Page 780 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
941
857
Wildcat Lake (WCL) Specs
Intel Raptor Lake UIntel Wildcat Lake 15W?Intel Lunar LakeIntel Panther Lake 4+4+4
Dies2223
Threads12688
Max Clock5.4 GHz?5 GHz4.8 GHz
L3 Cache12 MB12 MB12 MB
Size96 GB32 GB128 GB
Bandwidth136 GB/s
RTNoNoYESYES
EU / Xe96 EU2 Xe8 Xe4 Xe
Max Clock1.3 GHz?2 GHz2.5 GHz
Fjodor2001
4,570
730
While I agree that 52 cores seems like a proposition that will only be appealing to a limited number of users, 3D vcache is ALSO a proposition that is only appealing to a limited number of users IMO.
4C 4-ever, since nearly no one will ever need more than that. Used to be Intel™. Now the situation is reversed, so it's 16C 4-ever but AMD™, since 2019.
Reactions: Markfw
gdansk
4,742
8,031
It's 32T thread since 2019 and no one yet has surpassed it. If Intel actually does build >32T consumer processor (on a dual channel platform) I have to wonder what they're smoking.
Fjodor2001
4,570
730
It’s 16C/32T for AMD since 2019, and it was 4C/8T when Intel blocked progress previously with the same reasoning that nearly no consumer would need more than that.
This time it looks like it’ll be Intel that leads the way forward instead of AMD. So funnily enough, the roles are the opposite this time.
gdansk
4,742
8,031
And this time it's true. 4 cores was not ample. Smartphones in the 8T era were 6 or 8C. Smartphones in the 32T are still 6 or 8C. I wonder why. Consumers do not need more than 16 cores. Their workloads aren't atomizable like server farms. They overwhelmingly need faster cores. CPU media transcoding is a niche within a niche. Poor unfortunate C++ developers abusing Boost without a build server are a niche within a niche.
The failure of Intel and AMD isn't spamming more cores (they've done enough of that and they'll continue when shrinks allow). It's a failure of making faster cores. If you value more cores > more 1T performance then there is another market for that.
reb0rn
320
120
I do not agree there is ppl that need more, consumer is not same now what was 6y ago, consumer now is special high end segment
511
5,373
4,781
This is something only time will tell @Hulk will be happy to know that that he can buy a 52 core monster.
dr1337
542
830
Nah, most devs don't have access to build servers and even then a lot of companies straight up don't have resources like that because they're not adobe or oracle. And its much faster for dev work anyways if all your guys can compile independently on their own machines instead of all having to fill the server queue.
Honestly at this rate I want to declare the consumer workload a myth. If you're already comparing PCs to phones in terms of performance, you aren't a PC customer. I find it quite hard to believe you actually have a workload where you're being held back by 1t performance on a modern x86 machine. Unless you're getting paid to run geekbench and your commission is determined by points per watt.
Time is real, just as 4c became obsolete, so will 16c, and so will 32c. Modern operating systems already field thousands of threads, games already can take full advantage of 16-24c CPUs, the compute demand isn't going down thats for sure.
Reactions: Fjodor2001
511
5,373
4,781
I think game devs/content creator would find it attractable or maybe some OEM or Some Intel customer demanded it.
There must be a reason they are making 2*(8+16) also this time there is a lot of reuse with their architecture.
poke01
4,790
6,112
You do know the client web runs on 1t?
Reactions: Kepler_L2 and 511
MS_AT
929
1,848
To be fair, we also need faster cores;) The number of cores can only help so much.
I am, the workload was already mentioned here, it's c++ compilation.
Do you have profiling data to back this up? I am just curious. Also it would be nice to define what full advantage is.
Reactions: Thibsie
alcoholbob
6,390
469
I’m a bit skeptical of this, the engine that uses the most threads that I’m aware of (and is actually CPU heavy) is the newest iteration of Frostbite that uses 14 threads with BF2042. Cyberpunk’s Red engine uses up to 12. Doom’s engine supposedly can break up the workload into 16 but this isn’t really that demanding of a game CPU-wise, so it’s almost a moot point.
