Page 68 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
911
829
Dies2221
Threads8688
Max Clock3.8 GHz?5 GHz
L3 Cache6 MB?12 MB
TDP7 WFanless ?17 WFanless
Size16 GB?32 GB24 GB ?
EU / Xe32 EU2 Xe8 Xe12
Max Clock1.25 GHz2 GHz
NPUNA18 TOPS48 TOPS100 TOPS ?
eek2121
3,441
5,094
"GPU and other bits" is the majority of the silicon, if you ignore the base die. There's >100mm2 of N6, and another good chunk of N5. That cost is going to dwarf the compute die.
Of course it will, but the entire package will still cost less than it costs AMD for a typical Zen 4 chip.
BorisTheBlade82
721
1,148
MLID becoming more realistic with the claimed IPC improvements in Meteor Lake? Now he says MTL gains "up to" 10% over RPL-R with some tests in the mid single digits range. It's more realistic right?
There are some other claims. Current boost speed projections are 5.2 Ghz for 28W and 5.4 Ghz for 45W. Another claim: MTL is projected to consume 30-45% less energy than RPL-R at same performance below 45W and it launches between August-October.
As for Arrow Lake he says that both mobile and desktop will launch in Q4 2024. Mobile uses 20A whereas desktop uses TSMC N3+N3E. Recent 6+8 vs 6+8 benchmarks show ARL with 30% higher ST and 40% higher mixed average over MTL.
Yep, regarding MTL that sounds much more down to earth.
Geddagod
1,591
1,657
10% might still be a bit high, but then again he did say it was "up to" and avrg was single digits, so ye seems alright.
Funny though, he claims it's because RWC didn't reach expected IPC targets. Uh huh.
5.4 GHz ST max is reasonable imo. A good sign even for the node considering Intel's 'new' nodes max ST frequency went down for both 14 and 10nm.
30-45% less energy for the same performance is also a reasonable estimate I suppose. To put it into perspective, TGL vs CML was a ~25-30% gain (8c parts).
ARL 2H 2024 should be expected. Intel confirmed ARL is hitting their launch by 2024 timeline. Depending on how TSMC N3 is, they might even push for a 2Q launch to be able to compete against Zen 5 as soon as possible.
I would be a bit surprised about how they are benchmarking ARL right now. I expect ARL to just have been turned on, and maybe Intel announced that in a couple days during their Intel vision event. I also expect clocks to be pretty low right now, so unless they are clock-equalized I don't see how ARL is beating out MTL chips already by such large margins.
Geddagod
1,591
1,657
Also just want to add it would be funny if his IPC estimates for GNR is accurate because it uses LNC lol
Hulk
3,839
I watched that MLID video and actually I think everything he said regarding the Intel timeline and expectations are relatively reasonable. Also the timeline actually makes sense from the perspective of where each part fits into the stack. Specifically why Raptor Refresh will exist and how MTL/ARL compatibility will spur more MTL design wins that it would purely based on out of the box performance.
However I don't think ARL will show 30% IPC, more like 20%. Also RPL-R single core clocks are meaningless except for the fact that nC clocks can be inferred from them. So 6.2GHz from the refresh could mean 5.8GHc nC. 25% power reduction from Raptor to Raptor Refresh at ISO frequency would be nice if true but I'm having a hard time believing that as well.
H433x0n
1,224
1,606
Let's give Intel the benefit of the doubt and wet our floors with ample amount of drool.
30-40% (not 30-40% IPC) performance gains isn’t that crazy, it’s happened multiple times on a big node jump. Just look at Golden Cove from Skylake era. Zen 3 was a 30-40% performance jump in some tasks too.
Anhiel
61
Now, these raw and undiluted data points look... perfect. Roughly 2x2% off from my own estimations posted before.
Things've only changed for MTL but not really ARL. It's a ladder system of dependencies so things do carry over.
Either way, it gives a clearer picture, yet, these perfect numbers make me wary of the last time perfect numbers became a disaster. I'm leaning toward these being more reliable judging by how so many fall into place now.
But there seems to be one contradiction here with Intel's measurement. Welp, I'll leave it at that.
Anyhow, it seems ARL will come with L4 die with backside power delivery. This is probably the biggest change in metric from before. Welp, currently this won't count practically yet other than for games or large data sets etc.
Since this only slightly differ from before my earlier conclusion remain the same.
eek2121
3,441
5,094
Not in a single generation. Did you forget Rocket/Tiger Lake? Also, Zen 3 had both an IPC and clock speed advantage.
