Page 28 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
Wildcat Lake (WCL) Specs
Intel Raptor Lake UIntel Wildcat Lake 15WIntel Lunar LakeIntel Panther Lake 4+0+4
ModelIntel 150UIntel Core 7 360Core Ultra 7 268VCore Ultra 7 365
Dies2223
Threads12688
Max Clock5.4 GHz4.8 GHz5 GHz4.8 GHz
L3 Cache12 MB6 MB12 MB12 MB
TDP15 - 55 W15 - 35 W17 - 37 W25 - 55 W
Memory128-bit LPDDR5-520064-bit LPDDR5x-7467128-bit LPDDR5x-8533128-bit LPDDR5x-7467
Size96 GB48 GB32 GB128 GB
Bandwidth83 GB/s60 GB/s136 GB/s120 GB/s
RTNoNoYESYES
EU / Xe96 EU2 Xe8 Xe4 Xe
Max Clock1.3 GHz2.6 GHz2 GHz2.5 GHz
NPUGNA 3.017 TOPS48 TOPS49 TOPS
The reason I did this was because of your post regarding my trying to outsmart the Intel engineers at various power levels for E and P frequencies. I was curious.
Back then I did it out of curiosity as well, if you remember I was surprised to see the desktop chips seem to behave better at low wattage than mobile Alder Lake chips. At the time I think I limited max P core clocks around 2.6-2.8Ghz for the 35W test, I remember it was above the expected frequency in MT loads and it somehow "fixed" the quirk, allowing me to run the MT test.
I highly doubt Zen 4c will have similar frequencies to normal Zen 4. We know they're not lowering IPC, and it's the same process, so really the only knob left to get a lot of density/power gains is frequency reduction. If Zen 4c could hit clocks similar to Zen 4, then frankly Genoa wouldn't have much reason to exist at all.
I've stated before that I consider Zen 4c as AMD extending the TAM of their previous mobile focused cores to servers. With those mobile cores the frequency was around the efficiency inflection point of the desktop/server core which usually is close to the base frequency of the latter. We'll see.
Roadmap update from MLID:
- Redwood Cove is targeting 15-25% more IPC over Raptor Cove
- Lion Cove is aiming to bring 22-34% more IPC over Redwood Cove
- Panther Cove is aiming to bring another massive IPC increase
OK, I am trying to compile next generation desktop CPU from both Intel and AMD which are supposed coming in 2024:
Intel 15th ARL-SCoresTotal Cores + ThreadsL3 CacheiGPUVSAMD 8000 Zen 5Total Cores + ThreadsShared L2 CacheExternal L3 V-Cache
Core i5 (T)6P + 8E14 (20)24 MB?4 Xe Cores = 512ALU8600X12 (24)12 MB64 MB
Core i7 (T)8P + 8E16 (24)30 MB?4 Xe Cores = 512ALU8700X16 (32)16 MB64 MB
Core i98P + 16E24 (32)36 MB?4 Xe Cores = 512ALU8900X24 (48)24 MB128 MB?
8950X32 (64)32 MB128 MB?
  • The above comparison chart is preliminary, will be keep on updating it. Any insights please let me know.
OK, I try to compile next desktop CPU from both Intel and AMD in Q4 2023/Q1 2024.The above comparison chart is preliminary, will be keep on updating it. Any insights please let me know.
Where are those "ZEN5/ Ryzen 8k" core numbers come from?
or is it just a speculation/ estimate of yours?
MLID said that "now it is expected to have at least a slight speed regression on the Intel 4 node compared to Raptor Lake".
I disagree with this.
We know that MTL had overcome TSV tax.
Raichu on twitter:
Lion Cove isn't part of royal core
Though I think Intel's Roadmap has shifted so much IDK what is "Royal Core" anymore. Like Arrow Lake a 2023 product now a (2H?) 2024 product.
Though I'll probably build a Z890 MTL-S i5 system hopefully Summer-ish next year and swap that i5 for a ARL-S i7 from the sounds of it (I mean Raichu didn't seem to shot down MTL-S going up to 6P?). I do wonder if LGA 1851 is going to be a long supported socket unlike previous sockets because it seems to be a very beefy socket for the long run. And I expect DDR5 for consumer to last a long time so making LGA 1851 long running since Motherboards these days are incredibly expensive (Z370 Taichi costed like £200 in the UK, now Taichi motherboards cost way over double that).
Motherboards damn expensive these days.
So MLID thinks MTL will target Golden Cove-like IPC improvement? If he believes his "sources", he's lost his mind I'm afraid. It reminds me of his 29% IPC jump for Zen 4 (Chips and cheese also posted that exact number for some reason).
That's cause MLID is pretty much gaslighting everyone and he's gained so much fame that every "press"(regurgitators is more like it) is referring to him. Look how he constantly changes his predictions.
Raichu and @Exist50 is right. Royal Core happens way later, like post-Panther Lake. Everything else is just a buildup of what they have right now. Also he said Arrowlake-S is coming almost at the same time as Meteorlake-S.
