Page 356 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
941
857
Wildcat Lake (WCL) Specs
Dies2223
Threads12688
Max Clock5.4 GHz?5 GHz4.8 GHz
L3 Cache12 MB12 MB12 MB
Size96 GB32 GB128 GB
Bandwidth136 GB/s
RTNoNoYESYES
EU / Xe96 EU2 Xe8 Xe4 Xe
Max Clock1.3 GHz?2 GHz2.5 GHz
DrMrLordX
23,198
13,286
edit: somehow a quote wandered over from the Zen5 thread and I'm not sure how it got here. Either that or I was in an off-topic conversation so I've deleted my response.
6+8 is both TSMC and Intel.
Huh, how will Intel handle sourcing the 6+8 tile from different foundry companies? Are they going to mix and match within the same SKU or parcel them out to different SKUs based on the source foundry?
Elfear
7,169
829
Best case they might even add another 15% IPC. LNC in ARL isn't just an updated LNC in LNL. They were working in parallel from the beginning. Those two might be entirely different beasts for all we know.
Also remember, LNC in LNL isn't allowed to stretch it's legs due to power/thermal constraints. Not so in case of ARL. Some free bonus there too.
We may just receive 2% to 3% IPC uplift (over LNC in LNL) like you said. Or we may end up with a massive 30% uplift. Who knows? We can only speculate until they say so.
Has a 15-30% IPC increase ever happened on the same basic core design? Genuinely asking here. That would be like the same IPC increase we saw from RWC --> LNC on the low-end or Cypress Cove to LNC on the high-end. That seems so far outside the realm of possible...
Reactions: Tlh97 and Racan
Ghostsonplanets
774
1,228
From what I know, N3B 6+8 should be the highest volume at first, with 20A being lower volume. 20A ramp up later, with (maybe), getting the lions share of 6+8 die volume.
And 6+8 20A die is exclusively Desktop. Mobile is only 6+8 TSMC N3B.
Reactions: carancho
H433x0n
1,224
1,606
The odds of that are like 0.01%. Realistically a 2-5% above Lunar Lake’s variant of Lion cove is best case scenario for ARL-S.
The only way I can see it exceeding that is if they somehow reduce latency significantly with the SoC tile designed for desktop.
Edit: Why am I being downvoted / reported for a benign statement?
Thunder 57
4,250
7,049
People gonna hate. Have yourself an upvote.
Jun 4, 2024
I agree, expecting 2x performance gain by moving from low power design to high power design seems wildly optimistic. If they include HT, I could see MT gaining that extra 20%, but IPC for single threaded workloads isn't changing by an additional 15%.
Hulk
4,047
No. We used to call that a "tick." 5% is all we ever saw and it was usually due to very minor core/cache/memory subsystem changes.
Golden Cove to Raptor Cove would have been a tick back in the tock-tock days. Large L2 cache, more cores, and a process stepping.
Reactions: Tlh97 and carancho
Hulk
4,047
Okay, that answers my question: they won't mix & match within the same SKU. Which makes sense.
Could you imagine the mess that would cause? Kind of like SSD manufacturers using different NAND vendors. "Hey, did you get the Intel 20A or the TMSC N3B CPU tile on your ARL? I hear the memory controller is generally better on the Intel node but the TMSC clocks higher with less voltage. I'm gonna return mine and try again."
Joe NYC
4,189
5,755
Interesting. Someone just forgot about the recent Crestmont to Skymont.
Things happen. Both with AMD & Intel. We can never be sure of what to expect in this climate.
It is much easier to increase IPC when starting from low IPC base (previous gen E-Cores) than from a much higher base (previous gen P-Cores)
Especially when given extra transistors, extra die area, extra power budget.
Reactions: Racan
FlameTail
4,384
2,762
What would be the performance ratio of Lunar Lake's 'P-core : E-core'? Curious to know.
For comparison, Apple M3's ratio is 3 : 1.
DrMrLordX
23,198
13,286
Apple did it years ago with modems. They didn't just use different processes, they used entirely different OEMs (Intel and Qualcomm). That was quite a fiasco.
FlameTail
4,384
2,762
LNL has 3 display pipes. One would be used for internal display of laptop, meaning two remain for the external display.
So Lunar Lake laptops can only drive 2 external displays?
DavidC1
2,144
3,285
But Skymont is a huge change, while you are talking about 15% gains in essentially a near identical architecture.
The expectations are insane, such as 40% for Zen 5. Arrowlake uses the same tile configuration as Meteorlake, and Lunarlake is using a much saner approach. If anything, Lunarlake's Lion Cove should be faster than Lion Cove in Arrowlake.
I'd say your conclusions are insane, but I won't because I know you still got lot to learn.
Sure, but Apple has got it MUCH higher and even the ARM teams. This means the E core team is on the right track(still got ways to go) while the P core team needs a drastic overhaul, maybe a complete abandonment of the basic design.
14% difference per clock with near 3x difference should be a clue for everybody.
If they continue on the same path, Novalake will be a chip where P core's only advantage is in clocks, while still having the massive 3:1 area disadvantage. If the problem is due to the P core management and members being arrogant, the only way is to embarass them to destroy their attitude. Maybe bring the difference in core size down to 2:1 and beat the P core by 15% per clock.
Imagine if Conroe was a chip where it had Netburst and Core cores in one silicon.
Reactions: Racan
FlameTail
4,384
2,762
3 displays (2+1) is more than sufficient. Even Apple doesn't support like 8 displays or anything like that. Not needed.
3 vs 8 is huge number. I think there is a sizable number of people who use 3-4 external displays. Not sure.
CouncilorIrissa
786
2,854
I'd wager there’s a very small intersection between people who benefit from LNL's performance on the go AND those doing the type of work that requires 4 or more monitors. If you have so many monitors it’s very likely that you have an actual workstation next to them.
Reactions: Joe NYC
Wolverine2349
526
180
86
Is Arrow Lake going to inherit exact same core to core latency as Meteor Lake or could it be improved?
How would you say Meteor Lake core to core latency is compared to 13th and 14th Gen and also AMD core to core latency within a CCX?
It seems AMD core to core latency is great within a CCX but once it leaves a CCX/CCD< it is a massive 3 to 4 times increase hit.
Intel seems more consistent though still a 10-20% increase going to the e-cores rather than 300-400% increase AMD has crossing CCX/CCD/
Though could Arrow Lake make core to core latency relatively equal between P and e-cores where as 12th to 14th Gen has like a 15-20% increase going form P to e-core.
I noticed slides for Meteor Lake seemed to suggest yes, but at same time some core to core latency form P core threads seemed a little more inconsistent as in 15-20% hit in MTL than 13th and 14th Gen. Though not sure if they can fix that and maybe that was poor hyper threading latency implementation crossing threads on P cores of Meteor Lake?
And if latency is consistent and good between all cores P and E within a single tile on Arrow Lake would it likely be the better choice than AMD Ryzen 9000 for CPU thread heavy games??
