Page 769 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
940
852
Wildcat Lake (WCL) Specs
Intel Raptor Lake UIntel Wildcat Lake 15W?Intel Lunar LakeIntel Panther Lake 4+4+4
Dies2223
Threads12688
Max Clock5.4 GHz?5 GHz4.8 GHz
L3 Cache12 MB12 MB12 MB
Size96 GB32 GB128 GB
Bandwidth136 GB/s
RTNoNoYESYES
EU / Xe96 EU2 Xe8 Xe4 Xe
Max Clock1.3 GHz?2 GHz2.5 GHz
MS_AT
927
1,848
Yeah, I know. But I figured it should give at least some indication of how well the CPU performs with video transcoding in general. If it performs well with video transcoding at peak performance / max TDP (as used in that test), and it has a sweet spot at around 100 W (after which more watts does not give much more perf), then I figure it's likely to have good video transcoding perf and perf/watt at 100W also.
I've not been able to find any comparison of video transcoding performance at ~100 W between 285K / 14900K / 9950X(3D). But if someone has found any such comparison, please share. Ideally for x265 video transcoding, since that's probably what I'll do most of.
Well, then outlets I was able to find quickly, if tested at normal TDPs put Ryzen ahead https://www.phoronix.com/review/amd-ryzen-9-9950x3d-linux/7 https://www.techpowerup.com/review/amd-ryzen-9-9950x3d/11.html https://www.tomshardware.com/pc-components/cpus/amd-ryzen-9-9950x3d-review/3 but it's hard for me to comment how sensible these benchmarks are, still if you were wondering about an indication. Oh and here notebookcheck has power scaling tests in Cinebench 23/24 between 9955hx and 275hx at the bottom of the page, covering the points that might interest you if only to give some +/- estimates (still as I said, they are rather weak proxies) https://www.notebookcheck.net/AMD-R...ttle-for-the-fastest-gaming-CPU.989996.0.html
For more detailed x265 benchmarks you could try to look for some dedicated x265 / encoding message boards.
alcoholbob
6,390
469
Rumors are no stacked cache until the successor to Nova Lake too. Which means Nova Lake is probably gonna be Arrow Lake 2.0. Gonna get rolled in gaming and most practical workloads and will exist to win all-core benchmarks like Cinebench, and have horrible power efficiency again even with node advantage. There's probably a reason why they are going all out in core count (16P + 32E). Likely the cores themselves will be uncompetitive in IPC.
5,346
4,759
False NVL has a SKU Planned with 144 MB L3 as for IPC Panther Cove is not a small upgrade and neither is Arctic Wolf I fully expect both to be 20%+ over LNC/Skymont just cause they are increasing core count doesn't mean it is weak was Alder Lake weak?
Reactions: DKR
LightningZ71
2,671
3,371
It would be unlikely for them to not make any effort to address the uncore/fabric issues that Arrow Lake has as well, even if it's largely just increasing fabric clocks everywhere.
AMDK11
490
435
i don't know exactly what's Intel is using for it but it is a 144MB L3 cache SKU for sure in NVL linup btw i have found the reason for Lion Cove's bad PPA it's too funny when i heard about it
Could you please explain to us the reason for the bad PPA of the LionCove core? Is there more to what we already know?
ArrowLake L3 36MB, 84 cycles(14.83 ns), 1.02 TB/s
Zen5 L3 32MB, 48 cycles(8.44 ns), 1.6 TB/s
https%3A%2F%2Fsubstack-post-media.s3.amazonaws.com%2Fpublic%2Fimages%2F152a7e4a-408a-43f6-8df7-4d3e51c4cdc8_1738x405.png
https%3A%2F%2Fsubstack-post-media.s3.amazonaws.com%2Fpublic%2Fimages%2F931a1b2c-d5de-4810-9354-cac419964bdc_772x397.png
https%3A%2F%2Fsubstack-post-media.s3.amazonaws.com%2Fpublic%2Fimages%2Fb2a214eb-2da5-4c87-99b0-8279d5c9e4e5_1034x584.png
Zen5 L3
48 cykli (8.44 ns)
1T: 173.6 GB/s
nT: 1.6 TB/s
LionCove L3
84 cykle (14.83 na)
1T: 57 GB/s
nT: 1.02 TB/s
Reactions: lightmanek
511
5,346
4,759
It was the move to Industry standard tooling so they they messed up the physical design part as the P core team is using Industry standard tooling fir the first time.
Reactions: lightmanek and DKR
AMDK11
490
435
Yes, I knew about the new design tools that Intel had switched to and that were used in the LionCove project, among others. But is that the main reason?
AMDK11
490
435
LionCove has a very good L2 and a pretty good L1-1.5-D subsystem. Maybe L1.5-D could be a bit better but it's not bad. L3 is a nightmare. If the same team that did the LionCove core took on L3 it would be a lot better.
Are there any sources stating which parts of ArrowLake were designed by which team?
5,346
4,759
The interview with the Core team by kitguru they mentioned that they only worked on the core part of the core as for the L3 I think it will be fixed by PTL and by NVL they would improve upon it.
Reactions: DKR and AMDK11
AMDK11
490
435
Thanks for the reply. I'll look into that interview for Kitguru.
Reactions: 511
OneEng2
973
1,183
meh, new socket. Why?
Meanwhile, AMD will release Zen6 on AM5.
I wondered the same thing!
It's way to early to make the call. It's difficult for me to believe Intel would blow 2 launches in a row.
That is what I think as well. If all they do is fix the fabric issues (and get rid of some of the awful latency issues through a combination of CPU and fabric changes), I suspect performance will jump quite a bit.
Intel's been doing 2 gens per socket for so long. OEMs don't seem to mind.
Not sure why you think such a thing? You think OEM's like re-designs? Engineering costs lots of money. I'll bet OEM's like a drop in replacement even more than DIY does!
As an aside, shouldn't we be seeing some leaked Panther Lake benchmarks soon if consumers are to have them in their hands by the end of this year?
511
5,346
4,759
Yes the question is who is going to leak the stuff 🤣 cause I can't wait Strix Halo and PTL are the only two interesting products this Year(For me 18A is the most interesting one but it is a node not a product in the end it will be limited by your design).
Reactions: DKR
OneEng2
973
1,183
PTL for me.
I am very eager to see how 18A performs.
Reactions: DKR and 511
AMDK11
490
435
Question for 100 points. Is PantherLake a new core or slightly improved or the same as LionCove? Is NovaLake a different core than the one in Panther? Good question.
