Page 630 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
920
834
Dies2221
Threads8688
Max Clock3.8 GHz?5 GHz
L3 Cache6 MB?12 MB
TDP7 WFanless ?17 WFanless
Size16 GB?32 GB24 GB ?
EU / Xe32 EU2 Xe8 Xe12
Max Clock1.25 GHz2 GHz
NPUNA18 TOPS48 TOPS100 TOPS ?
Bouowmx
1,150
553
I tested a power limited Arrow lake here:
HT off at the silicon level is such a bizarre move.
If possible, at the system level, can you test whether DLVR Power Gate mode with static core voltage is more efficient?
Kocicak
1,177
1,232
It is not. HT threads were the weakest ones and in the spectrum of all possible loads that CPUs can experience in home PCs they got almost never used. Only the heaviest multithreaded applications used those threads and people running such apps would be better off running a threadripper system anyway. HT is useless today, when you have up to 24 core CPUs in home PCs.
Reactions: Hulk
Saylick
4,099
9,578
Will be interesting to see how the convergence plays out. I have to imagine the size of the E core slowly grows until it basically becomes roughly the size of the competing Zen core, mostly because Intel’s P cores are bloated to begin with (AMD has been able to get similar levels of performance in a smaller die area) and E cores will need a lot more xtors to have feature parity with Zen, namely AVX512, but also clock parity.
cannedlake240
247
138
So if Darkmont is a rather minimal upgrade as has been said, it's fair to expect Arctic Wolf and Golden Eagle (is that the first time this is mentioned?) to be big ones if they have to pave the way for the E core to take over the P core's duties after them.
Maybe the e core will gradually evolve to become larger and larger until Intels final hybrid architecture is just two different P cores but one of them is a lower clocked version of the Unified core, and the next gen could then feature a full fledged high frequency variant
OneEng2
960
1,173
Intel would have to lose for many many years for AMD to get to 50% market share then.
They are certainly working hard in that direction though, don't you think?
Intel seems to be doing enough damage on its own to make that happen. Their 18A better be as promised. The other threat is ARM. I like x86 because of its backwards compatibility. Also the fact that it isn't a "walled garden".
I believe ARL is good enough to minimize the damage, but another 14+++++++++ situation might actually do Intel in to the point of being bought out.
265K and 245K are the same chip as 285K If I am not mistaken.
If there is a supply issue, then only because there are many faulty chips.
I saw that this morning. Smells like a yield issue.
Intel's on a different level when it comes outdoing competition. Wonder what happened to the old Intel. But all is not lost yet. For that we need to wait for (ARL-H) mobile parts.
I agree. A good showing here would be much more important than the flip in the desktop.
19,203
Apparently ARL was pre pat
No. I won't accept the excuse that Pat couldn't do anything with a design that was already in progress. His job was to steer the ship RIGHT.
Arrow Lake and specifically Lion Cove performance tells me:
1) He doesn't care about CPU compute performance which is really weird since he's a CPU architect himself.
2) He's been out of the CPU loop so long (especially due to his previous job at EMC) that he had a talk with the existing CPU architects at Intel, didn't dive technically too deep in those conversations and foolishly trusted them. If that's true, that's on HIM. It is one thing for a fool like BK to run the company into the ground but a senior CPU Architect letting Intel release Arrow Lake with such unbalanced performance is simply inexcusable.
3) The Raptor Lake and Meteor Lake issues speak volumes about his "let the professionals do their work" approach to being a CEO. That approach would be fine for a company that wasn't in trouble but this is not what Intel needed. Intel needed someone like Jensen (yes sad but true) or Lisa Su.
cannedlake240
247
138
Not much he can do a year or 2 before product launch. Intel can't keep refreshing raptor lake or not launch a product for 4 years. But overall, yes Intel design core business isn't in a much better state due to constant layoffs and cancellations and they have zero presence in growth segments like AI.
mpumalanga
20
50
61
"Not much he can do a year or 2 before product launch"
Gelsinger started his return to Intel beginning of February 2021. That is 3.5 years before arrow lake launch.