Meteor Lake consuming 40% less power is a given. It is on a smaller process. The question is whether Intel focuses on perf/watt moving forward. Their latest chips are incredibly inefficient. If they can pull off another Core 2 they will be able to turn things around.
Reactions: A///
H433x0n
1,224
1,606
Going from Comet Lake -> Alder Lake is roughly equivalent of what we’d be getting with Raptor Lake -> Arrow Lake (with MTL being that intermediate step).
That was a sizable jump from April 2020 to November 2021.
soresu
4,187
3,661
Past events have shown us that no matter competitive AMD HW is at any given time that Intel has zero problems getting design wins one way or another.
What they can't get through HW merit they get through contra revenue strategies, because they have the extreme financial grunt to do so, while AMD has never really been in the position to play that card, and likely never will at this point unless Intel somehow makes a truly catastrophic misstep.
soresu
4,187
3,661
Intel doesn't do that anymore
You are only fooling yourself if you believe that.
They've been doing it from day one in the Chromebook market.
Doesn't it strike you as odd that so few ARM based Chromebooks exist by comparison?
The reason is very simple - Intel priced most of the ARM vendors out of the market.
They might not be pricing as aggressively in periods where no ARM vendors are making an effort, but you can bet that they are doing it the moment Qualcomm or Mediatek start making announcements to that effect.
This is especially obvious given the fact that Chrome OS supports Android apps which overwhelmingly work better on ARM CPUs due to ARM's near total dominance of the Android device market.
jpiniero
16,987
7,387
It's tough to compete with a fully depreciated fab in a market where performance doesn't matter. Esp with products fabbed at TSMC, given the high prices.
Even 10 nm, with nobody wanting Sapphire Rapids, there should be plenty of fab time to pump out cheap Jasper Lake and still be profitable.
Reactions: Ajay and Hulk
soresu
4,187
3,661
That too, but it's only part of the problem.
You can't effectively compete with a player willing to sacrifice most of the profits to keep competitors out of the game completely - not unless you have deep pockets of your own, or an entrenched starting position as the ARM vendors had with the Android segments.
soresu
4,187
3,661
Tiger Lake? Not sure I understand what you're saying here...
I'm gonna go out on a limb and assume they are referring to Intel's big Little/P+E implementation using Cove/Mont cores.
Arguably Intel owned themselves as much as anyone else by disabling the AVX512 feature with ADL that they had spent years touting despite it's throttling issues - thus removing a performance feature that many software devs had specifically coded for even in the consumer market.
One step forward, 2 steps back 😅
coercitiv
7,443
17,731
No, he's referring to TGL. There's still an abundance of cheap TGL machines on the market. That's not that big of impediment for AMD though, as their product mix still contains many Lucienne, Cezanne and Barcelo products, some of which are directly priced against TGL laptops. The situation is similar to desktop, where AM4 is still around.
On top of that, ADL can also come pretty cheap in some machines, suggesting Intel is indeed attempting to fill the channel with discounted silicon.
Reactions: soresu
eek2121
3,441
5,094
Hey, Tiger Lake isn’t a bad chip. If they had been able to push that out on desktop instead of Rocket Lake, AMD would have had a harder time winning marketshare.
Reactions: BorisTheBlade82
coercitiv
7,443
17,731
I was just implying that flooding the market with cheap tiger lake chips isn’t necessarily a bad thing.
For consumers it's nice. For Intel folk... debatable.
Very unfortunate news, but massive layoffs at Intel coming! Intel's Datacenter and Client computing groups are receiving ~10% budget cuts It's up to divisions to figure out how to cut Given fixed costs, means as much as 20% layoffs in groups LTD (process node) unaffected
Geddagod
1,591
1,657
Well, more evidence of the 'unlimited budget' given to the fab side.
I mean everyone (especially the people working there) should hope this rumor is false, but if it is...
I do hope they don't cut out engineers and instead more of the bloated management I hear often when people talk about Intel.
I also hope the cuts come more out of the client side, considering that client, tbh, has been doing much better than what server has been able to do. Seems like it would hurt less if the cuts come out of client.
However this seems like especially poor timing as well when you consider Intel has diverged into big and little cores, sounds like a lot more work supporting two archs in many skus. However the move to chiplets in client, where you can have a lot of design reuse, could also reduce total engineering hours needed for a new product.
