Page 770 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
919
834
Dies2221
Threads8688
Max Clock3.8 GHz?5 GHz
L3 Cache6 MB?12 MB
TDP7 WFanless ?17 WFanless
Size16 GB?32 GB24 GB ?
EU / Xe32 EU2 Xe8 Xe12
Max Clock1.25 GHz2 GHz
NPUNA18 TOPS48 TOPS100 TOPS ?
5,118
4,605
Question for 100 points. Is PantherLake a new core or slightly improved or the same as LionCove? Is NovaLake a different core than the one in Panther? Good question.
Panther Lake has cougar cove which is a Lion Cove+ with various fixes including different RTL and it is slightly smaller than Lion cove with 5-8% IPC Improvement on 18A.
Nova Lake and Diamond Rapids contains panther cove or coyote cove(renamed due to confusion with client product Panther Lake) which is multi sourced from 18AP and N2. This is a brand new core with APX/AVX10.2 and bunch of other extensions and stuff. DC panther cove has HT
AMDK11
484
422
NovaLace is supposedly CuguarCove from what the P-Core engineer said recently. As for NovaLake, I assumed it was a new core but I wasn't sure about PantherLake but I also suspected it was something like LionCove or its improvement.
dullard
26,185
4,841
I am very eager to see how 18A performs.
The latest that I've seen is this:
Intel claims that its 18A fabrication process delivers 25% more performance at the same voltage (1.1V) and complexity, as well as 36% lower power at the same frequency and voltage of 1.1V for a standard Arm core sub-block compared to the same block fabricated on Intel 3 process technology. At a lower voltage (0.75V), Intel 18A provides 18% higher performance and 38% lower power. In addition, 18A consistently achieves 0.72X area scaling compared to Intel 3.
https://www.tomshardware.com/tech-i...y-more-performance-lower-power-higher-density
It wouldn't be too hard to extrapolate from there.
Fjodor2001
4,423
663
Is there any known CPU from AMD to counter the 52 core NVL-S CPU?
Also, do we expect the high core count versions of NVL-S to keep idle power consumption as low as on 285K, or will it suffer from having more tiles/CCDs like Zen5 does in that regard?
Markfw
May 16, 2002
27,360
16,193
Is there any known CPU from AMD to counter the 54 core NVL-S CPU?
I don't know what a nvl-s cpu is, but either my 64 core Genoas or my 64 core Turin I am sure would compete.
MS_AT
913
1,828
Strix Halo solved the problem for AMD. No reason Intel should have the same problem even if using multiple compute dies.
Reactions: 511
Fjodor2001
4,423
663
Now you know:
52 cores though, and on regular desktop socket. So not comparable to Genoa/Turin which are server CPUs. So the question is what AMD has planned to counter it on regular desktop socket.
Fjodor2001
4,423
663
You mean Strix Halo solved the high idle power consumption problem with Zen5? But that was only up to 16C.
Or will the same solution work for AMD if they intend to provide core counts close to the 52C NVL-S?
coercitiv
7,447
17,752
Zen CPU have high idle power consumption due to their IOD interconnect. Intel has a different approach, as you should have observed from MTL and ARL.
Core count is of little relevance, idle power is influenced by interconnect tech first. On mobile, AMD moved from 8 to 16 cores in one generation and their idle power went down, not up.
Reactions: lightmanek
MS_AT
913
1,828
It's the same setup as desktop, 2 CCDs and 1 IOD. They replaced high speed serial interconnect with lower speed "sea of wires", the same idea that drives HBM power savings vs GDDRx. Since new CCDs will have 12 cores, they should have the same power draw for 24 cores total. Now if you they add more dies, this will push power up, but it should still be better than current 30W idle on desktop Zen5 parts, seeing Halo can idle in ~8W range. Assuming linear scaling it would be 16W for 48 cores but I am making this up;)
Markfw
May 16, 2002
27,360
16,193
Now you know:
n you say "threadripper". Since I have multiple of these in my house using home desktop cases, it qualifies right there.
eek2121
3,458
5,105
Now you know:
I find it hard to believe that this will be a desktop part. 52 cores at 230W = 4.42W for core on average. Possibly an HEDT part, if it even drops. It doesn't make sense in terms of economics or power/performance. The math also doesn't work out in terms of node shrinks. Sure, they can juice the power limits, but they have been burned by throwing power at the problem several times now, so I will be surprised if they try that one again, especially with how much money they are losing on the 14xxx/13xxx stuff.
I can see them staying at 24, or moving to 32 cores, but above that? Much more money for very little gain.
As AMD appears to be moving to 24 cores on the desktop, 32 cores would be the safe bet for a non-HEDT based Intel part. Of course, Intel could definitely drop an HEDT 52 core part, and if they execute properly there, they'd eat AMD alive. I'm actually hoping that is the actual case. Intel: give me a reason to own an Intel chip again, please.
