Page 720 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
942
857
Wildcat Lake (WCL) Specs
Dies2223
Threads12688
Max Clock5.4 GHz?5 GHz4.8 GHz
L3 Cache12 MB12 MB12 MB
Size96 GB32 GB128 GB
Bandwidth136 GB/s
RTNoNoYESYES
EU / Xe96 EU2 Xe8 Xe4 Xe
Max Clock1.3 GHz?2 GHz2.5 GHz
ajsdkflsdjfio
185
133
The whole "death of x86" argument is really missing the forest for the trees. Noone is seriously arguing that x86 will cease to exist anywhere in the near future. x86 will live on in some form or another for many decades to come.
Someone else in this thread said ARM was "only" 10% of the client laptop market....as if ARM going from 0% to 10% marketshare in just 4 years in one of x86's last (of 2) markets isn't fairly remarkable growth.
I think you are the one missing the forest for the trees. You do realize that the 10% client laptop market is due to apple alone right? There are no other viable competitors using ARM and there have been multiple attempts to bring ARM to pc including Qualcomm's recent attempt which have all ended up in complete failure.
People switched from x86 to ARM because Mac/MacOS itself changed to ARM. They also got a nice performance boost with it as well, but who's to say whether that's ARM or Apple's design team. Regardless, they could have gotten a 0% performance boost over contemporary x86 and still have gotten 5-10% of the laptop market to switch to ARM.
The problem isn't ARM taking over, it's Apple taking over with their chips or some other player like Nvidia even. But so far I don't see that happening either since apple mainly plays it's own game in the corner. They rapidly shifted their portion of the market to ARM but I don't see them converting a large portion of the market anytime soon.
Also, AMD and Intel laptop chips are closer than they ever have been to apple since the M-series chips first debuted and I don't see this gap widening as recent competition between Intel and AMD have spurred rapid innovation between the two in addition to the fact that both AMD and Intel seem to be putting more focus in laptop chips than ever before. I mean look at lunar lake, meteor lake, hawk point, strix point, strix point HALO. They all saw Apple's success with their SOC designs and are looking to replicate that success.
CouncilorIrissa
788
2,855
You do realsiy it is a bug in windows power plan which is causing this ona ASUS laptop? cause it is not even boosting to its peak
It's not a bug, it's intentional. Without limiting boost clocks LNL wouldn't have any battery life to boast about (other than when idling -- PMIC helps with that a lot)
It's reproducible on Lenovo as well.
And Acer laptops.
511
5,457
4,886
GPU isn't getting overclocked. Never heard of memory overclocking causing issues with a Ryzen APU. This is one more problem for Intel.
I don't think oc memory issues can be blamed on Manufacturers if it was stock it would be an issues it's not stock it's your own fault neither AMD/Nvidia or Intel will do anything regards to it it can be soem some driver problem as well cause.
Manufacture warrant is for stock settings
And Acer laptops.
You can watch this he tested it unplugged even phoronix had issues with LNL
CouncilorIrissa
788
2,855
I don't think oc memory issues can be blamed on Manufacturers if it was stock it would be an issues it's not stock it's your own fault neither AMD/Nvidia or Intel will do anything regards to it or maybe some driver problem cause according to manufacture it's not their stock setting
Thanks for proving my point: on 1:24 he sets the power profile to High Performance, which is what I said in the earlier post.
The battery life tests are done on Balanced, but performance is measured on High Performance. Different amount of work done, different performance.
A quick sanity check: you can't have 15 hours of battery life from a 55Wh battery if your device boosts to 17-18w in 1t workloads (which is what will happen once you run a web browser, or Discord, or Slack, or any other Electron-based / PWA app), period.
511
5,457
4,886
You have to sustain 17W for a hour to drain a considerable amount for a few seconds it won't matter much as for high performance i didn't notice that it happened on linux as well with Phoronix this is certainly a bug imo unless someone officially confirms it
CouncilorIrissa
788
2,855
You severely underestimate the amount of time web pages spend being re-rendered. They will keep your CPU busy.
poke01
4,873
6,202
Speedometer also seems to be very finicky even varying by +-10% based on the browser you are using. In the first place it seems to heavily favor apple even in scenarios where their CPUs are actually weaker than their competitors
This benchmark seems to like specific high IPC and high cache designs.
desktop raptor-lake and zen4 owners report and you see that there is clearly something different about MacOS that causes speedometer to perform better
Speedometer doesn’t favour any OS,
See 8 Elite Android scores , it’s on par with A18 Pro.
This was around the typical score I found for zen4 AMD users and it's still on par/weaker than my M1 Macbook air which has around a 10-20% weaker 1T performance and much slower ram among other things.
This is a Zen4 desktop with a very large L3 cache. Cache also plays a role but so do clocks.
Desktop Zen5 scores even higher, especially if you tune it.
But this is irrelevant to the fact that these benchmarks themselves are flawed for a CPU to CPU comparison. Pugetbench is also heavily reliant upon the GPU and therefore will have its scores differ significantly even on the same CPU using different GPUs. With the M3 chip having around a 20% stronger GPU, the Puget bench scores you referenced aren't reliable.
This is the Photoshop benchmark, it barely uses the GPU. It’s more of a CPU benchmark.
I understand that, my point was that speedometer having a better result for meteor lake compared to Strix Point doesn't really give much creedence to the accuracy or usefulness of that benchmarking program. Zen5 mobile was obviously nerfed vs desktop, but so is meteor lake which is a trash and older product regardless. The HX 370 has around a 20-30% 1T performance lead over the 185H and is monolithic to boot.
Strix point doesn’t perform well in web benchmarks and it’s not the only benchmark to be behind in. Jetstream 2.0 is the same.
MTL 155H is better than Strix point HX 370 here. So the 185H being better in Speedometer 3.0 isn’t an anomaly.
5,457
4,886
This just in:
Intel Core Ultra 9 285H Geekbench scores have leaked. And it beats AMD top-end mobile offerings
(AMD Ryzen AI 9 HX 370 & HX 375) by a mile!
And this is just the mainstream H series. The top-end HX series should totally blow the competition out of the water!
Arrow Lake mobile series appears to be very strong!
Only if we knew the Power consumption hoping it's 45W
Reactions: ajsdkflsdjfio
LightningZ71
2,694
3,394
This just in:
Intel Core Ultra 9 285H Geekbench scores have leaked. And it beats AMD top-end mobile offerings (AMD Ryzen AI 9 HX 370 & HX 375) by a mile!
Arrow Lake mobile series appears to be very very strong!
I'm not shocked that it's beating Strix Point. That's effectively a desktop processor vs. a mobile first. It'll be interesting to see how it does against Fire Range.
LightningZ71
2,694
3,394
Fire range should span from single CCD parts with as few as 6 cores to dual CCD parts with up to 16 cores. I'm looking forward to the test results. AMD has a variety of SKUs for customers with different needs.
511
5,457
4,886
They will be up against ARL-HX in laptop i am pretty sure ARL is going to win due to the limited power/thermals
