Page 92 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
942
858
Wildcat Lake (WCL) Specs
Dies2223
Threads12688
Max Clock5.4 GHz?5 GHz4.8 GHz
L3 Cache12 MB12 MB12 MB
Size96 GB32 GB128 GB
Bandwidth136 GB/s
RTNoNoYESYES
EU / Xe96 EU2 Xe8 Xe4 Xe
Max Clock1.3 GHz?2 GHz2.5 GHz
adroc_thurston
8,665
11,367
TESKATLIPOKA
2,696
3,260
CPU performance uplift will mostly be multicore. Perf/watt much improved.
Even If singlecore sees only 5% improvement, It's not a big deal for me. It's not like AMD has an edge here, at least until Strix Point.
MT is more important here. Raptor was not doing that great in multithread at limited TDP despite having more cores, because of low clocks.
Now It looks like we will see a significant increase in clocks resulting in much better MT at limited TDP.
Then there is still the IGP.
Schmide
5,791
1,094
Finally (to no one in particular), what is up with you folks throwing peak per core power numbers around? That number is kind of meaningless. A single core on a Zen 4 chip may consume 20W, but you will never see it consume 20W in an all-core workload.
A well-designed CPU should be able to scale as much as possible as long as power limits haven’t been reached. If the power limit is 28W there is absolutely nothing wrong with a single core using nearly all of it.
Also, race to idle is a thing. As long as chip a can complete tasks quicker and use less total power than chip b, chip a is the winner, even if chip a peaks at 28W per core vs chip B’s 5-10W per core.
Yeah. Wait ? Are we not supposed to talk about peak per core power like you just did ?
Nothing happens in a vacuum. Different algorithms and data cause different areas of the processor to do work. A large FFT may fill the cache and spill into main memory over and over, while an iterative matrix model may comfortably reside in the L1.
Cores exist in a hierarchy and workloads vary. You can win all categories, some, or none. Even if chip a wins against chip b, there is probably a low power variant of chip a or b that wins the power metric regardless of time. Conversely there is probably a server class chip that takes power to performance to a whole new level, and it sucks at idling.
eek2121
3,491
5,184
They really did!
And it's only just the beginning.
We will see. The source I got the boost clocks from is a reputable one.
Remember these are i5/i7 chips, not i9s.
The Core i7-1370p had a boost clock of 5.2 ghz. The 1360p boosts to just 5.0 ghz.
Intel is positioning Meteor Lake as a premium chip (hence the “ultra” moniker), they would not be doing that unless these parts are beating non “ultra” parts.
Khato
1,387
493
Yeah, MTL performance will definitely be on par or greater than RPL while being more efficient.
It's plausible that notable clock speed regression is with respect to the e-cores rather than p-cores.
msj10
117
121
Peak clocks won’t regress much, if at all over raptor lake. The last I saw these chips would have a peak of around 4.8-4.9ghz, but that has probably changed.
tbh this is still a big regression from the 5.4Ghz in RPL-H
H433x0n
1,224
1,606
He just repeats whatever he sees on Weibo, a classical Chinese tourist in every way possible.
That’s more than I can do since I can’t read mandarin nor access that market. The people I know at Intel have a limited scope of knowledge that’s based around their current project.
Khato
1,387
493
this is total BS and you know it
did he also get this slide from Weibo? lol
Did the full slide get leaked, or just the redacted version with MTL-S removal? Just one little tidbit from an interesting slide.
TESKATLIPOKA
2,696
3,260
It'll hit 5GHz. But certainly MTL won't be noteworthy from a CPU perspective.
We will see when It's released. From 1T I expect the same performance, MT being better. The question is how much better.
4P+8E i7-1360P 30W - 11571 points (100%)
8C16T R7 PRO 6860Z 27W - 11822 points (102%)
6P+8E i7-1370P 30W - 13157 points (114%)
8C16T Ryzen Z1 Extreme 30W - 14960 points (129%)
This is how i7-1360P looks during CB R23 MT.
At 35-40W P-core clocks at ~3.05GHz and E-core at 2.3-2.4GHz.
If 4P+8E MTL at 28-30W can't score at least the same as Phoenix 8C16T, which I consider an equal, then It's really not interesting.
Reactions: Tlh97 and hemedans
mikk
4,333
2,414
This was my expectation but what is the big deal about then? We know since ages that MTL will bring a sidegrade at best when it comes to 1T performance, nobody expects RPL boost clocks. I would expect at least ADL boost clocks though, means at least 5.0 Ghz (i9-12900H). adroc_thurston implies it's really bad like catastrophic. If it hits at least 5 Ghz it's not bad to me.
I expect much better PL1 clocks however because of Intel 4, efficiency is the key there. Otherwise it would be a disappointment...
I don't think so, sorry. You could prove me wrong but I doubt you can.
eek2121
3,491
5,184
This is a P chip. Intel will also rebadge these as H chips.
There is at least one ES chip that reportedly hit 5.4ghz.
The reason I suspect this chip will be a bit of a game changer for Intel is that it is low power. PL1 clocks went up massively to 3.4ghz despite a 28W PL1, and if it does indeed have 2 cores on the SoC, most of the chip can power down during idle/low loads. I could easily see battery life doubling over previous-gen if Intel nails execution.
AMD needs to take a page out of Intel’s book. If they put a couple cores on the Ryzen IOD it would do wonders for idle power consumption.
Nov 8, 2022
43
77
61
Yea a ton of stuff gets shared there.
you have made a ton of grand claims in the last week period, maybe they are right, but i cant verify them, your claims about A20 non existent will be proved or disproved in due time, to early to judge, your claims about having knowledge about Turin is something i cant prove, you made some other bold statements but its hard to prove them or disprove them, however this one accusation you have made is something you should be able to prove right here and right now.
please prove it. link to the weebo slide please?
uzzi38
2,747
6,657
Raichu being a Weibo resident and often just reposts stuff to Twitter has been known for ages now, this isn't some new revelation. I know for sure that I've said as much here before as well.
He does occasionally post slides and stuff that are legit, but there are also times where there are huge misses. What he's said about MTL is one of those cases.
