Page 488 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
939
851
Wildcat Lake (WCL) Specs
Intel Raptor Lake UIntel Wildcat Lake 15W?Intel Lunar LakeIntel Panther Lake 4+4+4
Dies2223
Threads12688
Max Clock5.4 GHz?5 GHz4.8 GHz
L3 Cache12 MB12 MB12 MB
Size96 GB32 GB128 GB
Bandwidth136 GB/s
RTNoNoYESYES
EU / Xe96 EU2 Xe8 Xe4 Xe
Max Clock1.3 GHz?2 GHz2.5 GHz
DokiDoki
47
77
46
I wonder how what percentage of people who buy thin and light laptops get them with 64GB of RAM?
If you want a laptop with 64GB RAM, you buy a laptop with 64GB RAM.
You do not write asinine op-eds complaining about something that only supports a maximum of 32GB RAM.
Reactions: 511
511
5,336
4,750
It is <redacted> people buy 8GB Ram MacBook air thin and light and max memory on air is 24GB iirc LNL has 32 GB
Please refrain from using profanity in the tech section. -Moderator Shmee
Reactions: SiliconFly
Doug S
3,791
6,723
I could count the %age on my hand. clickbait article
Its some weird sense of entitlement that people think that every product should be designed with their needs in mind. So someone announces a laptop with up to 32 GB and they whine that they want it with 64. Buy a different laptop if you want what it doesn't have! This is no different that you want a small laptop with a screen 13" or less but want a 4K display, and complain that you can't get a 4K display in that size and have to go up to nearly 16" to get that. If you have niche needs you're gonna have to face that most products won't be designed with your needs in mind.
511
5,336
4,750
32GB should be fine for the target audience also for 64GB we need a denser memory die or larger package size in LNL to accomodate it and i agree with you
19,208
Then you don't know power users. If you are buying something so expensive, better to have it maxed out rather than hitting a wall at some point in the device's life. Especially since maxing out the specs of the device will usually be a fraction of the total cost. Only the rotten fruit company forces people to sell their kidneys for more RAM.
cebri1
373
405
He needs 64GB to run LLMs… at 1.4t/s :)
Jokes aside I think we are maybe a couple of gens away of running fairly large models on SoCs with large & cheap (&slow) memory with decent performance.
poke01
4,752
6,092
True but Power users don’t buy Lunar lake they buy Arrow lake H or HX with upgradeable memory. Memory can fail so it’s not good to solder it.
Tup3x
1,300
1,438
They can buy 64GB Dell XPS with Snapdragon Elite X now. Lost sales for Intel.
For power users it might be better option anyway since it has better mt performance. Assuming you don't have to worry about performance loss caused by emulation.
jdubs03
1,443
1,016
Yeah but then you have compatibility issues. Power users are probably the most likely to deal with programs that aren’t native to WoA. This is where it would be the HX 370s time to shine.
511
5,336
4,750
From the rumours Xe3 will have 3072 bit XMX engines and 12 XMX unit with upto ~150 TOPS and the FP32 ALU count is 1536
Anhiel
61
Ignoring cost I don't think asking for 64GB is unreasonable.
case1 Mobile with 16GB and Windows 10: 2GB locked for W10; ~2GB for VRAM; you only have 12GB left. Upgrade to 32GB gives you 26GB of free RAM.
case2 Now with 32GB and Windows 11/12: 4GB locked for Windows(it scales with RAM amount); 16GB for Copilot; you only 12GB left not even counting VRAM allocation. In other words your 32GB upgrade gives you 0 more RAM.
And if you consider the forced move from 32b to 64b apps that will further diminish your free amount of RAM. If you want an equal upgrade gain as for case1 going the minimum is to go for 48GB.
There are tons of reason to have VM not to mention VBS and some antivirus app are running VMs. I see this as a future must have thing.
Reactions: dr1337 and MS_AT
Anhiel
61
You're wrong on so many levels. Makes me wonder...
Nope. RAM is still expensive. Otherwise, I'd prefer to have 1TB RAM.
Windows uses less than 1GB of VRAM during normal usage like browsing, office, etc. It dynamically allocates more system memory for VRAM only during GPU intensive tasks (like gaming).
You think co-pilot uses 16GB RAM? Hilarious. Thats the minimum system requirement. Not how much it uses.
Win64 requires 1 GB more RAM than Win32.
Also, 64bit apps in general do not use twice the amount of RAM compared to their 32bit counterparts. Just a tad more.
And for running VMs, we need go for platforms that are designed with such use cases in mind. Like ARL-H or AMD HX 370. Not thin and lights.
