Page 735 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
942
857
Wildcat Lake (WCL) Specs
Dies2223
Threads12688
Max Clock5.4 GHz?5 GHz4.8 GHz
L3 Cache12 MB12 MB12 MB
Size96 GB32 GB128 GB
Bandwidth136 GB/s
RTNoNoYESYES
EU / Xe96 EU2 Xe8 Xe4 Xe
Max Clock1.3 GHz?2 GHz2.5 GHz
DavidC1
2,177
3,328
there hasn't been one CEO like that since the O.G. Trinity they were humble
I speculate once a reign of a fantastic CEO is over, all his bad traits essentially get carried over to the future yet the company doesn't abandon it because it was established as a foundation. Such warts and problems with the fantastic CEO works for *him* because it's counteracted by his good qualities and the way he runs the business, but once he's gone, then it's all negative.
The reason I say this is Intel is internally competitive to the point of being detrimental to the operation. The top team is all about squashing everyone that threatens them. It sounds very much like part of Andy Grove's character, a bit of a flaw that got carried into the future. I read an account where Grove wanted to basically stomp competition(AMD) by pricing them out and Moore prevented him from doing so.
511
5,435
4,861
Yes I am not surprised Huang feared that Intel too brutal and cut throat. Gordon and Noyce were Humble it's sad such great people don't run business anymore 🥹
19,217
The best CEO is one who has all the potential but never really was a CEO.
Jim Keller
His company seems to be doing fine. But being CEO of Tenstorrent is kinda like being the CEO of a chain of stores in comparison to giants like AMD, Nvidia and former giant Intel. His skills are being under-utilized.
511
5,435
4,861
Jim Keller
yeah he is a good candidate
btw
Best ARL CPU?
mikk
4,333
2,413
I said on package memory(not enough alone but LNL has PHY optimizations) alone is enough for 0.5-1W reduction which is substantial.
20-30% reduction makes it closer to Meteorlake than Lunarlake, and that's a huge amount. You are going from 15 hours to 10-12 hours.
Did you see the power comparisons from video playback workloads between Lunar Lake and Meteor Lake? It was like 5-6W on LNL versus 10+ watts on Meteor Lake. This is coming from the much stronger LPE core cluster integrated into the compute tile. They can shut down the ringbus cores for many more workloads, this is the real big deal. Darkmont might be a few percent faster than Skymont. In many workloads the LPE cluster should be fast enough. This is not doable on MTL or ARL, even though ARL seems much better under full load thanks to N3B and LNC+Skymont. Under light load however no chance against LNL and for sure PTL.
OneEng2
1,004
1,207
It is a nice architectural enhancement IMO.
Using a 3rd tier of processors (LPE) for the lightest of loads for good battery life ..... not a bad idea at all. This (as you point out) allows them to completely shut down the ring bus under these conditions.
DavidC1
2,177
3,328
This is in theory, which didn't work well at all for Meteorlake in practice. Intel themselves showed a mere 0.15W savings, which is minutes. I don't know how that video justified itself.
Also 5W and 10W is extremely high for a video playback workload. My Kabylake is under 4.5W while in Youtube playback, so what happened to the 10W system?
There's a huge difference between Lunar and Panther, and that LPE is on another tile. Data needs to be handed off to the LPE before the compute can be turned off, thus there will be a brief period when both tiles are on. If the turn on/off is too slow, you potentially have a scenario where you are better off not having LPE at all.
LightningZ71
2,691
3,390
I wonder if the more performant and efficient Arrow lake-U (meteor lake u refresh) has a notably improved power profile than OG Meteor Lake? It seems that it should do better in race to idle and in light load situations. Intel 3 may not be night and day better than 4, but it IS an improvement.
DavidC1
2,177
3,328
It can't be worse, can it? It at least clocks significantly higher.
I initially was expecting much more from Foveros regarding latency and power. Maybe some of the disappointment is due to their lack of execution, but products seem to speak for themselves. Lakefield wasn't anything special, neither was Ponte Vecchio, nor Meteorlake.
The fact that there are multiple successors and with big changes to original Foveros suggest there's a way to go before coming even close to fulfilling original promises - disaggregation while minimizing penalty.
DavidC1
2,177
3,328
You know their insistence on having just 2 years for platform support is very short sighted.
I think if you look at their dGPU marketshare, it's probably closer to 50/50 split versus 80/20 for their whole client CPU share. With AMD if you have an old enough CPU to seriously bottleneck ARC, you could simply just swap out the CPU, a much better value proposition. AMD CPUs may be "saving" Intel's GPU.
Also, markets with upgradeability shows much more resilience in times of difficulty, because it's much cheaper. That's why notebooks drop far more during times of recession than do desktops.
The whole needing to swap entire platform to upgrade is in line with the mindset of using debt to fuel purchases. When it crashes, it will crash HARD.
511
5,435
4,861
Yes I want to see it as well btw I3 has a huge leakage improvement vs Intel 4 so it should be better rest is up to benchmark
