Page 773 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
940
852
Wildcat Lake (WCL) Specs
Intel Raptor Lake UIntel Wildcat Lake 15W?Intel Lunar LakeIntel Panther Lake 4+4+4
Dies2223
Threads12688
Max Clock5.4 GHz?5 GHz4.8 GHz
L3 Cache12 MB12 MB12 MB
Size96 GB32 GB128 GB
Bandwidth136 GB/s
RTNoNoYESYES
EU / Xe96 EU2 Xe8 Xe4 Xe
Max Clock1.3 GHz?2 GHz2.5 GHz
5,340
4,753
I find your lack of faith in AMD copying everything Intel made very disturbing.
You put too much faith in AMD not copying everything anyway this is my last post regarding this there is no point in Further continuing this discussion.
Win2012R2
1,291
1,352
Found a better thing but AMX Down locks heavily as of now.
It does, that's why base freq on Intel server CPUs is so laughably low - it's because they have to declare the worst case scenario, which is running heavy AMX code.
Half pumping won't work around this one, AMD won't touch it with a bargepole, even if they did not have GPUs on offer.
AMX case closed, class dismissed.
511
5,340
4,753
There will be some other way it's up to Intel/AMD Engineers to figure it out.
LightningZ71
2,664
3,358
AMD has something that Intel doesn't, the MIXXX series of AI processors. Intel essentially dead ended Falcon Shores and HAS to have AMX to be able to provide "something" for that space. AMD can sell you an all-in-one unit that is at least hardware competitive. I don't see AMD pushing AMX for Zen 6 and probably not Zen 7 either. They are certainly investigating it, and likely have continency designs ready to go with it if someone comes up with something amazing to use it for, but I don't expect to see if in volume production silicon for a while.
Win2012R2
1,291
1,352
It's already done and called GPUs. AMD just needs to figure out how to get CUDA compatibility working, APIs are not copyrightable, they should do clean room implementation that runs very well on their hardware.
Reactions: reb0rn and 511
dullard
26,187
4,853
See my discussion above. How will Nova Lake compete in the general desktop and laptop markets with such an expensive platform?
1) I personally don't see the 52 core Nova Lake in the general desktop and laptop markets. That will likely be the single chip 26 core Nova Lake. To me, the 52 core is intended for the workstation class.
2) You already know DDR6 prices? If so, please inform us. Since it is 4 channels within the same memory module, there could be fewer motherboard parts needed.
Reactions: GTracing
511
5,340
4,753
i think they will be willing to sell it to desktop just at $1000-1200 which is a fair price imo for so many cores.
Abwx
11,995
4,952
Typical cheap approach from AMD, very much same attitude taken with ray tracing.
The cheap approach was actualy Intel s one.
One advantage of 3DNow! is that it is possible to add or multiply the two numbers that are stored in the same register. With SSE, each number can only be combined with a number in the same position in another register. This capability, known as horizontal in Intel terminology, was the major addition to the SSE3 instruction set.
3DNow and SSE are totally different. 3DNow acts on the MMX registers, which are in turn aliased on the x87 registers, and only uses 64 bit vectors. It also inherited all the MMX problems of mixing with x87 code. SSE introduces completely new 128 bit vector registers separate from the x87 ones. It's a completely different (and better) instruction set.
Better.?
Read the above.
Win2012R2
1,291
1,352
It was cheap because of bad reuse of registers, same cheap approach they use for ray tracing.
Intel created something new that had far more success and in later revision improved what they had with the minor improvement AMD created, as we all know 3DNow! died a death such a long time ago, where as Intel stuff is the baseline that kept for a many years, only until very recently AVX2 finally became new baseline.
Abwx
11,995
4,952
So good that SSE2 has to be released 2-3 years later because SSE was just a stop gap, indeed 3Dnow brought way more perfs to AMD than SSE did for Intel.
Win2012R2
1,291
1,352
Yes, great, it had revisions, just like original AVX was rubbish, but got pretty good with AVX2 - they made good basement with bigger registers, that wasn't cheap - future oriented good effort.
It wasn't a cheap effort like AMDs, which was also dead end - what could possible be done further with MMX registers given issues with x87? AMD understood it pretty quickly and moved to SSE, it was far superior long term solution that can be built upon, probably cost a few extra bucks in silicon though.
Abwx
11,995
4,952
They moved to SSE exlusively because of Intel s market dominance, that s the only
reason, because software wise 3Dnow and later 3Dnow! Pro were more convenient
than SSE.
inquiss
617
875
Why would they? Then they would be beholden to Nvidia changing what cuda does over time and then always being gens behind.
GPU agnostic languages are growing anyway. What's the point?
inquiss
617
875
Agreed on point 1.
Point 2...look at any new memory standard introduced....low volume initially with very high prices. Don't need a crystal balls here
Reactions: 511
Win2012R2
1,291
1,352
Why would they?
Enables lots and lots of software to run NOW without changes, then add your own extentions to speed some stuff up if it's done better.
They moved to SSE exlusively because of Intel s market dominance, that s the onlyreason, because software wise 3Dnow and later 3Dnow! Pro were more convenient than SSE.
They moved because ops over 128 bits will beat 64 bits big time, plus it was terrible cheap choice to reuse registers for MMX, writing it was highly undesirable. Yes good thing Intel was dominant AND forward looking at the time, otherwise we'd still use MMX.
Schmide
5,786
1,085
They were so dominate they had to use artificial means to keep their dominance.
