Page 67 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
940
851
Wildcat Lake (WCL) Specs
Intel Raptor Lake UIntel Wildcat Lake 15W?Intel Lunar LakeIntel Panther Lake 4+4+4
Dies2223
Threads12688
Max Clock5.4 GHz?5 GHz4.8 GHz
L3 Cache12 MB12 MB12 MB
Size96 GB32 GB128 GB
Bandwidth136 GB/s
RTNoNoYESYES
EU / Xe96 EU2 Xe8 Xe4 Xe
Max Clock1.3 GHz?2 GHz2.5 GHz
A///
4,351
3,160
Sounds like a load of dookey to me.
in case it isn't obvious dookey was being sarcastic. amd has managed to screw themselves lately. must be one of them modern kinks.
Reactions: DooKey
coercitiv
7,462
17,810
Here we go, we're getting another rebrand apparently. I'm having an allergic reaction already, but I guess I'll reserve judgement for the launch day when they'll have to use the new branding during keynotes.
Later edit: at least it's not as bad as “Intel Processor:p
19,209
If they are going with that branding, it means MTL is definitely going to offer a performance uplift. 10%? 15%? 20%? Place your bets, folks :p
eek2121
3,471
5,145
MTL: Intel Core Ultra 3/5/7 1xxxH
RPL-R: Intel Core 3/5/7 1xxxH
Yeah I hate this new naming scheme too, thanks for asking.
Having ultra before 3/5/7 is odd to me.
Also, more indications that Intel 4/3 is in good shape and Intel expects to increase capacity quickly….that or they expect much lower sales volume moving forward. 🤣
By adding “Ultra” to the name, it means they can roll out more SKUs as capacity allows, so I am not totally against it. It also means they can demand a premium over non-Ultra SKUs.
Things are going to get interesting. Hopefully AMD will have something to compete.
DrMrLordX
23,173
13,259
It just means they can mix Raptor Lake and Meteor Lake in the same CPU generation while letting people know the difference (sort of).
mikk
4,328
2,410
According to Bionic_squash Raptor refresh won't get the Ultra naming. Also Intel confirmed the brand change for Meteor Lake.
  • Love
Reactions: Elfear
Hougy
Will "Intel Processor" still happen or did they change their minds?
DrMrLordX
23,173
13,259
Yup, that's what I figured. Which isn't a terrible idea, though if the Raptor Lake Refresh chips wind up being faster in some cases than the Meteor Lake CPUs (which will likely be the case, at least if Intel releases "desktop" Meteor Lake), it could lead to some confusion.
But at least we know which products are retreads.
coercitiv
7,462
17,810
Based on what we know so far via leaks, MTL-S will use a different socket, the new 800 series chipsets, and will be DDR5 only. At the same time, we know RPL-S Refresh will still use 700 series chipsets.
My take is MTL will share the same timeline with RPL in mobile, but on the desktop I think it will share timeline with ARL. I don't see a place for Raptor on the new socket unless ARL gets stuck in traffic.
ondma
3,319
1,708
I dont really see AMD having a problem with competing. I would look at it as hoping MTL can catch up to AMD in efficiency for mobile. I dont see MTL giving Intel a lead in desktop, although it might make them more competitive in efficiency. Hopefully, ARL will be good boost for desktop, but it will at some point compete with Zen 5.
jpiniero
17,121
7,512
I am wondering about pricing... given how expensive TSMC is. OEMs might actually like having new Raptor Refresh models if the pricing is going to be ugly.
Reactions: Exist50
DrMrLordX
23,173
13,259
They'll definitely like having more Raptor Lake SKUs to fill in the spots currently occupied by Alder Lake.
eek2121
3,471
5,145
Given that TSMC is only used for GPU and other bits, likely won’t change much. The compute tiles are on Intel 4.
The only reasons TSMC is involved at all are that the GPU IP was always TSMC and it would take work to port it over, and also Intel is currently still limited in capacity until later this year/early next year.
Exist50
2,452
3,106
"GPU and other bits" is the majority of the silicon, if you ignore the base die. There's >100mm2 of N6, and another good chunk of N5. That cost is going to dwarf the compute die.
mikk
4,328
2,410
MLID becoming more realistic with the claimed IPC improvements in Meteor Lake? Now he says MTL gains "up to" 10% over RPL-R with some tests in the mid single digits range. It's more realistic right?
There are some other claims. Current boost speed projections are 5.2 Ghz for 28W and 5.4 Ghz for 45W. Another claim: MTL is projected to consume 30-45% less energy than RPL-R at same performance below 45W and it launches between August-October.
As for Arrow Lake he says that both mobile and desktop will launch in Q4 2024. Mobile uses 20A whereas desktop uses TSMC N3+N3E. Recent 6+8 vs 6+8 benchmarks show ARL with 30% higher ST and 40% higher mixed average over MTL.
Thunder 57
4,245
7,040
I don't know why people still listen to that guy but ~10% sounds fair. I certainly do not expect ARL to hit 30-40%. That is just a huge amount that we don't see anymore. Zen hit above that but largely because it was compared to a very lackluster design on an ancient node. I can't think of anything else in recent memory that got that much over its predecessor.
mikk
4,328
2,410
I believe we will see bigger gains. The lead architect last year told "in the coming years you will see Raptor Lake and Meteor Lake and then you will see bigger and bigger jumps"
Once Arrow Lake hits the market there are 3 years between Golden Cove and the next big Cove upgrade Lion Cove. It makes it easier to achieve something bigger combined with newer process nodes. Meteor Lake is more like a tick upgrade similar to Broadwell, although the platform changes are big and 30-45% less energy than RPL-R would be huge for the mobile market.
