Z Zoinks Senior member Oct 11, 1999 826 0 76 Sep 9, 2001 #1 The 'enhance pointer precision' button resets to off after reboot. Anyone else have this problem? Win XP RC1 MS Intellimouse with IntelliEye.
S SuperSix Elite Member Oct 9, 1999 9,873 2 0 Sep 9, 2001 #2 If you did an upgrade for win2k, you will need to reinstall the drivers to get full functionality even though all looks well. When did 4.0 come out?
L Lichee Senior member Jan 2, 2001 645 0 71 Sep 9, 2001 #3 yeah, i never saw it on the site. it still has 3.2.
WHipLAsh13 Golden Member Jan 17, 2001 1,719 0 76 Sep 9, 2001 #4 It isn't really out but if you follow this thread you can get your hands on it.
Z Zoinks Senior member Oct 11, 1999 826 0 76 Sep 9, 2001 #5 I'm not sure what you by 'reinstalling the drivers'. I deleted the mouse from the device manager before running the 4.0 setup program. No effect. Does anyone know of a registy setting?
WHipLAsh13 Golden Member Jan 17, 2001 1,719 0 76 Sep 9, 2001 #7 It might have o do with the fact you are running RC1. I run RC2 w/o any problems.
T T2T III Lifer Oct 9, 1999 12,899 1 0 Sep 9, 2001 #8 << It might have o do with the fact you are running RC1. I run RC2 w/o any problems >> Also, the RTM version of XP works without issue...or, so I've heard.
