Page 227 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
942
858
Wildcat Lake (WCL) Specs
Dies2223
Threads12688
Max Clock5.4 GHz?5 GHz4.8 GHz
L3 Cache12 MB12 MB12 MB
Size96 GB32 GB128 GB
Bandwidth136 GB/s
RTNoNoYESYES
EU / Xe96 EU2 Xe8 Xe4 Xe
Max Clock1.3 GHz?2 GHz2.5 GHz
FlameTail
4,384
2,762
Also the fact that OLED screen on laptops typically have high resolutions (2.8K, 3K, 3.5K, 4K etc...) is a another punch in the gut for OLED laptops battery life.
Reactions: Tlh97 and Thibsie
moinmoin
5,248
8,463
Unfortunately for laptop OLEDs, much of the web uses a light background (i.e., high APL)
That's why I enforce dark mode on my phone and on laptop (through addons injecting CSS if necessary). But very good point that web browsing benchmarks ends up being a worst case for OLED screens if that's not being done. Makes the results pretty worthless.
SiliconFly
1,924
1,284
ikjadoon specifically stated that it was because of offline media playback being included in the test. I assume that means that the laptop doesn't have to actively download the media while playing it. Just a guess here, but does that mean that only the LPE cores and media engine is running and the rest of the CPU cores can shut down in this case?
Even with the CPU & GPU tiles shut down & only LPE cores running, MTL's performance was pretty much disappointing in many of the early test results. I think this is the first time we're seeing MTL beat the competition with such a wide margin in power efficiency. Also, I think we're gonna need a lot more test results just to be sure.
Hitman928
6,755
12,501
If you watch the whole review, it's not a good showing. This is the same Asus laptop that other outlets have reviewed and it looks like Kitguru didn't get the updated firmware for the laptop because the performance is really bad, much worse than it should be. It does get decent battery life but that comes at a severe lack of performance and is also thanks to a larger (75 WHr) battery and a screen that can't go very bright so it saves some power (for an OLED at least). The battery life looks better than it is next to Kitguru's other laptops because the other top laptops they are comparing it to all come with discrete GPUs which decreases battery life. They don't have a single good comparable laptop in their review against contemporary laptops. This is not a good example for MTL. They should at least update the firmware and test again.
mikk
4,333
2,414
Maybe the known Asus regression from one of the last Windows/My Asus updates other people wrote about which affected several other tests like this one.
MyASUS is driving me crazy. The damned software keeps thinking my laptop is in battery saver, lowering the refresh rate and slowing the CPU. I'm going to try reinstalling Windows.
It looks like Windows updates are the culprit here, and @Microsoft's broken updates have murdered the performance of my brand new laptop to the point a 9th generation product is beating a 14th generation Meteor Lake CPU.
And I think you should check some results.
Windows update seems will keep the CPU in the battery saver mode for Asus laptops, it will reduce freq and perf.
It seems to appear in your result too, like this one.
DavidC1
2,187
3,340
Could be that as well. Either way, there's obviously something very wrong going on with their review unit.
At this rate, we'll have Lunar and Arrow before Meteorlake gets properly benched.
Lunarlake is a much more sensible design. The system level cache will actually do it's job in reducing SoC power, and Skymont acting like a mix between LPE core and E core is much better for power consumption too. It should be able to cover higher performance points than the LPE core, and it's on the same die for faster communication.
A dedicated core stack to save a mere 0.15W, I mean that's not far from a flop on your face.
mikk
4,333
2,414
What does 'design win' mean?
Also I am skeptical about LNL coming in September. That leaves MTl only like 9 months to shine?
It means Laptop models. However it's not clear to me what Intel compared, the entire MTL lineup or maybe just the U-lineup? And then we have to keep in mind MTL is not a full volume mobile launch, for Intel it's limited.
Sry let me CRT that statement, in may you will see some official performance numbers in one event.. and sep at innovation day it is released and available
He also said ARL-S "K" will be available in November and launch possibly in October. Non K ARL-S and mobile ARL next year. Basically a repeat of ADL-S and RPL-S.
Kepler_L2
1,093
4,714
He's probably referring to the Windows 12 launch event and all the "AI PC" shilling that will ensue.
Tigerick
942
858
LNL-U (4P+4E with integrated GPU) are mostly sitting on top of MTL-U (or ARL-U in the future due to 2P+8E). I think they will co-exist for a while....
Abwx
12,034
4,995
Khato
1,382
491
I imagine it's confusing for Intel to have notebooks available at launch when competitors 'launch' months ahead of actual availability. If it's any consolation, that more 'normal' delay is present on the majority of MTL based designs that were displayed at CES.
I will be amused that the 3x design wins for LNL was misinterpreted, though that's par for the course with leaks.
19,218
Looks like this will be Intel's Lakefield experiment 2.0, just on a wider scale than their previous short-lived effort. I think 3.0 is where they finally get it right. So Lunar Lake.
mikk
4,333
2,414
He is clearly talking about Lunar Lake, no idea how you got to a Windows launch.
Technically it's LNL-MX.
Where are the MTL design wins.?.
So far there were only some experimental laptops from two or three brands, basically that s a paper launch in disguise, so 3 x the designs wins means nothing at this point.
Experimental? 2-3 what?
Meteor Lake: https://geizhals.de/?cat=nb&xf=6752_Core+Ultra+100
Hawk Point: https://geizhals.de/?cat=nb&xf=9690_Hawk+Point
You see the difference? Did you confuse AMD with Intel when you talk about 2-3 experimental laptops? You can brand every laptop generation from AMD to a paper generation when you talk like this.
Reactions: controlflow
Kepler_L2
1,093
4,714
Windows 12 launch will include HW shilling for "AI PCs" like Lunar Lake, Strix Point and X Elite.
Reactions: Ghostsonplanets
trivik12
354
324
During CES we have laptops from all major vendors Lenovo, Dell and HP apart from Samsung/LG as well. Best buy has 11 laptops on sale and few more coming soon. Paper launch is Hawk Point. I have not seen a single laptop available so far 2 months after announcement.
Abwx
12,034
4,995
There s not a single review at NBC, generaly they get samples from europeans and US offerings from big names once the devices are launched, if anything that s telling.
As for Hawk Point it will land first in hand held devices but there s already laptops available in France, and that s a country wich is generaly late in big names offerings.
Abwx
12,034
4,995
Most intel offerings are directly from manufacturers while AMD s ones are all from retailers, manufacturers offerings of Hawk Point are not listed even if they also sell those AMD s devices, so that s a hint that MTL is not more common than Hawk point despite the latter being launched later.
Tigerick
942
858
Yeap, WiAdows 12 is pretty big launch for 3 CPU makers, any ideas how many TOPS LNL is having? Based on Pat saying PTL is having 2X TOPs, I am expecting around 30 TOPS?
