Intel processors crashing Unreal engine games (and others)
BFG10K
22,709
3,007
Intel with 12,13,14 generation did EVERYTHING to win benchmarks against AMD, too much voltage, too much heat, no protections (or way too few), too high GHZ (they got that only through too much voltage and heat). They deserve any bad press or sales hits due to this.
This pretty much agrees with what I put in the OP. Both Intel and mobo vendors know exactly what the cause is but they're hoping the issue issue blows over rather than confronting it. They won't dare do anything that risks lowering benchmarks or a class action lawsuit.
Nothing new here, Intel does this every time AMD starts beating them. Industrial water cooler @ Computex, Prescott throttling @ stock, faulty 1.13 GHz P3 recall because it couldn't compile the Linux kernel.
Heck, E-cores are nothing more than Cinebench accelerators specifically designed to win benchmarks because Intel can't compete with real cores. To hell with the people trying to actually use the chips for real work and finding all sorts of scheduling problems with the async design.
The solution? An "Intel accelerator utility" that disables them. You know, for all those other times when you aren't constantly looping Cinebench. :rolleyes:
First reported in February, here we are in April, Intel still "investigating". How come a $161 billion corporation has so much trouble figuring this out when according to some people in this very thread, they've solved it? Just point Papa Gelsinger over here and things should be sorted quickly, amirite?
Ranulf
2,902
2,571
Nvidia recommends consulting Intel if having stability problems with raptorlake in latest gpu driver notes.
Edit to add earlier report that Intel is investigating the issue:
AdamK47
3,630
Not good for Intel. That's what happens when a CPU runs at the ragged edge out of the box.
How much are motherboard manufacturers to blame?
Reactions: spursindonesia
DAPUNISHER
32,312
33,178
Dr. Ian Cutress places most of the blame on them. He explains why in the vid I posted. It amounts to their engineers always pushing the limits for bigger bar better. Of course Intel could squash all of that if they really wanted. I don't think you'll find anyone without a horse in the race that doesn't think they bare some of the blame for at the very least, tacitly allowing their board partners to engage in these practices.
lakedude
2,778
529
Reminds you what... of the days of the Pentium /// 1.0 Ghz CPU? That was later recalled?
Oh man I remember those fire breathers.
My buddy had a 1GHz laptop that may have had a desktop CPU in it, regardless it put out heat like a 1500 watt hair dryer.
I was such a jerk, LOL. I'd take his Coke and put it in the path of the hot exhaust. After maybe 15 minutes the Coke would be undrinkable.
Sometimes he would notice right away but other times that Coke got as warm as coffee or tea.
Mopetar
8,521
7,782
They're selling the board. It's their product. Does Intel say that their boards can't explode and spray acid in a customer's face. Probably not, but would anyone be okay with a board that did that? I think all of this used to go without saying, but it's apparent that now it needs to be said.
No one company will stop because actually staying within specifications means they'll be dead last on a bar graph and that's going to hurt sales. Intel should at least force them to require users flip a switch or type in the power overwhelming cheat code if they want to go lay with fire.
Customers should have to be paranoid about their technology being configured to destroy itself out of the box. As others have pointed out, Intel isn't losing much and if they still really feel they need that last few percentage points, just put it behind a BIOS setting that warns the user and then it's squarely on them.
bononos
3,944
192
Which benchmarks expose this issue directly. From a quick look at the AT benches, Intel seems to be doing ok except for the scientific-simulation computational suite like the 3D particle movement, ONNX runtime, Tensorflow benches. Are they multithreaded benches?
19,208
What do you mean except? Did AT point out that the CPUs got too hot or unstable in these benches?
bononos
3,944
192
I said in simulation and computation benchmarks AMD beats Intel by alot 30-50% even up to 8x in one 3d particle movement bench, wondering if that is because of the e-core architecture.
tamz_msc
3,865
3,730
3DPM is Ian's code optimised by an ex-Intel guy for AVX-512.
19,208
Which review are you referring to by the way? Must be a bit outdated. I think a direct die cooled 14900KS would reduce that lead by quite a bit. Could even turn the tables in non-AVX-512 benchmarks. You do pay too much for that in terms of heat, noise and power consumption though.
DAPUNISHER
32,312
33,178
Bryan says Intel blacklisted him. He goes after LGA 1700 fairly hard for this latest problem and tells his viewers do not buy for any of the higher end CPUs past the 12700K. And he advises turning off e-cores on it. After hearing his story about how he was treated, I'll state yet again - they let the wrong people go during those mass layoffs.
SolidQ
1,540
2,541
ASUS has outed new BIOS with updated settings profile called Intel Baseline Profile.
That's big drop
yottabit
1,671
874
I can confirm Intel has an issue with Unreal Engine games. I played PUBG on a 7600K and the game would run perfect and then introduce lag, latency and what seemed like video driver crashes but would recover. I think it's a CPU issue. I never thought the day would come where an i5 processor would be cut down by such an old game as PUBG. It's been around for 7 years. This reinforces the problem Intel CPU's have with unreal engine games. I hope they fix the problems.
You can’t really go by age with live service games. As an extreme example World of Warcraft in 2004 minimum requirements were a Pentium III 800 MHz. Nowadays it requires a Haswell/Zen quad core @ 3 GHz.
I can still run Half Life v1.0 retail fine on my Pentium 233 MMx but I can’t exactly go install the latest version off Steam and expect that to work.
PUBG specifically has gone through numerous updates including now using a much newer version of Unreal Engine. Each newer version of game engines tends to be a bit more “heavy” and I believe PUBG is currently in the middle of migrating to UE5 so, performance probably isn’t going to get better. Not to mention all the Spectre/Meltdown mitigations and Windows OS updates that have come out since launch. It’s also possible you’re getting some actual hardware related failure due to age of the system
Hitman928
6,751
12,482
Gamers Nexus has commented on it, not much in their actual video but there is some interesting discussion in the comments section.
We obviously have no way to verify this claim or how much volume this SI does to see if it is a significant amount, but GN seems to at least anecdotally confirm based upon viewer reports in a reply.
At this point, it's hard to give any kind of number on percent of CPUs effected, but if you are having this issue, it seems you should make the BIOS adjustments to follow Intel spec and if you are still having issues, RMA your CPU.
S'renne
151
109
86
Does the benchmarks account for data integrity? I know an engineer that regularly compiles full Linux kernels that states AMD is indeed faster than Intel in those workloads, but does not have full precision unlike Intel systems
