If you want (relative to IPS, TN, etc.) deep blacks, high contrast ratios, 8-bit panels without FRC, little backlight bleed, and no glow than you should look into an LCD with a VA type panel. They blow away other panel types as far as blacks and contrast ratios are concerned and that's why I picked my BenQ GW2750. Only problem is if you want resolutions higher than 1080p but manufacturers are working on that.
Don't game in a dark room, problem solved
here's an example video https://www.youtube.com/watch?v=lfAsCMMkAKA
I have a 6 year old TN panel and am afraid to jump to either 120hz TN or an IPS. Hoping something with less obvious drawbacks comes out soon. G-Sync... 120hz IPS... something that merges the tech.
Then again if I (or anyone) is happy with an OLD 5ms blacklight bleed crazy TN panel then I'd have to imagine I'd be happy with anything new. TN's have gotten better over the years I've heard... and so has other display tech.
I usually play 'dark' games in a dark room but always with a small source of light in the corner of the room (lamp)
If IPS is shit in terms of playing in dark room, will just send it back. Or perhaps bring it to work and convince my boss to buy it from me 😉
Not sure if I mentioned that before, but it turned out my TV is IPS. It has IPS glow but it never bothered me to date and I can barely see it now (even when watching horror flicks). I also used to play games on it a bit in the past and never felt something is wrong. I wonder how this compares to Dell screen I'm getting
Hi guys
Trying to get myself a new monitor and I've been doing a research for many days now. My PC usage is 80% games (non competitive, mainly single player) and 20% internet/work. I narrowed my search down to either an IPS (Dell P2414H) or one of the standard gaming 60Hz TN's in 200-300 quid range (eg BenQ RL2455HM)
Now, my main problem with IPS is I'm extremely concerned (scared even) of amount of glow that could possible take all the pleasure from using this screen (or even become annoying). Like I mentioned, I do play games a lot and I do like atmospheric or horror games with plenty of black color on screen. I'm used to what I have in terms of blacks on my current TN and I'd at least like to have the same. not worse.
I own an IPS TV from Phillips and I can definitely see the glow when watching a movie in a dark room (I'm yet to do a proper gaming test tho). The experience is of course slightly different as a) it is a different screen (brand, model), b) I watch from a bigger distance than I would a PC monitor.
I think my main question here is then directed to all gamers who had a TN screen not that long time ago (so they can still remember 😉 ) and do play a lot of atmospheric games in a dark room. Can you tell your experience with the glow after switching to IPS panel? Is it annoying? Do you even notice it?
