Is a nVidia GeForce4 MX 440 same as Radeon 9200?
Schadenfroh
38,416
4
9200 = 9000 with 8x agp, the 9000 is a striped 8500 but still retains the dx8 archetecture, i would say in dx8 games, the 9000 is better, in everything else i would think the mx would be better and forget about dx9
videoclone
1,465
The nVidia GeForce4 MX 440 MX420 and MX460 are all Direct X 7 Cards ... there pretty much Geforce2 GTS cards with a new name.
The ATI Radeon 9000 9100 and 9200 are all DX8.1 Cards and feture Cores similar to the Readeon 8500.
DAPUNISHER
32,121
32,694
Originally posted by: Matthias99
The GF4MX is based on the GF2MX, which is a DX8.1 part. They have full DX8.1 support.
You're mistaken.
Matthias99
8,808
NVIDIA claims DX8.1 support, and it works in games that "require" DX8.1 support (like BF1942). I'm not sure how much more DX8.1 you can get.
modedepe
3,474
Well of course it works in dx 8.1 games, what dx7 card dosen't? But that doesn't mean it can utilize dx8.1 features. It can't. It's dx7. And show me where nvidia says it's a dx8.1 card.
kylebisme
9,396
well my voodoo5 has some issues with dx8.1 games...
:D
but back to the question, the mx cards are all dx7 class hardware and nvidia never even made a dx8.1 class card.
Matthias99
8,808
http://www.nvidia.com/attach/3665?type=support&primitive=0
Second page, down at the bottom. The RIVA TNT2 doesn't work at *all* in DX8.1, to name one card. The GF2 and GF4MX do. Maybe they don't do everything in hardware, but it supports DX8.1 just fine.
modedepe
3,474
There is a big difference between simply "supporting" a given version of dx and being built to use the features. For instance, a ti4200 is a dx8 part, but it will run dx9 games such as hl2 in dx8 mode. Does that mean we can say it's a dx9 part? No, we can't. Same thing here with the gf4 mx. It may play dx8 games, but they run in dx7 compatibilty.
Edit: Also, your statment that a tnt2 will not work in dx8.1 is false. Take for example gta3. This game requires dx8.1. Tnt2's work fine with this game.
Matthias99
8,808
TNT2s do *not* work properly in BF1942, which requires DX8.1. The fact that they work in another game that "requires" DX8.1 is meaningless.
I'm not talking about games having a backwards compatibility mode (like HL2). Games which *only* run on a DX8.1 card will run on a GF2 or GF4MX, but not on (for example) a GeForce1. The card, between the hardware and the drivers, is compliant with the standard. Does it do it all in hardware? Probably not. Does it do it all quickly? Probably not. But it works. How can it "support" it if it is unable to use it? That's the definition of "support" (or at least the one I use).
modedepe
3,474
The reason a tnt2 won't work in BF1942 has nothing to do with dx. BF1942 requires hw t&l, which the tnt2 can't do. Furthmore I don't see how a tnt2 working with another game which requires dx8.1 is "meaningless." It means that the tnt2 can in fact work fine with games that require dx8.1, even though it is not a dx8.1 card. It proves your point that a tnt2 will not work with dx8.1 "at all" is incorrect.
Matthias99
8,808
Wait -- isn't HW T&L required as part of being a "DX8.1-compliant card", according to MS? If not, I'm confused (and wrong about the TNT2, which wasn't terribly important anyway). But my point remains that NVIDIA claims (and nobody that I've ever seen has disagreed) that the GF4MX *is* a DX8.1-compliant card. If it isn't, then what games is it not compatible with? Or are there *NO* DX8.1-only games on the market?
DannyBoy
8,820
www.danj.me
ffs people like you really bug me, despite being told by a selection of different users you still insist you are correct.
This has been discussed many times, the GF4MX will run an 8.1 dx game, but the HARDWARE itself is based on a dxSEVEN core.
If you want to get cocky, then we can both head over to the reference designs of the NVIDIA NV cores.
edit: Infact you go and find them yourself, then come back and tell me you are correct.
xSkyDrAx
7,706
Well back to the origional question, no its the same cause the 9200 has pixel shaders and the mx440 doesn't. I think that the 9200 is faster than the mx440 cause I saw my friends mx440 do 2-3k on 3dmark01se and the 9200 SE!...do 4k in same. That should say a little something even if its not completely accurate, no?
lazybum131
231
Anandtech article with info about the NV17 (Geforce4 MX)
In case Matthias99 has trouble finding info.
Exerpt from the article:
another way of looking at it would be the GeForce3 without two pixel pipelines or DirectX 8 compliance. The problem most developers will have with this is that the uneducated end user would end up purchasing the GeForce3 MX with the idea that it had at least the basic functionality of the regular GeForce3, only a bit slower. While in reality, the GeForce3 MX would not allow developers to assume that a great portion of the market had DX8 compliant cards. Luckily NVIDIA decided against calling the desktop NV17 the GeForce3 MX, unfortunately they stuck with the name GeForce4 MX.
Sid59
11,879
look at the beefcake of a videocard!
DannyBoy
8,820
www.danj.me
Just think, these days we can fit that video card into a single chip ;)
modedepe
3,474
I guess hw t&l might be required, but I don't know the exact dx8.1 specifications. If there are any dx8.1 only games, then I haven't heard of them.
beserker15
820
i'm guessing you're asking for a buying question? if you are under a heavy budget, then the mx440 can be found on compusa tomorrow for $30 after rebates, it can run dx7/8 games fine, even if it doesn't support some of the features, you might not see the difference. at the price of the 9200 ~$70 however, you should buy a ti4200 or a 9100 which is better.
kylebisme
9,396
hardware t&l was intoduced with the orignial geforce, the tnt2 was dx6. nvidia did advertise the geforce4mx as dx 8.1 "compatable" though, pretty dirty of them.
DAPUNISHER
32,121
32,694
The G4MX doesn't support DX8.X vertex&pixel shaders and hence dosen't meet the DX8.x specs making it a DX7 card. Just run 3Dmock2k1se and you'll quickly see that it's not capable of running the tests with DX8.x features.
Rufio
Banned
Mar 18, 2003
4,638
ok u guys got too technical for me.
i just wanted to know which card is better in general. :p
