Page 629 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
942
857
Wildcat Lake (WCL) Specs
Dies2223
Threads12688
Max Clock5.4 GHz?5 GHz4.8 GHz
L3 Cache12 MB12 MB12 MB
Size96 GB32 GB128 GB
Bandwidth136 GB/s
RTNoNoYESYES
EU / Xe96 EU2 Xe8 Xe4 Xe
Max Clock1.3 GHz?2 GHz2.5 GHz
poke01
4,850
6,183
Intel seems to be doing enough damage on its own to make that happen. Their 18A better be as promised. The other threat is ARM. I like x86 because of its backwards compatibility. Also the fact that it isn't a "walled garden".
A bit off topic but ARM isn't a walled garden. You can get ARM worksations from System76 with upgradeable CPUs/GPUs/RAM which run Linux. Its just no one cares about Windows on ARM because Qualcomm had an exclusivity period with MS. Apple's idea of ARM computer is different from others like System76.
In the future who knows a RISC-V/ARM core might be so powerful that even with a 20% emulation hit its still faster than then contemporary x86 designs.
CakeMonster
1,662
843
I can understand Intel being in a challenging situation with their initial product on a re-design, and waiting for their own next node and higher prices at TSMC. But they better be able to iterate on this quite quickly and steadily to keep gamers interested.
TESKATLIPOKA
2,696
3,260
Not speaking demand, but 285k seems having supply problem which 265k/245k don't have. It may reflect the cost issue of ARL though.
265K and 245K are the same chip as 285K If I am not mistaken.
If there is a supply issue, then only because there are many faulty chips.
Kocicak
1,177
1,232
I tested a power limited Arrow lake here:
lopri
13,329
709
1.480 Vcore is in my opinion too much for Intel 7, much less a smaller node, under ambient for day-to-day use. You are practically begging for degradation. Everybody has a different opinion but I keep my 14900K under 1.3V and it's generally under 1.2V when under load.
This person got a great sample and is pushing it to the limit. It's great to show what ARL can do but not really useful for people that want to use these CPU's for longer than a few weeks.
From what I have seen online 1.4~1.5V (transient) is not an outlier. I think Ryzens do it, too.
But what I cannot get my head around is how 1.5V/250W is only reporting 80C max temp.
inf64
3,884
4,692
It looks like intel will be in the rear view mirror even after Panther Lake, especially in gaming. It's sad since this means AMD will be commanding the prices for their X3D parts which will be priced higher than most of us would like to see. It was a solid opportunity for intel after flopped Zen 5 launch, but they managed to out-flop AMD with this one.
mzocyteae
26
19
Surely AmpereOne is not a walled garden, but it pretty much isn't a valid choice as a desktop/workstation:
1. Low availability - few MB choice and retailers despite the cpus are launched long ago.
2. High cost - list price is way too expensive when comparing to msdt; total system cost won't be much better than epyc.
3. Questionable performance: lack of review (and MT/power is not promising); doomed ST; lack of cpu 2017 submission.
4. win32/linux binary support: some oss projects exists, but in they definitely can't do as well as wine or vmware workstation.
Maybe 1 & 3 will get better in the future, but 2 & 4 is unlikely.
majord
509
711
but I thought AMD were " never again to be in the windshield" : :p
poke01
4,850
6,183
whats more interesting, is your username over at TPU.
I love it lol
DAPUNISHER
32,412
33,392
265K is the more desirable part anyway isn't it?
And should be easier to bin.
I do not think that word means what you think it means. :p In retail it is going to collect dust with the Zen 5 parts. All these latest generations from the IHVs have done is help sell the older SKUs. Going to take a significant price drop to move them. It would also be a BIG help if Intel would confirm 1851 isn't one and done.
poke01
4,850
6,183
Interview with David Huang.
these answers are interesting:
Q: I have a question. In the Luna Lake performance review posted a month ago, the Luna Lake 258V was about 12% faster than the Meteo Lake using the same clock speed Redwood Cove. But why did Arrow Lake only improve by about 2% compared to the previous work? Shouldn't Arrow Lake show better performance than Luna Lake in terms of IPC? Can you explain the reason to me?
A: Luna Lake's L3 latency is much better than this.
Q: In the case of Luna Lake, is IPC better because the L3 latency is much lower than Arrow Lake? However, I personally don't understand that the IPC improvement is only 2% compared to the previous work when considering the expansion of the interior of Arrow Lake's architecture.
A: The L3 latency of Luna Lake and Rapter Lake is about 55 cycles, while Arrow Lake (265K) is about 73 cycles and Meteo Lake (155H) is 80 cycles.
Q: I wonder how the result came out with such a low result. And why does Arrow Lake perform well on benchmarks like Cinebench R23/R24 or Geekbench?
A:Cinebench and Geekbench are mostly executed within the L2 cache. SPEC is generally much more sensitive to cache and memory.
tsamolotoff
261
512
is this even explicable? )
There can be wildly different results depending on the test used, i.e. there is a popular canned benchmark in the steam workshop that many reviewers use which shows high FPS for almost any CPU and is basically a gpu benchmark while others (i2hard for example) use real-world demo files that were recorded during WGL championships or other high-ranking events where _sometimes_ CPU is more of a limit. Also, CS2 unlike CSGO has some particle effects processed via GPU now so the FPS lows might be actually caused by GPU, not CPU now. Also, if you use several monitors DWM sometimes breaks down and this tanks your FPS considerably as Windows attempts to sync game with DWM which leads to characteristic 'saw line' frametime which can easily noticed when you do tests manually, but it naturally would pass unnoticed while using automated benchmark tools.
