Well, technically it does because cruise can't change gears for you. Get to a steep enough incline, where it would make sense to downshift, and it will obviously just give as much throttle as possible to compensate.
snip
I will definitely remember this. When the cruise control is on, the automatic tranny will automatically unlock the torque converter, automatically drop 2 gears, then automatically burn the shit out of the transmission. Maybe this is the safety plan against unintended acceleration. Just let the throttle stick for a minute and the car will stop once the transmission melts.Let me try again. It's an automatic tranny. It does what it is programmed to do. Don't like what it is doing? Drive stick or get a better/different automatic tranny.
I'm curious what you were doing when you tested this. You're in a car with 343hp, top gear, on the highway. You approach a hill that even your car can't climb in top gear. Were you pulling a trailer full of rocks or something?343hp and a manual with cruise that hammered on the gas would have me doing 183 mph. It does, however, cut cruise if the engine is lugging
Always a possibility.Any automatic that I've driven with cruise control would floor the throttle before down-shifting... have you ever thought that maybe your crapolla just doesn't have enough torque in top gear to get up the hill?
Toyota's transmissions are purchased from Aisin Warner. To be a better engineer than a Toyota engineer, all one needs to do is buy a better transmission than the one picked by Toyota. That's pretty simple. I want a Honda transmission since they don't disintegrate under full throttle.Go Build Your Own...Obviously you are much smarter than the mechanical engineers that came up with the tranny in your car.
This is a thread about fuel efficiency and you're saying what race car drivers do. Race car drivers try to keep the rpm close to maximum power so the car can accelerate as hard as possible. I'm not a scientician, but I'm guessing that keeping the engine buzzing at 6000rpm all day is not great for gas mileage.Even race cars do not climb hills in top gear. They have plenty of power and torque. An F1 driver will not try to climb a hill in high gear. Neither will a Nascar driver. They will downshift.
They do when they're not hauling anything 😉Big trucks have torque out the wazoo and they don't climb hills in high gear either.
That shakes my faith in them even more. All this time I thought they were just purchasing poorly made transmissions, and now you tell me Toyota is the one making those crap transmissions.Toyota owns 51.9% of Aisin AW. Who do you think Toyota is going to source trannies from?
Toyota fail. I swear I made a thread about my Corolla transmission changing gears 20 times per minute as a rough guess. Someone quoted it and remarked at how silly it sounded that the transmission would change gears an average of every 3 seconds :awe:first post:
Went on cruise control at 65mph, I just noticed that on up hill freeway the transmission keeps switching up and down every 3 second or so. Is there TSB for this?
In other words it totally is Toyota's fault that my transmission is all busted. I'm not the one telling it to gear hunt. The cruise control tells it to do that.Transmission Hunting is Bad!
It'll heat up the Fluid quickly and the protection of the tranny will dwindle.
If you want to see something funny, go to google and type (without quotes) "automatic transmission up hills". First result:
http://www.rav4world.com/forums/99-...n-keeps-switching-up-down-cruise-control.html
Next post down
Keep in mind where all this heat is coming from. The transmission screws up because you're burning all this extra gas, getting horrendous gas mileage, and that extra gas goes directly into heating and melting your transmission. Toyota = r gooder ungineerz
If the engine were having problems, wouldn't it make the car shake? Generally that's what people are talking about when they say the engine is lugging or bogged down. At 2500-3000, there was never any shaking or weird sounds. It would just maintain speed (maybe drop from 70mph to 65mph) and that was it. There wasn't anything dramatic happening.
If flooring it up hills was bad, then those little 50HP economy cars would never last more than a couple years. Those haven't been made in the past 10 years but you can still buy used Chevy Sprints and Pontiac Fireflies and they still work. Maybe GM just has better engineers. Who knows.
Nice trick question. [bunch of intentionally-misunderstood bullshit]
Hey don't blame me for that. If it were up to me, it would stay locked the whole time. The guys at Toyota are the ones who specifically wanted the torque converter to unlock under load. If unlocking the torque converter generates tons of heat, destroys my transmission fluid, then destroys the clutch packs, it's because Toyota wants that to happen. I can't figure out why they would want that since they're currently replacing the transmission under warranty, but I assume they have their reasons.
Pointing out how flat even the steepest highways are actually proves my point more than it proves anyone elses. I said a Corolla can't deal with steep hills. You correct me by saying there are no steep hills. Fine, then I change my statement to read: Corollas can't deal with near-flat ground. Put a Corolla on a 6% grade and the transmission will burn up. A Honda (or any other car in the world) on that samehillalmost-flat ground never has a problem.
blah blah blah, more automatic transmission crap
rock solid reliability of automatic transmissions is why pickup trucks built for hauling large loads almost always have an automatic transmission
Pointing out how flat even the steepest highways are actually proves my point more than it proves anyone elses. I said a Corolla can't deal with steep hills. You correct me by saying there are no steep hills. Fine, then I change my statement to read: Corollas can't deal with near-flat ground. Put a Corolla on a 6% grade and the transmission will burn up. A Honda (or any other car in the world) on that same hill almost-flat ground never has a problem.
Because that's the whole point of owning an automatic. If I wanted to pay attention to what I was doing, I would have bought a manual. I just want to set the cruise control, stay half awake with one eye open, and get to my destination.Your problem is you blame all this on the car, when it's distinctly obvious you know nothing about it nor how to even drive a car besides steer it and go from A to B.
That's because 3 speed autos run near max torque (about 4000rpm) on the highway. If it downshifted, the thing would explode.I drove my '95 Corolla 3-speed auto up and down the Sierras many times with 0 issues.
http://www.corolland.com/corolla/1993-1997/transmissions.html
1st 2.810
2nd 1.549
3rd 1.000
Your highest gear is 1:1. Here is the gearing for a 2010 Corolla 4 speed:
http://www.autotropolis.com/2010/toyota/corolla/309332/specs.html
1st 2.85
2nd 1.55
3rd 1.00
4th 0.70
The older models also have smaller tires.You need to take the final drive into account as well. The 4-speed as a 4.13:1 final drive while the 3-speed has a 3.72:1 final drive (in the US).
