Page 42 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
942
858
Wildcat Lake (WCL) Specs
Dies2223
Threads12688
Max Clock5.4 GHz?5 GHz4.8 GHz
L3 Cache12 MB12 MB12 MB
Size96 GB32 GB128 GB
Bandwidth136 GB/s
RTNoNoYESYES
EU / Xe96 EU2 Xe8 Xe4 Xe
Max Clock1.3 GHz?2 GHz2.5 GHz
Exist50
2,452
3,106
View attachment 77825View attachment 77826
Above slides seem indicating Die2Die power delivery from SoC, is it?
I think I see the confusion. The top slide is referring to the location of die-to-die interfaces for communication between the active (top) chiplets. The bottom, as mentioned in the upper right, is basically a cross section of the base die. That big pillar (TSV) in the center is where the power would come from. The metal layers at the top are where the signals are routed between dies, and possibly some second order fanout for power delivery. But there should be no power delivered between the top dies.
uzzi38
2,747
6,657
Below is my understanding of upcoming Meteor Lake and Arrow Lake CPU and I am trying to calculate how much power needed in TDP term.
13th RPL-HMTL-HARL-HX
Release DateQ1 2023Q1 2024?Q1 2025?
Process NodeIntel 7Intel 4 + N5 + N6Intel 20A + N5 + N6
CPU Max Cores6P + 8E6P + 8E8E + 16E
L3 Caches24MB24MB36MB
P Core Base Clock2.6 GHz??
P Core Turbo Clock5.4 GHz??
iGPU96 EU - 1.5GHzGT2 Xe LPG 64EU - ?GT2 Xe LPG 64EU - ?
TDP45 W45 W55 W
Max Turbo Power115 W??
CPU TileNA25 W35 W
SoC + IOE Tiles (est)NA10 W10 W
GPU Tile (est)NA10 W10 W
Power per CPU core (4E ~ 1P)3.13 W2.92 W
  • As far as I understand, SoC tile is the one receiving power from the socket then distribute to other tiles (namely CPU, GPU and IOE) through die to die connectors. That's why I figure SoC tile consume much more power than conventional PCH. For simplification, I combine SoC and IOE tiles as total power of 10W.
  • GPU tiles are based on Alchemist graphics engine; so I calculate upon A370M's TGP of 35W. With half of Xe cores and newer process, 10W seems reasonable?
  • That left 25W for CPU tile; here comes the interesting part cause this is Intel's first CPU that based on EUV lithography and I am expecting higher clock speed. For reference, AMD's Phoenix has TDP of 35W with base clock speed of 4 GHz and 2.8GHz iGPU speed which are rather impressive. Power per core figures might be good indicator of process advancement in the future cause AMD and Intel are moving to chiplet/tile design...
CPU, GPU, SoC tiles etc would surely be dynamic in their power usage rather than a set 25W/10W/10W split. You shouldn't be seeing the GPU tile pull or reserve 10W for non-GPU accelerated tasks.
Hopefully.
Tigerick
942
858
Hopefully.
Sure, the clock of all tiles would be dynamic but the base of operations will be set by certain power criteria, hence TDP. When Intel advertise all cores base clock of CPU like 2.5GHz, that is nominal speed at TDP of said 45W. With turbo mode, the CPU speed will go much higher. With Speedster, CPU speed would go much lower. But nominal speed is the standard clock being advertised and that associate with the TDP. Even with tile design, the rules apply.
Tigerick
942
858
Hmm, come to think of SoC design with 3 die2die connectors are really stressing the CPU. SoC has to coordinate CPU, GPU, memory controllers and then output the video through IOE which has power of it own. No wonder Intel has to put ULV Atom within SoC...
SiliconFly
1,924
1,284
TDP45 W45 W55 W
CPU TileNA25 W35 W
MTL is expected Q4 this year.
MTL Xe1 tGPU is rumored to be TSMC N5. But Intel hasn't confirmed that yet i think. Their ARL tGPU which is also Xe1 but many a times it was mentioned it's going to be on N3. Considering, Intel already has a lot of N3 capacity now & it's a waste of time and resources to just port the same design to yet another node, it's very much possible both the tGPUs might actually end up being N3. Or N5. We don't know for sure. Gotta wait for more info.
The core count for MTL isn't confirmed yet. Many say it's 6+8. And many say it's 6+16. The latter makes more sense. 6+8 won't cut it anymore as it's a huge step backward. Intel might shoot itself in the foot with 6+8. I think it's gonna be 6+16.
Due to the density increase because of node jump, there is always a possibility MTL might get more L3 cache than RPL. 30MB sounds about right? Not sure though.
