Page 904 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
Wildcat Lake (WCL) Specs
Intel Raptor Lake UIntel Wildcat Lake 15WIntel Lunar LakeIntel Panther Lake 4+0+4
ModelIntel 150UIntel Core 7 360Core Ultra 7 268VCore Ultra 7 365
Dies2223
Threads12688
Max Clock5.4 GHz4.8 GHz5 GHz4.8 GHz
L3 Cache12 MB6 MB12 MB12 MB
TDP15 - 55 W15 - 35 W17 - 37 W25 - 55 W
Memory128-bit LPDDR5-520064-bit LPDDR5x-7467128-bit LPDDR5x-8533128-bit LPDDR5x-7467
Size96 GB48 GB32 GB128 GB
Bandwidth83 GB/s60 GB/s136 GB/s120 GB/s
RTNoNoYESYES
EU / Xe96 EU2 Xe8 Xe4 Xe
Max Clock1.3 GHz2.6 GHz2 GHz2.5 GHz
NPUGNA 3.017 TOPS48 TOPS49 TOPS
speculate one reason that they keep having these cycles is because they change their CEOs too much. They'd be much better off with a good CEO that stays there for decades, like Jensen.
The Intel Trinity thought differently they allowed everyone to have a chance at Position Rob Noyce/Gordon Moore retired in relatively short time as CEO compared to other folks Andy Grove had health issues.
18AP is ahead of N3P ish closer to N2
Individual transistor performance and clockspeed has broken it's relation a long time ago anyway.
Icelake's 10nm was slower than 10nm SF and Intel 7, but the smaller transistor offered lower capacitance meaning overall lower power. Also according to the 18A presentation it's better performing at 1.1V, then 0.75V. Meaning it does better for desktop and laptop processors, the opposite of what you are saying. That's also confirmed by Intel's presentation that says they won't have "mobile" variants until 18A-P.
Yea and look at Nvidia... and look at Intel.
8% over 18A puts it a hair faster than N3p.
Intel 7 is roughly equal to N7 in drive current. If you extrapolate that out here's what we get:
Intel 7/N7: 1x
Intel 4: 1.2x
Intel 3: 1.18x
18A: 1.15x
1.628x
N5: 1.15
N3E: 1.18
N3P: 1.05
N3X: 1.05
N2P(vs N3E): 1.18x
1.496x for N3X, 1.6x for N2P
18A also achieves 25% gain at 1.1V, which is basically Turbo clocks. It's 18% at 0.75V. The graph says it achieves over 15% over Intel 3.
What's achievable on a transistor level doesn't necessarily scale to clockspeeds at the whole chip level. The better transistors allow you to do other things such as different circuit designs. Intel's 22nm process had great gains over 32nm, especially for Atom with 37% gains. However, with Ivy Bridge, overclock capability degraded noticeably. It took them two years later with Haswell Refresh and 4790K to get better clocks than 32nm.
Intel is fair bit older than Nvidia and yeah they should have chosen a good CEO after Craig Barett last capable CEO before PG but PG didn't actually solved the core problem the rot that infested during PSO-Swan Era
Intel 7/N7: 1x
Intel 4: 1.2x
Intel 3: 1.18x
18A: 1.15x
1.628x
N5: 1.15
N3E: 1.18
N3P: 1.05
N3X: 1.05
N2P(vs N3E): 1.18x
It's not showing up in designs though 18AP is behind N2P
Reactions: DKR
Intel is fair bit older than Nvidia and yeah they should have chosen a good CEO after Craig Barett last capable CEO before PG but PG didn't actually solved the core problem.
Craig made manufacturing strong(his background) but he didn't do good on products. That's why I call him the "sane" Kraznich.
I added the part about 22nm vs 32nm:
It's not that simple as having faster transistors for high clocks anymore. Actually this thinking is a decade late. It stopped after 45nm generation.
What's degraded is Intel's engineering too. When layoffs happen, the hidden parts that really kept everything stable falls apart. That's why they are behind others in memory adoption, or cache latencies and sizes. The "boring" stuff is what matters for a product because the 5-10% is the difference between equal/lose or being at the top.* Arrowlake sucking in games despite having good foundation(Cores), is because it lacks the engineering necessary to smooth out the rough edges. We'll see whether the recent round of layoffs by both Tan and Pat will have such negative impacts in the future.
*I was fascinated with Itanium, and Itanium 2 had fantastic engineering. First chip with a massive on-die cache, that was very fast, and also very compact. The 0.13u successor was amazing in that regard as well. If you go older, their chipsets were usually the top performing. When they went integrated memory controller, they were way ahead of AMD. And IDF always talked about new memory, PCIe, and USB standards, among others. They pushed the industry forward.
