Page 330 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
941
857
Wildcat Lake (WCL) Specs
Dies2223
Threads12688
Max Clock5.4 GHz?5 GHz4.8 GHz
L3 Cache12 MB12 MB12 MB
Size96 GB32 GB128 GB
Bandwidth136 GB/s
RTNoNoYESYES
EU / Xe96 EU2 Xe8 Xe4 Xe
Max Clock1.3 GHz?2 GHz2.5 GHz
branch_suggestion
888
1,937
Seems peak ST performance will be neck and neck for Zen 5 and Lion cove at the supposed frequencies?
Yes, which is why AMD cheaped out on area again and settled for another balanced PPA core, since AMD knows they have X3D to fall back on and Turin is still gonna be comfortably ahead in server, plus Strix has the better ancillary IP vs ARL-H.
Volumemaxxing is a risky game.
H433x0n
1,224
1,606
A few %% above GLC in specint is where Zen4 and bros dwell.
Dingus on PHX2 goes to 3.7 and that's a mobile part.
Please.
It's a few % above RPC, where Zen 4 is behind.
BTW have you seen SRF benchmarks? Looks like SRF is now the most efficient X86 server CPU in existence.
The power efficiency story of the Xeon 6700E series is a great one and allows Intel to regain competitiveness on that front and in a number of cases outperforming 4th Gen EPYC in performance-per-Watt for both Genoa(X) and Bergamo.
Pretty good event for Intel.
Reactions: Henry swagger
Markfw
May 16, 2002
27,397
16,239
Get an SPR-MCC, get a Genoa, bench it.
Also did you mean this? This isn't comparing against Bergamo, but a 64c(!!) Genoa.
That is a slow... Genoa also, the 9554 is what they should be using.
What we really need is a few 3rd party review sites to bench them and give results. I don't believe anything either company shows at a preview.
Reactions: carancho
mikk
4,333
2,413
From this slide LNL-MX iGPU seems to be easily faster than MTL-H iGPU at the same power.
Lion Cove might be only 10% faster per clock than Skymont. This is so bad from the big core given how much bigger it is.
H433x0n
1,224
1,606
Client is tricky because I don't have PHX2 on hand.
Ask cheese, maybe he'll do SPEC runs. Eventually.
no, I'm going off of the Phoronix review that I linked.
Edit: Looks like Intel 3 is a legit node. That's super impressive for what was considered a meme SKU a few days ago.
adroc_thurston
8,479
11,198
Phoronix testing methodology is grade A mess. Don't (unless specific tests).
Now with SKT, RPL, MTL and ARL-U are non-starters. That's a big issue for Intel.
Not my problem.
Oh it is.
Which is why they're comparing 128c/128t SRF against 64c/128t Genoa.
They're brave. Not suicidal.
Saylick
4,117
9,628
I wouldn’t call it cheapening out, but it’s a very engineer-y move and not out of line with what Zen was originally named to do: bring a balanced approach to x86 cores. Using balanced cores (read: high PPA) lets them win in servers, where it matters the most. But I will admit I was really hoping they’d make an x86 version of ARM’s X cores instead of iterating on top of a wildly successful middle core.
Reactions: Elfear and Racan