45W TDP parts confirmed. But 55W parts not ruled out yet. Got to wait for further announcements. Might happen as they need a replacement for their HX series.
jpiniero
17,209
7,582
6+8 is what the P maxes out now, so not really. There's also a 2+8 die.
Given that desktop is getting Raptor Lake Refresh, I imagine there will be HX of that at the very least too.
SiliconFly
1,924
1,284
6P is pretty much solid info. But why do you think 16E isn't possible? It's not confirmed yet. Even 8E isn't confirmed yet.
Exist50
2,452
3,106
MTL Xe2 tGPU is rumored to be TSMC N5. But Intel hasn't confirmed that yet i think. Their ARL tGPU which is also Xe2 but many a times it was mentioned it's going to be on N3.
Without commenting on the rest, MTL's GPU is Alchemist-based, not Battlemage/Xe2.
Reactions: Kepler_L2
Hulk
4,126
Wait a minute. Wasn't the rumor that Meteor Lake would be mobile only because Intel couldn't get frequencies to ramp up on the new node? If TMSC is doing the CPU tiles then what's the deal with the node? It's not even Intel's node?
mikk
4,333
2,414
No it wasn't, there is no serious rumor like that. Some people may speculate this is the reason but this is just a guess. Also there is no confirmation about no MTL for desktop.
Exist50
2,452
3,106
TSMC is not doing the Meteor Lake CPU tile. They're doing all the other top dies though.
SiliconFly
1,924
1,284
Just rumors. Waiting for more info. At this point we can easily rule out 6+8 as it appears to be a sandbagging trick. If I remember right, Intel 4 HP libraries should be able to handle 5.5 GHz easily. Beyond that is we still don't yet.
BorisTheBlade82
722
1,149
IIRC the "big" MTL compute tile is supposed to have gotten cancelled. IMHO that is the 6/8+16 you are talking about. Now only the 6+8 as well as the 2+8 are left. That might arrive in the Mid to Low range Desktop at some point but should start as mobile only.
MTL looks like IceLake-U at best and Cannon Lake at worst.
jpiniero
17,209
7,582
Way I'd interpret is that the 24/25 desktop would be Arrow Lake (at TSMC) for the high end and the 6+8 Meteor Lake tile at the lower end.
Reactions: Exist50
DrMrLordX
23,228
13,310
Wasn't someone saying that Intel would be using TSMC N3 for desktop parts and 20a for mobile parts in late 2024?
SiliconFly
1,924
1,284
TSMC capacity is meant for the AXG group (N3/N5/N6). Whereas 20A is for the client group (more specifically Arrow Lake).
SiliconFly
1,924
1,284
Actually, intel's plan for desktop parts hasn't leaked yet. Some rumors say meteor lake has no desktop parts! Doesn't sound right.
Meteor lake is a Q4 2023 product.
Arrow Lake is Q3 2024 product.
Intel going without any new desktop parts from late this year to Q3 2024 doesn't sound right. Even a raptor lake refresh doesn't sound very appealing. I'm sure they're cooking something better than a RPL refresh. Wish they shed some light sooner rather than later.
BorisTheBlade82
722
1,149
I fear, that exactly what you fear is what will happen 🤷🏽‍♂️
Reactions: Hulk and SiliconFly
jpiniero
17,209
7,582
There was a legit looking roadmap leaked which had Raptor Lake Refresh on it. If anything, the question is going to be whether Intel feels compelled to also do mobile rebrands to help cover up Meteor Lake's low supply.
Kepler_L2
1,093
4,723
That will be the case yep. It's basically Ice Lake/Comet Lake generation all over again.
Exist50
2,452
3,106
Seems more like Tiger Lake. 6+8 should be enough for use in the H series. So just like Tiger Lake, we're going to get mobile on the new gen, and desktop on the older. Though I guess unlike Tiger Lake, we should eventually see MTL in the mainstream to low end desktop market.
Reactions: Strangerer
SiliconFly
1,924
1,284
MTL 6+8 is just a rumor. Another rumor said 6+16. The later sounds more plausible.
Geddagod
1,683
1,720
Intel themselves have shown a 6+8 die. It's the only one we have confirmation for other than 2+8.
I think it's a decent assumption to make that a 8+16 MTL die could have been planned, even if it never got anywhere. RPL only exists because MTL was coming in late, so that makes it seem like a 8+16 MTL desktop sku would have been planned (or at least an 8+8) to fill out their desktop cadence.
A 6+16 die just sounds weird, because that would just look weird as a successor to Alder Lake desktop, while also looking weird as a successor to Alder Lake mobile as HX skus would on alder lake had 8 big cores. One could argue 6+16 die if Meteor Lake was always planned to be a mobile only lineup, but I don't think so.