Reactions: 511
Intel will use N2P for the higher end desktop parts. That tells me all I need to know in regards to 18A-P (and 18A by extension) clock speed potential, or lack of.
Not sure how I'm misinterpreting this, "begin production ramp of Intel 18A in these products in the first half of '25 for product release in the middle of next year." How should I read that as anything other than exactly what it says?
If you are confused by a long sentence, then you can remove the words that just add flair. For example, "the cat with black and white fur has catnip" can be reduced to "the cat with black and white fur has catnip" or "the cat has catnip". That message is still true. The cat has catnip regardless of the cat's color. But, it is nice extra information to know the cat's color.
Now lets try that with your message.
“Intel's CEO, Pat Gelsinger, has confirmed that the upcoming 18A process of the Panther Lake CPU generation is on schedule for a mid-2025 release, which aligns with the initial projection.”
reduces to
or
“Intel's CEO has confirmed that the upcoming 18A process is on schedule for a mid-2025 release.”
You know, the whole 18A process that Intel tried to sell as a foundry to other companies. Doesn't look like Intel succeeded in that quest. But it was tested by several companies in mid-2025. The new CEO is focusing on 14A for external companies.
I agree that Larrabbee was a failure. But, he should have been reprimanded instead
Why? He obviously had to use x86 for it and nobody in this Universe could have made it work better than custom stuff AMD/Nvidia were doing without any worry for backwards compatibility other than defined software APIs.
Also Many Cores concept from that project came up pretty handy when core counts gone up a lot.
Because Larrabbee did fail. There does need to be some form of punishment. What I am saying is firing was the wrong move.
reduces to
or
Now do that with his actual quote, which I already posted twice, not the butchered one.
"Furthermore, our lead products, Clearwater Forest and Panther Lake are already in fab, and we expect to begin production ramp of Intel 18A in these products in the first half of '25 for product release in the middle of next year.”
They aimed it at HPC where it did score some wins in supercomputers of the time (had problems delivering tho), fundamentally it's failed because Intel brought x86 to a fight that involves custom stuff with no need to maintain backwards compatibility (other than a few APIs), hardly Pat's fault. Pretty sure it was not funded properly too, they (Intel top brass) probably did it to prevent Pat from becoming CEO.
Reactions: 511
You can't eliminate a comma and the word "and" then randomly apply the remaining part of a sentence to the first portion before the comma.
Inventing your own language rules to pretend a company is behind schedule. Weird flex, man. But you do you.
You just eliminated the subject of the sentence to try to twist it to fit what you want it to say, lol. You can keep tilting at windmills, but I think it’s pretty apparent to everyone else what the sentence says.
Now I remember why I stopped posting here much, too many people entrenched in camp a or camp b that they will fight in the weirdest ways to try and make their side not look bad, even over the simplest of things.
It could also be an indictment of the yields (parametric or just working chips) AND capacity that they have on 18a. If they just don't have sufficient yielded capacity to supply the market with their products that use larger CCDs, no matter how "good" 18a might actually be, it may just make business sense to go to TSMC for more capacity.
Arrow Lake I would argue was somewhat of a comeback for Intel. Outside of gaming, Arrow Lake is a very competitive product and truth be told Arrow Lake is acceptable for gaming, it's just that AMD is demonstrably better.
I'm very much looking forward to Nova Lake and Zen 6. Hopefully they will both be successful and we can look forward to these tech giants going head-to-head for a couple more generations before some new paradigm changes the playing field.
I agree.
People like to bash it because of gaming performance, but overall ARL is a pretty good product from a consumer's perspective.
Where I feel it falls short is in the cost to produce it (same for LNL). I suspect Intel is paying a pretty penny for each processor compared to AMD's Zen 5 on N4P.
Reactions: DKR
w
you do realize the part of ARL that is on N3B is Compute tile and the IO/SOC is on N6 which is dirt cheap the N5 iGPU is 23mm2 so the only costly stuff is the compute die and packing is somewhat expensive.
You missed the mark here. AMD and Intel both have great products. I'm one of the few that uses both and supports both. If neutral people make you think they are biased, then you need to look into the mirror to see the bias.
I post here when people make obviously false claims. In this case, it was you that made one.
If you have to delete the subject of a sentence to get it to say what you want it to say, you’re not reading it truthfully.
It's a good product now, after numerous firmware updates and a considerable price drop.
When it launched, the 265K was just ~3% 2% faster than 14700K in Techpowerup's testing (performance in applications, gaming excluded). The worst offender in my book was the poor browser performance, making it slower than a 12700K in Speedometer or Jetstream. The pricing added insult to injury, as it matched the 9900X.
People bash Arrow Lake because it started on the wrong foot and Intel never did manage to shake this bad image.