VBS is a thin virtualization layer built for kernel security, not a full blown virtual machine like you think. The difference is huge. And it does not use tons of RAM. Many Win10 machines and almost all Win11 machines use VBS by default (for many years now).
This is theoretical that's why I said ignoring cost.
Windows actually can use much less VRAM depending on the frame buffer. But most mobile have it set to 2GB. Again this is purely theory and normal cases not fringe case.
Yes, 16GB is Copilot requirement and since Windows auto locks for 2GB at this scale there's 14GB left (not counting VRAM) not much different to my generous allocation amount.
Try testing that 32b to 64b difference with something like GIMP with huge images (taking up 1GB VRAM). In my tests for 64b (v2.10) I can't get things done (as in hours) while the 32b (v2.8) It tooks only minutes. It's a significant difference eventhough RAM usage only had 1GB difference.
VBS uses 3% it's still a loss of RAM and performance.
511
5,336
4,750
i think you are wrong here cause cause AMD Reserves the Ram permanently unlike intel which only reserves like 128-256MB max everything else is shared pool which is dynamically allocated
The performance loss is too much vs the ram loss in VBS sometimes we have so many amazing programs from Microsoft or our friendly OEMS and than we have our loard and savior Google chrome that hogs Ram like no other so 3% is still fine compared to them
Anhiel
61
I dunno about those differences but I do know it won't go down less than ~40 frames and up to about 256 frames; it takes whatever amount depending of your screen size.
The point of fixed allocation calculation is not about being precise but about making sure things can run under any circumstances. In other form of engineering you would call it safety margin.
Yes, considering most people use a browser all the time, then most likely a chat program like discord, all the other background apps and before you know it a lot of RAM is gone. Not even talking about apps getting less and less optimized.
Even if I just use Office suits (at least 2-3 open), likely also Adobe PDF, the amount of apps coming together is already at least 6 and that's before even starting on power using. I wouldn't say ordinary people these days don't need lots more than a decade ago.
Wolverine2349
526
180
86
Upon further checking my hope for more than 8 strong cores with good core to core latency is alive with Arrow Lake after all
That is Core Ultra 155H which is Meteor Lake.
The Core to core latency between Cresmont cores which there are 8 of them (both in clusters of 4) have mid 30s ns consistent latency even with the cores in different 4 core cluster). So apparently at least with Meteor Lake which Arrow Lake is gonna have same latency per reports.
So with Arrow Lake, and Skymont e-cores having Raptor Cove IPC, maybe could buy the Core ultra 265K or 285K and disable Lion Cove cores and have a 12-16 Raptor Cove substitute cores with excellent and more importantly consistent core to core latency in mid 30s ms between all 12-16 Skymont cores regardless o which node they are in., And the Skymont cores run at 4.6GHz. Probably can get them overclocked to 5GHz and perfectly setup 12 P core Raptor Lake equivalent with slight lower 5GHz clock. I am excited.
Wolverine2349
526
180
86
Raptor Lake it seems there is a little more hit going to e-core clusters in latency where as Meteor Lake, there is none at all and in fact core to core latency even better between Crestmont cores even in different 4 core clusters *as long as on same ring as LPE cores of course are bad which desktop counterparts will not have and are excluded)
Though its a mild increase and pretty consistent even among the 4 different 4 core Gracemont clusters though not quite as good as Raptor Cove to Raptor Cove communication. And despite consistent 40s ns score to core latency GFracemont cores are Skylake IPC or weaker in certain aspects.
Consistency is key. AMD has even better core to core latency within a CCX than Intel as all numbers are in green. But once it exits a CCX/CCD, latency jumps enormously and it is bad as not consistent as a massive latency jump through IF.,
Supposedly AMD is supposed to improve it with Zen 6, but then again with Zen 5 was supposed to be much better, but cross CCD/CCX latency actually much worse than Zen 4 as with Zen 4 jumps into high 70s to 80s ns where as Zen 5 100s of ns almost like Laptop LPE e-cores of Meteor Lake which are irreverent for desktop on Intel side.
I am exited looking at the Core Ultra 155H graph and seeing consistent 30s core to core latency of the Crestmont cores even in different clusters on same ring. Figure Arrow Lake Skymont cores should be no different if not better and just as consistent. My dream chip may be there if I can disable the Lion Cove cores and use only Skymont with a mild 5GHz overclock. As long as Skymont can truly replicate Raptor Cove IPC and real world performance with HT disabled across the board all workloads with same RAM overclock and latency as well. But obviously with good stability and no degradation unlike RPL.
