Page 790 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
941
857
Wildcat Lake (WCL) Specs
Dies2223
Threads12688
Max Clock5.4 GHz?5 GHz4.8 GHz
L3 Cache12 MB12 MB12 MB
Size96 GB32 GB128 GB
Bandwidth136 GB/s
RTNoNoYESYES
EU / Xe96 EU2 Xe8 Xe4 Xe
Max Clock1.3 GHz?2 GHz2.5 GHz
dullard
26,191
4,856
Nice find Igor.
I wonder how much of this is just due to bumping up power/heat though?
Linux just fixed an Intel power issue (the NPU was never put to sleep and kept using power even when idle): https://www.phoronix.com/news/Linux-6.15-Fix-ARL-U-H-s2idle
As for the desktop Arrow Lake, Phoronix found a 6% speed improvement with a 3% average power reduction. This came from Linux changes putting the software on the proper cores (see the first two graphs here):
Just saying that performance changes and power changes can very well be independent from each other. This is especially true when drivers or the OS are operating a CPU out of the optimum conditions.
Tigerick
941
857
Intel is claiming 20% performance uplift. 4+8+4 we have 16 cores on the same die (18A) compared to 14 main CPU cores
Last year, my source told me Intel was claiming 20% performance uplift compared to ArrowLake H with 6+8+2 cores. Now Intel is claiming similar performance with ARL-H. Well, depending on the final clock speed, I am actually expecting worse performance than ARL-H @ 5.4GHz max. Sure, iGPU will perform faster thanks to TSMC's N3E process with 12 Xe cores but not CPU fabbed by IFS's 18A... :cool:
Come on, how hard could 4+8+4 compute die be made? Turn out very hard for IFS, that's why IFS cancelled 20A process and completely forgotten about 6+8 exists in the roadmap...
511
5,396
4,819
20% MT? Intel claimed LNL efficiency with ARLH MT IDK what that means.
It's just all rumors coming from Taiwan. Also they have a money problem now a very big one when 20A was supposed to ramp. They didn't have money to ramp 🤣.
Tigerick
941
857
Oh, about that slide actually compared to PTL-H and PTL-U series seperately. Thanks to your X links about PTL-H SKUs; what is missing is PTL-U SKUs which are supposed to be released around the same timeframe.
Basically, PTL-U is a ultra-portable SoC with 4P + 4LPe (8 e cores are disabled) and 4XE cores (Intel 3-E). PTL-U are most likely replacing ARL-U but not LNL-MX. LNL-MX is more power efficiency and comes with 8 XE cores.
511
5,396
4,819
I think the marketing is a mess after the 35% cut.
I am not really sure about the CPU part being more efficient than LNL vs 4+0+4 PTL-U the GPU can be but not other parts cause everything is brand new and upgraded in PTL.
511
5,396
4,819
AcrosTinus
221
226
Well I read a serve the home article that says there are 16 DIMM Slots on each side that would mean this is a freaking 16 Channel platform
Wouldn't that throughput be needed for a single socket scale up, like more cores, lanes and even higher PCIe generation ?
Reactions: Io Magnesso
511
5,396
4,819
Yeah it will be there Is also DDR5 12800 MT/s MRDIMMS for DMR delivering 1.63 TB/s Bandwidth!. That's more than 4090 and just less than that of 1.79 TB/s for 5090.
MS_AT
933
1,852
Hopefully most of it will be usable, compared to the Sapphire Rapid HBM fiasco where out of theoretical 1.60TB/s only 700-600GB/s is usable by the CPU. Of course with DDR5 there is also a difference between practical and theoretical BW, but usually it's 70-80%
yuri69
697
1,251
The 2026 AMD Venice is reportedly split between a highend SP7 socket with 16ch and SP8 socket with a lower channel count. So yea, it's expensive but nothing extraordinary for 2026-2027 products.
Reactions: Io Magnesso and 511
511
5,396
4,819
Look what i found looks like something is bottle necking GNR in 2S config i wonder what are the values for 1S.
Zen 6 is 16 channel with DDR5 8000 IIRC so approx 1 TB/s.
AcrosTinus
221
226
Arrow Lake-S refresh coming after all:
They surprised me in a positive and negative sense with Raptor Cove, the gaming improvements from the 12900K were crazy, even a 13600K could surpass it. Can they pull that again, this time without degradation ?
Fjodor2001
4,585
734
i was being sarcastic over the improvement to NPU as intel choose to focus on this. :sweatsmile:
Likely it’s to pass some Microsoft Copilot AI TOPS threshold requirement so they can put a necessary sticker for that on the PC box. Might affect sales if the average Joe is told to look for that when buying a new PC.
Reactions: lightisgood
AcrosTinus
221
226
Not sure why you are expecting magic with the Refresh? It's likely just Arrowlake but 100-200MHz higher clocks.
I am still hoping for some tweaks to the cache like they did with Raptor Lake, It might be cope but 12900K -> 13900K is the gain I am hoping for not 13900K -> 14900K, they have two options to surprise me with.
