, 2001
- 12,957
- 1
- 0
you will certainly be fineSo then it would be safe for a 24/7 overclock? Yes, I am using power saving, by the way
Not speaking for Intel, but speaking as an engineer who designs high speed analog I/O on an Intel CPU, electromigration is not only real but a huge amount of my design effort is spent making sure it isn't a problem. With that said, you are insane if you think an overclocked CPU should always work flawlessly, especially if you increase the voltage.
As for this:
I assure you that the last 25mV had very little to do with it. It was the other 300.
Degradation is a process by which something gets destroyed.
Besides, if it's as bad as people say it is, people's CPUs should be blowing up by now.
Degradation is what happens to you when you post about how much better your 8150 Bulldozer is than an Ivy 3770k.
Well, the forums at the time had said that the general wisdom was that 1.4v was the max safe voltage for 45nm Core2 chips. As was said, 1.5 or 1.55v was the safe max for 65nm Core2.
Whether either of those is true, I have no idea.
But I cringe, when I see people running 1.4v+ (some 1.5v+!) on SB CPUs, being that they are 32nm, knowing how a 45nm Core2 degraded at those voltages.
could be the motherboard getting old.
I had what I thought was degredation. e2180 stock 2ghz at 3.4ghz 1.5v.
Turned out the board was getting old, voltage at 1.48 would drop to 1.47, 1.46 under heavy load-- started giving me BSODs. Bumped up the voltage to 1.5025, and it would drop to 1.48v. Was good to go again for years.
I think a lot of people have this problem and blame the CPU.
Yes, its real, but usually takes years to see the effects of a max overclocked (mild vcore) system. That is when you run them 24/7@100% load like I do.
I assume having my 2500k at 4.4 using 1.33 will have no real impact on its useful lifespan since nearly 90% of the time its just at 1.6 and idle voltage of around 1.00.
Electromigration:
This is the most likely reason an overclocker will kill a processor. When the DC current in a line is too high, the metal grains that make up the wire are physically pushed aside by the electron wind. The longer you run the chip at higher than design voltages, the more the metal is distorted. Eventually it gives up the ghost and the circuit fails permanently.
Hot Electrons:
Again caused by overvoltage, when there is a high voltage between the source and the drain of a device, a high electric field is created and electrons accelerate, damaging the oxide and interface near the drain, changing the transistor threshold and mobility. In an N-transistor, the gate is always positive and the shift is always in the same direction. Eventually the threshold moves to a point where the transistor no longer switches and is effectively dead. This problem is exacerbated by the move to smaller technologies as, although device voltages are reducing as sizes come down, they aren't reducing in proportion to the device shrinkage, leading to higher field strengths compared with older devices.
I'm sure those numbers were not arrived at with anything other than empirical evidence. There's something to be said for that, though.
With that said, 1.4V on Sandy Bridge is nothing short of retarded.
I think alot of people confuse the concept of a dead CPU and a faulty one. Remember there is alot of software exceptions, crashes, maybe a BSOD now and then. All can be caused by degration. It doesnt have to be totally dead. And as some say, some will still work at lower speeds.
the problem is the bigger electrons cause the most damage. the smaller ones don't cause any electromigration. if we could filter, somehow, the big electrons out, and send them to the motherboard instead, that would fix the problem of degredation.
There is no such thing as big or small electrons. Nor can you send them to the motherboard to avoid material degrading.
In modern consumer electronic devices, ICs rarely fail due to electromigration effects. This is because proper semiconductor design practices incorporate the effects of electromigration into the IC's layout. Nearly all IC design houses use automated EDA tools to check and correct electromigration problems at the transistor layout-level. When operated within the manufacturer's specified temperature and voltage range, a properly designed IC device is more likely to fail from other (environmental) causes, such as cumulative damage from gamma-ray bombardment.