Markfw
May 16, 2002
27,360
16,193
Quoted since this is the part I agree with fully !
edit: BTW clarifications. at least 16 core, same or lower power as 9950x, and uses avx-512 to the same extent as the 9950x. No shortcomings to that chip, but better somewhere.
Reactions: eek2121
poke01
4,606
5,916
You will be waiting a long time especially for gaming and server needs. AMD rules this space now.
OneEng2
958
1,172
The standard Zen 6 desktop will likely top out at 24c/48t (2 x 12c CCD). Beyond that, I believe that more memory bandwidth will be needed. AMD's solution for higher bandwidth is to make a multichannel desktop for HPC (Threadripper). I suspect that this is how AMD will compete with the 52 core Nova Lake. I also wonder how Intel intends to feed such a monster?
It doesn't seem cost effective to create so many cores for the masses, and I am guessing it can't be fed with just dual channel memory either.
Ding ding ding!
Can they feed a 52 core chip? If they give it more memory channels, then it isn't really a consumer desktop chip any more (and it would be priced accordingly). It would be a Threadripper competitor..... which I believe it may well be.
There is also cost to consider. Can Intel really afford to build a 52 core chip for the masses on 18A? Seems like an awful lot of money to be spending on all those cores that most people (90%) will never use.
511
5,118
4,605
Not server with GNR there is very dependence on your workflow gaming is X3D or nothing 🤣.
In the end it will come to price if they are selling this 52 Core chip at $1000 I think it would be a great buy especially with the bumped up memory spec we will get with NVL not to mention a 52 Core chip with APX/AVX-512 if they don't mess up.
There is 4LPE Cores in arctic wolf for exactly this purpose.
Reactions: DKR
Markfw
May 16, 2002
27,360
16,193
If Intel sells a decent 52 core chip with at least 6 memory channels, I will buy it in a second. The chances of this happening ? ZERO
511
5,118
4,605
Chances of Six memory channels is zero but
You should look at memory speed as well along with Channels.
A good example a 7980X(64 Core) has 4 Memory Channels with 5200MT/s is roughly 166GB/s with Nova Lake I think they would bump up to 7200MT/s or 8000MT/s DDR5 which would roughly translate to 117/128 GB/s approx 77% of bandwidth of the thread ripper that is before any OC.
I would not be surprised with people breaching 10000+ MT/s and equalling the bandwidth of the threadripper
fastandfurious6
837
999
here's why zen6 (tsmc n2) will eat intel A18:
Turin (Zen 5c) is ~20% faster than Intel 3 xeon (AFAIK the only intel 3 product?)
Underlined the models with same core count (128)
mark my words: basically intel A18 will be catching up with zen 5 on all segments
mobile
desktop
server
A18 maybe ~10% faster than zen5 in some cases but wont compete with zen6
Reactions: Tarkin77
Fjodor2001
4,423
663
That’s high-end desktop which is a much more expensive platform and on a different socket than regular Zen5, i.e. not regular desktop. So not really comparable, since Nova Lake S will be on the regular LGA 1954 desktop socket according to the article I linked to previously.
Markfw
May 16, 2002
27,360
16,193
actually, I think you are missing the point. What I have uses regular SP5, its all real servers. The motherboards I buy just fit desktop cases. They are regular production too. Look up supermicro H13SSL-N its even at desktop prices, Fits Genoa and Turin processors. I have 9 of them.
MS_AT
913
1,828
To be fair I would expect Zen5 TR chips to support 6000MT/s what gives 192GB/s. The problem with 8000MT/s+ parts is that they are more expensive, harder to setup if you want to scale capacity. I mean it would look a bit silly to have 12000MT/s 32GB memory with 52 core chip;) But who knows, maybe 2DPC at 8000MT/s+ will be easier to achieve next gen.
Reactions: coercitiv
coercitiv
7,447
17,752
This happens when one invents a solution in search of a problem: the high core count CPU with low idle power and high speed dual dimm configuration. This time the 100W TDP target is optional.
Personally I hope their intent is to bridge towards the HEDT market, but this will obviously come at a higher price. Some professionals are looking for something not quite as expensive as HEDT.
Reactions: lightmanek and 511
511
5,118
4,605
i think this part is mostly solved in terms of their initial specs LP-E cores for light task i think with proper scheduling NVL HX laptop can easily be in the same league as Strix Point/ARL-H laptop in terms of battery life. For High SPeed DIMM we are getting a new platorm it's totally expected on past history and with CU-DIMM we will get 8000 MT/s and High Core Count is expected. This time they planned very nicely lets hope they don't F*** up the implementation part.
Yeah same but i think it will still be cheaper to buy the newer part.
Reactions: DKR
