Page 495 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
942
859
Wildcat Lake (WCL) Specs
Dies2223
Threads12688
Max Clock5.4 GHz?5 GHz4.8 GHz
L3 Cache12 MB12 MB12 MB
Size96 GB32 GB128 GB
Bandwidth136 GB/s
RTNoNoYESYES
EU / Xe96 EU2 Xe8 Xe4 Xe
Max Clock1.3 GHz?2 GHz2.5 GHz
ondma
3,321
1,715
Yeah may not. But Zen 5 is a flop in uplift with almost no gain in gaming and other consumer workloads that do not use AVX512. Will Arrow Lake actually have a meaningful gain over RPL in gaming and other general consumer workloads even if only 10-15%. I really want to see that plus much lower power for cooler running CPUs and oh stability stability stability which Raptor Lake lacks.
Raptor Lake may even lack stability and still degrade too easily even with corrected microcode and default Intel power profile updates. It was a rushed design and flawed afterall.
"Only" 10-15%? I would jump for joy of ARL shows that much gain in either 1T or nT. (I mean in final performance, not just IPC)
511
5,551
4,945
Maybe in 128-bit support, but that's a stretch. Supporting it itself increases transistor count and power because of the extra registers.
Nope Avx10 128 bit was canned so it is 256 bit or 512 bit
AVX512 is a remnant of the misguided and fat Intel that aimed at continually increasing vector performance of CPUs to limit GPU inroads. There were AVX1024 in plans at one point according to some. It should have went from AVX2 to AVX3, but with 256-bit vector.
It is really nice but I agree AMX was invented for AI instead of AVX-1024 a nice step
The E cores have been closely following ARM cores in development. After all, Atom was shifted to compete with ARM in Smartphones early on and that never stopped.
And it is paying them off nicely look how E cores have been constantly getting better i think Skymont is on same level as X2 which is nice in terms of IPC
ondma
3,321
1,715
MS_AT
948
1,878
Yes.
Link: C&C
In addition to what Nothingness said I will also quote from the article:
The most common FP/vector math instructions are VMULSS (scalar FP32 multiply) and VADDSS (scalar FP32 add). About 6.8% of instructions do math on 128-bit vectors. 256-bit vectors are nearly absent, but AVX isn’t just about vector length. It provides non-destructive three operand instruction formats, and Cinebench leverages that.
naukkis
1,030
854
I would buy a 10-12 P core 5GHz Golden Cove/Alder Lake CPU on a single ring bus in a heartbeat if it existed.
Arl come very close of that. Up to 12 threads every thread have 2MB L2 and at least 4.6Ghz clock on same L3 ring. Replacing Skymont clusters with Lion Coves wouldn't change much at sane power levels.
TESKATLIPOKA
2,696
3,260
No it's just what to be expected from max 17w soc. Those 700-800 results would have only possible without powerlimits consuming about 100w.
As you said, 700-800 points is impossible at low TDP.
LNL is still just a 4P+4E CPU without SMT at 15W+2W for memory, 479 points is not that bad even If some think so or simply had too high expectations.
In comparison:
Ultra 5 125H 4P+8E+2LPE(18t) manages 564 points at 30W(Link).
Ultra 7 164U 2P+8E+2LPE(16t) manages 420 points at 16W(Link).
Core i3-N305 8E(8t) manages 324 points at 15W(Link).
I think retail product will score a bit higher ~500 points.
It could be an interesting CPU for a handheld, but I don't think price will be low and then GPU drivers are still worse than AMDs, and Intel doesn't have any frame generator yet.
511
5,551
4,945
I agree i was always thinking of 500-550 range
Funnily amd FG works with Xess so it won't matter much the drivers are the biggest pain though
Reactions: TESKATLIPOKA
Abwx
12,035
5,005
Oh pls. First you said it’s not there at all.
But now you say it’s there but useless.
Make up your mind!
There s only up to SSE 4.2 in CB R15, a tiny amount of AVX128 in CB R20/23, AVX256 is found only in CB 2024 since this is required to run this bench, and of course there s no AVX512 in whatever version.
Reactions: SiliconFly
Nothingness
3,374
2,475
Looks like AVX512 is not useful for general consumers after all!
No, it just means the CB guys didn't optimize their software for AVX-512 or found it didn't fit well in their current implementation. I will let you read about the benefits of AVX-512 for some other renderers: https://www.phoronix.com/review/amd-zen5-avx-512-9950x/3
Of course rendering is not of use to all people. Just like high-end gaming isn't.
gdansk
4,807
8,139
It should also work pretty well for a renderer in general.
For example, Intel added it to Embree. But last I tried I couldn't get AVX 512 to work, it required Intel's compiler on Windows. But maybe it works these days.
Not using AVX-512 extensively in a renderer used as a benchmark is almost a deliberate decision. Edit: And it's a fine decision in my opinion.
