Page 650 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
Wildcat Lake (WCL) Specs
Intel Raptor Lake UIntel Wildcat Lake 15WIntel Lunar LakeIntel Panther Lake 4+0+4
ModelIntel 150UIntel Core 7 360Core Ultra 7 268VCore Ultra 7 365
Dies2223
Threads12688
Max Clock5.4 GHz4.8 GHz5 GHz4.8 GHz
L3 Cache12 MB6 MB12 MB12 MB
TDP15 - 55 W15 - 35 W17 - 37 W25 - 55 W
Memory128-bit LPDDR5-520064-bit LPDDR5x-7467128-bit LPDDR5x-8533128-bit LPDDR5x-7467
Size96 GB48 GB32 GB128 GB
Bandwidth83 GB/s60 GB/s136 GB/s120 GB/s
RTNoNoYESYES
EU / Xe96 EU2 Xe8 Xe4 Xe
Max Clock1.3 GHz2.6 GHz2 GHz2.5 GHz
NPUGNA 3.017 TOPS48 TOPS49 TOPS
Would this be a decent option if I were to switch teams? I'm staying with mATX due to the fact that I have a case I really like that fits under my desk.
You see, my 1.3V underclock on my 14900K is not stable anymore so I downloaded the Intel microcode BIOS update. Yeah it's stable now but taking in quite a lot of volts and I've lost 300-400MHz at the same 200W I used to run at.
I think I'm done with Raptor Lake. I want to try a 9950X.
Probably throw a 7800XT or 4700 GPU in there as well. I don't game much but like the GPU power for other tasks.
I have one from the TUF series. While I like MicroATX, I wanted to get one with PCIe Gen5, so I went with TUF x670E, which is an ATX (for a few extra bucks)
The Gen 4 you are looking at is fine for the GPUs you are considering, but apparently, next gen graphics cards will be PCIe Gen 5.
The board you linked does have a PCIe Gen5 M.2 which is good, so with either one of those 2 GPUs it's probably just fine.
One of the nice things with this board are all the analog audio outputs - if you have a multi-speaker audio system...
In HWU testing, 7800X3D is already 20% faster than 285K, though, admittedly with RTX 4090. So unless the testing is radically different, this is really not good news for 9800X3D if these numbers are true. Many people expect like 10% gaming delta on average between 7800X3D and 9800X3D and that's probably not going to happen.
I expect the big jump isn't going to be just the out of box 9800X3D over 7800X3D (as you point out likely ~10% give or take), but rather the ability to clock higher and tweak it to levels more like 20%.
Only a few more days and we will know.
That's true. Just thinking they have the high clocks and probably good yields in Intel 7.
Honestly even Raptor Cove paired with Skymont on monolithic might have been a better option than ARL as we have it now. ST would have remained the same but MT would have gone through the roof with just a little larger die area.
ARL on Intel 7 would've been a disaster. The cores would've been monstrously large and power hungry. Intel learned their lesson with RKL to not backport to an old node.
Not to mention how much LNL changed with new industry standard PDKs and designs. Intel 7 is old. DTCO'd a lot for ADL/RPL requirements.
Intel 3 monolithic would've been the choice if they wanted both in house and monolithic.
Intel 3 wasn't even certain upto a point also one of the engineer said they are happy with Intel 3 and how it turned out
Yes I agree, I changed my opinion. I was thinking Raptor Lake with Skymont instead of Gracemont, still on Intel 7.
Avoid the Lion Cove fiasco and having to go out to TSMC.
The only great tech Intel has produced lately is Skymont.
Anyway, "coulda, shoulda, woulda" is for kids. So it's pointless to look back.
Lion Cove & Skymont use industry standard design tools that are compatible with Intel 20A/18A/TSMC/etc. Hence LNC & Skymont aren't backward compatible with Intel 7/4/3 which still use (proprietary) in-house design tools.
Intel 3 was being offered as an IFS offering, so they must have some level of industry standard tool support, though maybe it is a bit lacking/incomplete as no outside companies showed interest in using it.
Pat originally said there would be external users to Intel 4/3 but quietly stop talking about it and is only talking about 18A now.
Yeah, there were some customers who "kicked the tires" on Intel 3, but no actual takers (none of any significance at least). If they can get the price down, maybe they'll attract some future customers who stay a few nodes back from the leading edge, but it's doubtful.
Pat has a tendency of acting like customer engagements (i.e., potential customers) are actual customers (i.e., signed agreements / purchase orders). He did the same thing with Gaudi.
I'll refrain from more comments, but just wanted to add, that from my experience building AM5 rigs, the best kit out there for OOtB timings (at least for the 7-series) in terms of bang/buck is this one:
or if you really like RGB, then this (otherwise identical)
It's not on the qualification list of your mobo for the 9000 series, for some odd reason (probably due to the age of the product) but it is for the 7000 series:
In my country at least it can be had for a very good price and HWUB among others covered it, offering some of the best OOtB performance.
No customers in their right mind would use (Intel 3) proprietary tools to design their cpus knowing very well it's literally a dead end.
My understanding (Having trouble finding the original source where I read this) is that Intel 3-E and/or Intel 3-PT is supposed to introduce industry standard tools.
Intel 3 capacity is still quite limited:
And 3-E and 3-PT are supposed to come later:
Going from 8/16-24 to 6/24-30. 6 P cores and 24 E cores.
Going by your calculations, that 6+24/30 would have increased the performance from 8880 to 10848, a gain of +22.16%, while implementing HT with 10080 is just +13.51%. So, the switch to more E-cores is a better deal if the increase in die area is less than 1.64x of the increase when implementing HT.
With Arrow Lake, the rule of four E-cores for one P-Core no longer applies. A Skymont E-core cluster is around 33% bigger than a Lion Cove P-core. Switching two P-cores for two E-cores clusters would have increased the die size by roughly 6.4% which is around four times as much as implementing HT. That means it's not a better deal than implementing HT. As I said, it should have been a no-brainer.
That being said, it's still correct that E-cores provide much more performance per area than P-cores. That's the whole point of having them. But then why not go with just 32 or 40 E-cores, for maximum multi-core performance? Because it's a conscious decision to have 8 P-cores for Ultra 7 and Ultra 9. Marketing requires 8 of the fastest cores for the top SKUs.
Because there are many workloads that use a limited number of cores, it's rare to find a workload that can use 12 cores and stops there, it's more common to find a workload like games that can use 6 or 8 cores and not more, or workloads like Cinebench that can use tons of cores, like 32 for example. That's why a limited number of fast cores is important, 8 seems to be the sweetspot, 6 at minimum.
If I am not wrong isn't excel capable to use 16 threads?
Tiering should be straight forward:
9K: 6+24
9:6+20
7k:4+20
7:4+16
5k:2+16
5:2+12
3:1+8
I know some will object to the low P core count, but at i3 and i5 speeds, the E cores are nearly as performance as the P cores.
Edit: I still strongly contend that, for most applications, there are usually just one or two threads that are performance critical. With the E cores doing so well, it won't really matter.
