Page 436 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
926
844
Dies2221
Threads8688
Max Clock3.8 GHz?5 GHz
L3 Cache6 MB?12 MB
TDP7 WFanless ?17 WFanless
Size16 GB?32 GB24 GB ?
EU / Xe32 EU2 Xe8 Xe12
Max Clock1.25 GHz2 GHz
NPUNA18 TOPS48 TOPS100 TOPS ?
biostud
20,041
7,145
I threw in towel AND THUS SOLD or returned on any 13th or 14th Gen part because of stability and degradation issues. SO never really tested it,
I have a 7800X3D right now.
But if they have a 12 P core on a single ring bus Raptor Lake and it has stability issues fixed (I would think given new die or otherwise Intel will not make it), I am for sure a buyer. If it has the 8 + 16 RPL die stability and degradation issues, a hard pass despite me wanting such a product.
Would you trust Intel enough to buy such a 12P processor at launch? Or how many months would you wait?
Wolverine2349
525
179
86
I will play that by ear. I think I would trust it at launch as long as it's determined that the issue is with the current stepping and not a design flaw in Raptor Lake itself.
Cause Alder Lake stepping are reliable and stable also on same 10nm node.
If there is some flaw with cache or ring structure of RPL (have heard rumors there may be and not just a stepping issue) and it is not stepping than no unless intel makes it Alder Lake based. Those I suppose its possible those flaws are based on the current die or they could be based on Raptor Cove cores and the ring and cache not sure. If its the latter its a hard pass.
Not sure what to do. Given its coming out in 1 year, hard to wait a few months. If it was out like now then yes I would wiat a few minutes. Hope to have more data for a good informed decision by then given its tardy release date.
ondma
3,316
1,708
Yep. If any reviewers are using some special settings in benchmarks that casual users don't understand or able to replicate, then it amounts to cheating.
Its not cheating really, but they should make clear they are using some special settings.
Reactions: Elfear
511
5,164
4,628
Reviewer using XMP they should compare JEDEC as well cause freaking 90% of users run it
Doug S
3,761
6,657
Maybe they need two results, one is "this is the performance typical users who mostly use defaults will see" and "this is the best you can get if you perform the full list of optimizations/tweaks listed in the footnotes".
It is really no different than if they overclocked the CPU by 500 MHz in their results. Just like core parking, buying faster RAM and tweaking it, and so forth, that's just another optimization to get more performance, right? But I have a feeling more people would find that to be "cheating" than the stuff they're currently doing. Not sure why.
dullard
26,185
4,844
Exactly. All good reviews do this. Spec memory/clocks/settings (which is what almost all users will see when they buy a Dell, HP, Lenovo, or similar). Then max everything (which throws money and power consumption concerns out the window).
jdubs03
1,367
950
Hot off the press:
Based on the chart within, ST is about 11% higher than the 14900K and MT is about 10% higher.
H433x0n
1,224
1,606
There’s some really good news in these results. If you dig into the subtests, ARL gets wins in text processing and HTML5. It’s only real big losses are object detection and background blur both of which are accelerated by AVX512.
So if you go by just the int performance, ARL looks promising against Zen 5.
cebri1
373
405
why? Its supposed be higher in ST, lacks HT(increases ST) and is on a much better node.
If you take into account the IPC increase and the clock regression should be under 10%. People were expecting close to 3-5% improvement.
Abwx
11,942
4,920
Yours is overclocked. Normal 9950X will be 3.5% slower than Core Ultra 9 285K.
This change nothing, 14900K and 9950X score 3236 and 3427 in ST respectively, both using stock speed RAM at 5600, this 285K GB submission use 6400 RAM and 5.7GHz ST frequency, so the 9950X is certainly not 3.5% slower in ST at stock RAM speeds.
  • Screenshot 2024-08-21 at 10-46-01 AMD Ryzen 9 9900X und 9950X im Test Benchmarks in neuen Anwe...png
Reactions: Tarkin77
511
5,164
4,628
6400MT/s is the supposedly official speed for Ultra 9 285K,9950X is 5600 according to AMD so both running at STOCK :)
Tup3x
1,293
1,427
Hot off the press:
Looks pretty nice. Now it all comes down to power usage.
Det0x
1,481
5,059
Also, there are some results for Geekbench 5. The P-core in Intel Core 285K matches the one in Apple M4:
That's not a fully fair comparison because of the Geekbench Windows tax, but it is pretty interesting.
Seems like the 285K does alittle worse in GB5 ST than GB6 ST in comparison against the same OC'ed 9950X (?)
Abwx
11,942
4,920
Supposedly...
And the submission was made at JEDEC lose timings for DDR 6400 you think.?.
Anyway even at 6400 it score a paltry 0.67% better than the 9950X at 5600.
It matters a lot. Looks like Zen5 isn't that good compared to ARL. Seems both are actually running at stock. :tearsofjoy:
9950X run within 200W while ARL is at 250W, and Intel already made a reservation for 297W/329W PL2/PL4 in case 250W still falling short in a lot of benches, wich will be likely the case if we look at the 43118 pts CB R23 score at 250W.