Might still be too late to radically change arrow lake, but certainly enough time to influence it.
maddie
5,180
5,576
This isn't true. Both threads in a HT core shares the resources. There isn't 1 strong and 1 weak one, or at least not continually. The threads are dynamic.
HT adding, say 30% to throughput does not mean 1 thread is at 100% and the other stays at 30%. It could be 65% + 65%, or any mix within the limits.
19,203
Sorry. Disagree.
Things he could've done:
1) Release Bartlett Lake type of CPU on latest refinement of Intel 7 instead of 14900KS (which was useless because it couldn't sustain high clocks without special cooling due to thermal throttling) with AVX-512 enabled.
2) If Meteor Lake was too much in demand (like he said), he should've tried to improve and fix Intel 4 yields before churning those out instead of incurring a huge loss with hot lots.
3) Intel had working Lunar Lake prototypes in October 2023 yet the laptops were ready for sale only a year later. Being a CPU architect, he should've understood the importance of Lunar Lake over Meteor Lake and sped up the development of the former no matter what. He probably didn't do that because MTL was on Intel 4 and he wanted Intel fabs to keep being utilized. That stupid plan backfired spectacularly on him.
4) He probably cut the funding of the GPU team and slowed down ARC's development to focus on other stuff he thought was more profitable. That was a bad move. We could've had Battlemage six months ago had he not messed with that team by firing a lot of them.
5) Gaudi 3? Pfffttt. How many billions did Intel make from THAT?
Pat's been too slow for Intel. Intel needs someone ambitious with a great sense of direction. Not some old has-been who can't figure out what Intel is good at.
Reactions: Kryohi and Tlh97
511
5,118
4,605
He influenced Granite Rappids and the Nodes and LNL was on him lol also iirc he also started development of Sierra Forest I don't like him that much but he is a lot better CEOs than 3 people before him
I agree with ARL/LNC BK and Pat are in two different leagues in terms of knowledge about CPUs and to think he was the chief Architect of i486
Intel needs someone more like Andy Grove than these guys 🙂
gdansk
4,688
7,925
Do you know anything about Pat? The only reason there are still plans for discrete GPUs is because he is obsessed with Intel having their own graphics that they can eventually scale into DC. Any other CEO would have killed all those plans by now.
He has said in multiple interviews that not having GPGPU in the 2010s was a huge miss by Intel, even before he was CEO.
19,203
That's true. However, ST performance of Raptor Lake improving a bit when HT is turned off (and quite a few gamers have been doing that since Alder Lake launch) means that some resources get statically partitioned so it's not dynamic HT. Turning on HT starves the primary thread of some resources it could've had if HT hadn't been turned on.
511
5,118
4,605
Sorry. Disagree.
I can't disagree on this this is idiocity Bartlett lake should be out for consumers as well
I am pretty sure you don't know much more than Intel on how to run fabs
He fixed Intel 7nm(OG) something both the other CEOs were unable to do what is the point of your fabs if they are empty
Show me the proof for this
Yes Gaudi is the worst bet
And who would that be Intel is an IDM seperation of either design or fab will kill the company no one has that experience outside of few people in running IDMs everyone will try AMD/GF Moves
511
5,118
4,605
That also Not getting the CEO role was the reasons he left if Pat was CEO i am pretty sure Intel would have been on a much better state than rn he kept saying Intel Needed GPUs but MBAs
He need go lay off some upper management
cannedlake240
247
138
He can't do performance simulations ahead of time. Arrow lake is tied to Meteor lake and by the time problems in it's design were apparent they weren't going to start designing a whole new soc in between generations just for the Desktop market. Arrow lakes problems aren't caused by chiplets only. There's multiple things at play. Its already delayed and trying to redefine it would result in further delays. Pats main mistake was cancelling PTL-S which might have been a decent upgrade for gaming by early 2026
