Page 437 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
Wildcat Lake (WCL) Specs
Intel Raptor Lake UIntel Wildcat Lake 15WIntel Lunar LakeIntel Panther Lake 4+0+4
ModelIntel 150UIntel Core 7 360Core Ultra 7 268VCore Ultra 7 365
Dies2223
Threads12688
Max Clock5.4 GHz4.8 GHz5 GHz4.8 GHz
L3 Cache12 MB6 MB12 MB12 MB
TDP15 - 55 W15 - 35 W17 - 37 W25 - 55 W
Memory128-bit LPDDR5-520064-bit LPDDR5x-7467128-bit LPDDR5x-8533128-bit LPDDR5x-7467
Size96 GB48 GB32 GB128 GB
Bandwidth83 GB/s60 GB/s136 GB/s120 GB/s
RTNoNoYESYES
EU / Xe96 EU2 Xe8 Xe4 Xe
Max Clock1.3 GHz2.6 GHz2 GHz2.5 GHz
NPUGNA 3.017 TOPS48 TOPS49 TOPS
Nope. Check the videocardzGB6 numbers (all stock). 9950X is 3335 & 285K is 3450. That puts 285K around 3.5% ahead of 9950X.
I posted Computerbase since all their tests are at stock 5600 RAM using the latest AGESA contrary to random GB subsmissions whose most were done before the CPU was launched and with old AGESAs, hence the low average.
Beside even for the 14900K at 5600 RAM they have a higher number than the average GB submissions that often use higher speed RAM but are done by PCs that run some light background tasks when tested by random users.
That M4 score is throttled. Here's the non-throttled one. Most of the M4 scores will be lower because you know thin tablet, it peaks at around ~2700-2750 in GB5.
There is a difference when the frequency is maintained throughout the test.
https://browser.geekbench.com/v5/cpu/compare/22615013?baseline=22798191
Here are a dozen of the latest Geekbench results for Apple M4. I don't see 2700-2750 there. The regular scores are closer to 2500-2600.
2700-2750 were probably obtained under LN as Geekerwan did.
Most likely the freezer. Almost all of results in the screenshot the freqency is not maintained and if it is maintained it would score around 2700. This shouldn't be an issue for Macs with fans.
https://browser.geekbench.com/v5/cpu/22615013.gb5
"processor_frequency": {
"frequencies": [
4407,
4405,
4394,
4399,
4392,
4402,
4402,
4402,
4408,
4396,
4401,
4406,
4399,
4396,
4406,
4402,
4338,
4403,
4398,
4405,
4397,
4396,
4406,
4402,
4397,
4406,
4403,
4407,
4402,
4397,
4401,
4401,
4402,
4408,
4402,
4390,
4398,
4403,
4407,
4407,
4403,
4404,
4391,
4371
The ones that are throttled score around ~2500.
"frequencies": [
4388,
4401,
4394,
4392,
4380,
4393,
4401,
4409,
4395,
4390,
4394,
4398,
4391,
4403,
4393,
4398,
4381,
4384,
4394,
4383,
4388,
4388,
4386,
4330,
4386,
4396,
4395,
4396,
4400,
4396,
4394,
4382,
4393,
4389,
4396,
4381,
4389,
4399,
4385,
4395,
4394,
4395,
4395,
4399
Yeah I wonder how Intel's P cores will evolve, Intel did say they were focused on IPC instead of clock improvements now. But keep in mind that is 4.40GHz vs 5.7GHz Intel has a long way too go to match Apple in IPC.
At this rate the E-core team will surpass the P core.
Yeah per clock ipc apple is way ahead.. i think darkmont or arctic wolf will catch apple on a per clock ipc
Thats invalid. Test 285K at recommended settings including RAM (not 5600).
Hence, 285K is 3.5% ahead of 9950X. No doubts.
Latest AGESA was received by Computerbase 4 days before the reviews days, actually they only had 3 days to do the tests, so all others AGESA, thats is, the totality of what was submited at GB before August 14, are invalid by the definition.
That being said i m curious of your reaction once some other submissions of the 285K are done at GB and that some scores are lower, because a single test is not representative statistically wise.
There is something wrong with those clocks because the averages are 4400 for the first result and 4390 for the other ones. It's a 0.2% difference.
So, most results between 2500 and 2600 are valid and not throttled.
There are some weird scores (less than 2400 and more than 2700), but they are not representative and should be excluded from the analysis as outliers (if we want to stay objective, of course).
Ok. It's time for me prepare a "I told you so" list of all the people who said this ARL generation will only get a lower single digit % performance uplift in ST. Whereas, it's already showing 11.7% ST gains against previous gen equivalent 14900K and this isn't final silicon yet!
There are many people in the list, with whom shall I start? :tearsofjoy:
Mild said arrow lake refresh will uave even higher clocks
Surely the "per clock" is totally irrelevant when talking about IPC (Instructions Per Cycle).
While the x86 vendors get close to Apple they do so use way more power.
For single core that continues to be true however LNL will be pretty close to a M3 in MT scenarios at comparable power, on the same node. (M4 will be ahead but on N3E instead of N3B.)
this is just Geekbench, we still have to test many more. Cinebench. Productivity tests, web tests, gaming etc
Edit: skymont is star here
Looks like it's everything Intel said it was. Can't wait for actual tests with real software. Top of the AMD/Intel stack will once again be neck-and-neck in performance.
