Page 222 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
Wildcat Lake (WCL) Specs
Intel Raptor Lake UIntel Wildcat Lake 15WIntel Lunar LakeIntel Panther Lake 4+0+4
ModelIntel 150UIntel Core 7 360Core Ultra 7 268VCore Ultra 7 365
Dies2223
Threads12688
Max Clock5.4 GHz4.8 GHz5 GHz4.8 GHz
L3 Cache12 MB6 MB12 MB12 MB
TDP15 - 55 W15 - 35 W17 - 37 W25 - 55 W
Memory128-bit LPDDR5-520064-bit LPDDR5x-7467128-bit LPDDR5x-8533128-bit LPDDR5x-7467
Size96 GB48 GB32 GB128 GB
Bandwidth83 GB/s60 GB/s136 GB/s120 GB/s
RTNoNoYESYES
EU / Xe96 EU2 Xe8 Xe4 Xe
Max Clock1.3 GHz2.6 GHz2 GHz2.5 GHz
NPUGNA 3.017 TOPS48 TOPS49 TOPS
These documents which are leaked by yuuki_ans seems imply the Hyperthreading(SMT) is still there in the ARL P core, but it cause some mobo function like M2 SSD misfunction the SMT was turned of on initial ES ARL SKUs.
Some terminology/key words are expunged(by yuuki_ans?) and leave blank, but it is easy to guess though.
I’m understanding it a bit differently, I’m reading it as the 8c 8t P Cores(“IA cores”) are disabled in bios due to instability bug with only e cores enabled
I’d also like to point out this is “pre alpha” probably for power on and early validation. So it is not ES1 or ES2. Assuming it says 3.5Ghz, that is quite good for Skymont E cores on such an early chip
If 144C require 360W it doesnt make sense to cram 288C for this TDP, that s silicon waste as long as it s with the same process.
Bergamo is around 400W. So, SF 288C can comfortably go up to 450W which should be quite sufficient.
It does look like only HT has been turned off rather than a specific ST only design. Welp, I guessed as much last year.
It's been shown before Skylake/ADL without HT gains ~24% (outliers 31%) for ST. Since the MT gains aren't as large as Zen's ofc it means Intel's has a bigger loss in MT mode for the 1st thread and 2nd thread. Since Zen is able to keep higher rates for the 1st and 2nd threads and only gets ~12% w/o SMT. Zen would have more too lose so this cheap trick won't work for Zen. Sooner or later HT will have to return imho.
That's what the E cores are for, and ARM CPUs doesn't use SMT but is still competitive in MT
LNC is a grounds up new design. So, HT hasn't been turned off. It was never implemented. Starting with LNC, they're trying to follow the likes of Apple Silicon which offers higher performance without HT or SMT. So, HT isn't coming back.
And considering the numerous cores CPUs have these days, HT doesn't make sense anymore. HT is purely for MT gains, and it offers performance benefit only when all the existing cores are already maxed out. HT based thread context switching is significantly faster when compared to a OS based context switch. That is it's sole purpose. Throwing more E cores into the mix and improving the performance of E cores should take care of MT perf without HT. Keeps P core design neat & clean.
Also, I remember reading that the new LNC P cores are going to be larger than RWC P cores! Don't know how far it's true, but looks like that might be the case. LNC's primary focus seems to be ST performance more than MT performance.
If it's MTL-U refresh on intel 3, then it's not worth anybody's time. 🙁
Eh.
What actually sucks is that it’s MTL, not Intel 3. That part is interesting. Should see see real performance/watt and density gains. Not enough to take away from the primary issue with MTL — or ARL’s crap — but still. Academically interesting.
Since Intel 3 is refined Intel 4, clock speeds should be higher. That said I am not sure about Intel's strategy here. Anyway we will know details probably around September when Intel On event is hosted.
I personally wouldn't think of calling those monster P cores whose size was the reason to introduce E cores to begin with "neat & clean". Also I find it really odd that HT gets removed but the design apparently is not redone enough to make the area usage any more efficient.
I would not be surprised if SMT circuitry is still there. Remember when they told us they had removed AVX512 transistors from Lakefield?
Knowing that Lakefield was going to have to take the lowest common denominator from the two core designs, Intel probably should physically removed the very bulky AVX-512 unit from the Sunny Cove core. Looking at the die shot, it's still there - there was some question going into the recent disclosures as to whether it would still be there, but Intel has stated on the record repeatedly that they removed it. The die shot of the compute silicon shows that not to be the case.
...I find it really odd that HT gets removed but the design apparently is not redone enough...
Wrong. LNC is a grounds up new design started under Keller's supervision. So, HT hasn't been "removed". It was never implemented. Starting with LNC, they're trying to follow the likes of Apple Silicon which offers higher performance without HT or SMT.
Don't you think it's highly worrying that LNC is supposed to be a ground up new design but supposedly already larger than RWC?
