Intel Starts Production of Next-Generation Haswell Microprocessors.
StinkyPinky
6,991
1,284
One day fusion power will be discovered and then Intel wont care about TDP for the desktop. Say hello to 20GHz 1000W CPU's that doubles up as an incinerator.
bunnyfubbles
12,248
I'm expecting:
-10-15% better performance
-Similar air overclock as Ivy Bridge
-Better top overclocks using exotic cooling(but this is due to other factors like increasing the max multiplier and giving different base clock frequencies)
Cheap TIM held Ivy back, and IIRC its pretty much been confirmed that Intel is going back to solder. And with the extra time of 22nm under their belt plus other overclocking friendly features being added in to the new architecture, I'd almost be willing to bet 5GHz will finally be a new norm for the enthusiast willing to spend ~$100 on cooling
However I'd bet against IPC improvement being that high, it'd wager it will be closer to 10% at best
khon
1,318
124
Who cares about power consumption.
My Macbook lasts 5-7 hours on Sandy and my Desktop runs at 4.0 ghz 24/7 and i dont care about power use there
Anything else is a bonus.
I care about power consumption, because Ivy bridge mobile CPUs overheat, which doesn't just cause the laptop to be uncomfortable to use, it also means they get throttled and thus slower.
NostaSeronx
3,815
1,294
So, you didn't worry about power consumption from:
Sandy Bridge mobile CPUs
Clarksfield CPUs
Penryn mobile CPUs
It seems to me that you are making Ivy Bridge a special point. Even though, Ivy Bridge has the lowest TDP/Power Consumption of all x86-64 CPUs on the market.
Fx1
1,215
they overheat due to bad TIM and not because they use to much power lol
Also i have yet to see a laptop not get hot when under full load
NostaSeronx
3,815
1,294
The mobile Ivy Bridge processors are not affected by this issue because they do not use a heat spreader between the chip and cooling system.
Fx1
1,215
No but i have never seen a laptop maker use good TIM in general. They cut costs during mass production.
As far as i know Apples Retina Pro doesnt throttle under load. i have seen 2 people play 64 player BF3 on it with ease for sustained periods
khon
1,318
124
Clarksfield CPUs
Penryn mobile CPUs
Why would I bring up older and even more power hungry CPUs ?
I don't know about you, but when I buy a computer I want it to have new hardware in there, not stuff from 5 years ago.
khon
1,318
124
My either, which is why I'm hoping Haswell will be better.
Max performance is for desktops. For laptops the goal is adequate performance, while keep battery lifetime long and temperatures low.
NostaSeronx
3,815
1,294
Why would I bring up older and even more power hungry CPUs?
Ivy Bridge - 35 Watt TDP
Sandy Bridge - 35 Watt TDP
Clarksfield - 35 Watt TDP
Penryn - 35 Watt TDP
What is the power consumption/TDP of each CPU generation?
Thirty-five watts.
khon
1,318
124
Thirty-five watts.
TDP only tells you about peak power use, not average power use, and for that there has been a clear improvement generation by generation.
tweakboy
9,517
www.hammiestudios.com
I would rather get a Ivy Bridge E 10 core 20 threads.
Guys Haswell for all of 2013 is mobile chips and budget chips, Most is quad with HT.
In 2014 Haswell comes out for enthusiast desktops.
In 2013 3Q Ivy Bridge E released 6 to 12 core chips that will slap the you know what out of Haswell. Haswell is nothing but a GPU upgrade on CPU to be blistering fast and less power drawn TDP.
Lets get some info on the Ivy 6 to 12 core chips due Q3 2013. thx gl
Piroko
905
79
The Retina Pro 15" uses discrete graphics which will help a great deal and I doubt that the 13" will play BF3 'with ease'.
I'm a bit baffled how so many people here seem to expect (or imply) performance per watt increases of 50% and more as well as an endless supply of magical beans if you'd ever need any. I'ts on the same process as IB after all.
Fx1
1,215
The GPU is irrelevant to my point. The CPU handles the 64 player aspects of BF3 and it doesnt throttle.
mrmt
3,974
And they still didn't remove that [older generation] they wrongly placed there. But this is in line with the quality of the coverage of other Q&A and conferences.
Abwx
12,004
4,968
22nm FinFET isn't tuned for high clocks and Haswell will not bend physics.
It is , by the virtue of intrinsicaly less parasistic capacitances
attached to the fets but it isnt because of the shorter distance
between conductors that increase strain parasistic capacitances ,
so what is gained at a end is lost on the other one , that s why
IB didnt overclock substancialy higher than SB.
Also , Intel s 22nm is actually 26nm.
Piroko
905
79
Ok, I'll change my wording then, IB on 22nm FinFET isn't tuned for higher clocks than SB managed on 32nm. Point in case, I don't expect Haswell to be different in this area and I haven't read otherwise.
Nemesis 1
11,366
What I find interesting are this Ultras that can disconnect from the base and operate wirelessly. Get the right M/B with Wi-Fi and use with your desktop loaded with MS8 .
I see I lot of neat possiabilities for a powerful home base unit . With traditional highend Desktops.
ShintaiDK
20,378
Power use won't be the problem at that TDP, but how to cool that chip.
And the noise, house/room heat etc.
In short, nobody would make a 1000W CPU if power was free and you could cool it for the consumer space.
ShintaiDK
20,378
They dont overheat. And they produce LESS heat. Meaning your laptop should be more comfortable to use than for example a sandy bridge mobile chip. And there is no TIM/IHS on mobile chips.