@Tigerick Core i9 and likely even i7 is Arrowlake with 8+16 not 6+16 Meteorlake.
I think he's perfectly aware of what he's doing.
Royal is Royal. It's really that simple. No double meaning.
It's baffling, really. I guess you need nothing more than persistence, ego, and a complete willingness to lie to become a professional "leaker".
How would we know what Royal is?
Like Royal could be Nova Lake? Is Royal going THAT powerful that as soon it leaks/releases that we know that that CPU arch is Royal based?
Fair point. But I hope that even if you won't take my word for it, Raichu's is worth more than MLID's, low bar though that may be.
I do expect Royal will be that distinctive, yes. But even if not, it's the name of the core. So they'll probably just say it...
From what I gather, MTL-S sounds like this:
P-Cores - IPC: single digit gains - Clocks: minor gains, especially in multicore workloads.
E-Cores - IPC: Double digit gains - Clocks: Decent gains.
Both: lower power consumption.
So I imagine total single thread improvements will be somewhere around 7-12%, multicore will likely be 30-40%. Just a guesstimate based on what I am reading now. Power limits down to 233W maybe?
I think (trustworthy) rumours surrounding MTL's TDP and PL2 will be the biggest indicator if Intel has something decent lined up, we'll see it in the (admittedly fake, since RTL needs to run unlocked/over 253W PL2 to truly compete with Raphael) TDP/PL2 numbers.
Lower than 241-253W desktop/115-170W mobile turbos? Will probably be good. Same? 50/50. More? It will be an unmitigated disaster, like Cannon Lake.
I love how specific the numbers are, even though performance benchmarking cannot be.
18% Sunny Cove and 19% Golden Cove. 51% for Zen 1. Again 19% for Zen 3.
Really? You could literally change one benchmark and swing it easily by 1-2%. 18 or 19% is called 15-20%. That's how we used to do it back in the days. That's the fundamentals you learn in grade-school math!
Same with power numbers.
Mobile is fine because they cannot have PL1=PL2 or the thermal system will be overloaded, unlike desktop where bricks are used for heatsinks. That in itself is the check for out of bounds TDP limits.
We may be headed to a future in desktops where the case itself is the heatsink. Actually there's a passive heatsink where it is indeed that big. Then you can crank CPU/GPU power to the limit where 1500W wall socket limit will be reached.
I expect Meteor Lake to do great even against Phoenix.
Here is a table about MT performance at different power limits. Link: ComputerBase
As you can see, If you limit the power to 45W then 13900K is the most efficient one and 6+8 13600K is just a bit worse than 7700x.
A monolithic 8C Phoenix should perform better at 45W in this table, not sure by how much.
Increasing the power for 7700x by 20W(+44%) increased performance by just 20%(82% -> 98%), but the chiplet overhead is hardly 20W, so Phoenix at 45W shouldn't be 20% faster unless the supposed N4 process and additional changes makes up the difference. Let's say Phoenix will be 15% faster at 45W than 7700x limited to 45W.
6+8 Meteor Lake should have the same configuration as 13600K and If you check the above table the 13700K with +2 P cores performs only 1% better at 45W, so having only 6+8 is not that surprising for a mobile chip.
Meteor Lake should use Intel 4 and that supposedly reduces power consumption by 40% at ISO frequency or being 20% faster at ISO power.
I made a table based on the above table where I apply Intel 4 gains to Raptor Lake.
13700k at 65W is 100%7600x7700x7900x7950xPhoenix13600K13700K13900K
Performance at 45W69%82%83%84%94%79%80%92%
Intel 4 at ISO power69%82%83%84%94%95%96%110%
Intel 4 at ISO frequency69%82%83%84%94%79% at 27W80% at 27W92% at 27W
Meteor Lake should use Redwood Cove for P-cores and Crestmont for E-cores, meaning higher IPC, so the performance at 45W would be even better than what I calculated above.
P.S. Only today I found out that Meteor Lake supposedly has additional 2 LPE cores inside the SoC, meaning It has in reality 16 cores in total(6P+8E+2LPE). Videocardz
What is the source for this claim again? Seems like high altitude pastry.
Otherwise known as "pie in the sky."
Meteor lake using Intel 4 process. Link or Link
Intel 4 process info where they mention -40% and +20%. Link
I also found this. Link
Actually, It looks like It was at ~2.1GHz. At 3GHz you can still shave off ~1/3 of power or gain ~15% of performance.
I wish they would do that and redesign the enthusiast PC design from the ground up. Hot air circulating in a confined space is just stupid.
For APUs its not the CPU side that is the key, but its always the iGPU.
Till this day, we've always had an APU/SOC that always had CPU more powerful than the iGPU, but we're entering an era, where its the iGPU that is more powerful than the CPU.
And the performance of the iGPU will always define who won this round of competition. Not the CPU.