All of these will fit neatly into a 9800X3D with 16 threads. You can say having more threads helps in “real world scenarios” if you are running background tasks, but that’s a separate issue.
5,373
4,781
Bruh 52 Cores ain't Targeted for gamers they should Cook big LLC Version for that.
dr1337
542
830
Yeah its called STALKER 2, I had an issue with snipping tool for some reason but it will absolutely load up every thread I have at times, and thats a system wide bottleneck. A 16c CPU would be atleast at 50% and that is pretty utilized if you ask me.
Do you have any profile/data to backup your claim that you're being limited by ST perf with your compiler? Are you sure its not a you problem?
Also while im being gaslit/baited, I should also mention the farce that transcoding isn't relevant. Literally all media on the internet has to be rendered in some form or another and not every task is purely GPU offload-able. And even then, the best GPU encoders lag plenty behind CPU in terms of quality and you aren't going to see many ads or videos posted online that were exclusively encodes with nvidia or intel (let alone AMD) encoders.
Sure in an ideal world 10ghz processors would be a better focus for intel. But in this world, making ICs run that fast is infeasible and frankly I would NEVER prefer a return to the world where intel kept shrinking their 4c designs and increasing profit margins instead of shipping the consumer the same amount of silicon but with more functionality. But hey I guess everyone on this website loves paying more for less.
Addendum: I don't think its an issue that ST is being neglected, like at all. I think all the major CPU fabs focus on it. But for the same reasons mobile beat desktop to 8c are similar to the reason why desktop is ballooning in thread count. Its all in due time and hard limits on what can be done on a single thread. I think if intel could make a CPU that clocks/runs faster much faster they would, but the best any of them can do is increase core count. I mean, even apple is shipping 10c as standard now. Maybe this statement clears up my opinion for some folks.
dr1337
542
830
thats crazy and you know it, nobody here is running a single task at a time if they don't have to. lets get real real, multi-tasking was invented before the multi core processor
Like rly Im in an intel thread and nobody here understands the point of the E cores? lol???
actually on even more thought, I wanna call this bluff
Enough people in this very thread have expressed wishes that intel would have shipped a 12p core product instead of 8+16. Why would that be if 16t were enough? Or maybe most people here already see the implicit benefit of having 12 tightly knit cores instead of having a bunch of threads jumping around. Almost like intel saw the same issue and thats why there are so many e cores now, so that the 8c cluster of P cores can act at full tilt without issue. Same thing would happen with 12p cores only but perhaps not even as good.
LightningZ71
2,673
3,372
I still haven't seen anything that makes me believe that any non-professional or non-prosumer user needs anything more than 4 cores optimized for maximum single thread performance and a fleet of light weight cores to handle background tasks. Heck, I maintain a fleet of Alder Lake 2+8 core laptops and I haven't had a single user come to me with a performance issue that wasn't solved by moving closer to a WAP or rebooting since we got them.
Reactions: CouncilorIrissa
511
5,373
4,781
Video Games(8C16T seems to be fine)
3D rendering?
Game Dev with Unreal Engine?
Compression/Decompression (100s of GB of data )
Reactions: lightmanek
dullard
26,189
4,855
3D rendering?
@511 I guess we have vastly different views of professional and prosumer users. I don't know too many casual users that are doing much 3D rendering, game development, and frequent compression/decompression of 100s of GB of data. To me those exactly summarize professional and prosumer users. I believe that LightningZ71 was referring to office workers on Word/Excel, our parents on Facebook doom scrolling, kids doing homework, people watching a movie, etc.
511
5,373
4,781
Oh damn i misread that 🤣 Yeah for those stuff a 2+8 ADL/RPL SKU is fine
Reactions: dullard
Schmide
5,788
1,092
Maybe if you clean up your darn headers. Compilers are fully threaded and can take advantage of multiple cores. Go find a medium project and compile it. It will take at least a min if not more. I just recompiled wxwidgets and it took 1:40 on an eight core.
