Page 482 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
Wildcat Lake (WCL) Specs
Intel Raptor Lake UIntel Wildcat Lake 15WIntel Lunar LakeIntel Panther Lake 4+0+4
ModelIntel 150UIntel Core 7 360Core Ultra 7 268VCore Ultra 7 365
Dies2223
Threads12688
Max Clock5.4 GHz4.8 GHz5 GHz4.8 GHz
L3 Cache12 MB6 MB12 MB12 MB
TDP15 - 55 W15 - 35 W17 - 37 W25 - 55 W
Memory128-bit LPDDR5-520064-bit LPDDR5x-7467128-bit LPDDR5x-8533128-bit LPDDR5x-7467
Size96 GB48 GB32 GB128 GB
Bandwidth83 GB/s60 GB/s136 GB/s120 GB/s
RTNoNoYESYES
EU / Xe96 EU2 Xe8 Xe4 Xe
Max Clock1.3 GHz2.6 GHz2 GHz2.5 GHz
NPUGNA 3.017 TOPS48 TOPS49 TOPS
ST is around expected I think.. MT score is bad , it would want to be a bad run or something for their sake.
Nothing else really stands out.. Probably most interesting thing now will be IGP performance. Since that's the other thing they promised it would excel in
Right but Intel’s own slide is saying they get 1.165x the ST score of the HX 370, which has a score ranging from 112-116. That comes out to 130-135. The scores also match somewhere within the 1.0526x the X80-X84: 124-128.
I don’t think it’ll be that high (135) but they’ve put it out there that it could be. So a 127 is plenty reasonable for the 268V.
Spotted this. Not sure what to think of it, but kinda jives with what I was pointing out (could just be throttling, but that still seems too low).
Does this XPS have a fan?
No it's just what to be expected from max 17w soc. Those 700-800 results would have only possible without powerlimits consuming about 100w.
It can go up to 30W though. It’s obviously going to be less than the HX 370 in MT, because of core count. But at 28W if the HX 370 can get 919, I don’t see why the 268V can’t get in the high 600s.
All HX 370 12 cores have SMT, that s a big difference.
50% more cores + 30% SMT amount to 2 x the core count, so it can score roughly 70% better at a same 33W.
Beside the 8945HS@37W score 852 pts, so Hawk Point should have no trouble scoring 600 pts at 17W while the 286V require 30W to do so, if not with a turbo at 37W.
50% more cores + 30% SMT amount to almost 2 x the core count, so it can score roughly 70% better at a same 33W.
You’re being very generous about that 30%. It’s obviously workload dependent but I’ve seen half that number quoted as well. But that’s also the whole purpose of Skymont. It is to negate the loss of 15-30% performance. Hence why you’ll see the 285K still do quite well in MT tasks.
No it can't max tdp for 268v is 17w.
See timestamp 05:26
We need to manually set Power limit rn it is driven by Dynamic Tuning driver we want the values to be static to properly examine the performance
See yourself. Even 17w is a lot for proper thin&light laptop and configuratoon limits for LL is 8-17w. 288v is outlier for non thin & light use cases.
What do you mean see for yourself? I watched it that’s why I attached it. You said the 268V can’t go up to 30W. I said it can. The video says that it can.
Video is mixing ultra9 to 5 and 7. U9 can go up to 30w, others up to 17w. See that table you posted.
Video is mixing ultra9 to 5 and 7. U9 can go up tp 30w, other up to 17w.
The guy literally says it’s a Core Ultra 7 running at 17W and can go up to 30W. Nothing is mixed up.
Here’s more evidence:
That says max turbo power is 37W!
Yes. But that’s not what you were saying. You were saying 17W was a hard limit. Despite me showing it wasn’t numerous times.
For cinebench mt result only tdp matters. You expected something other than 17w tdp mt results and were disapointed. 17w tdp is limiting those results.
Power envelopes are listed in the official specs
I get that the TDP is 17W. But that’s not the point of contention here. There are likely some points in those tests that there are spikes to 30W if configured for it. My whole argument was that it can hit 30W that’s it. I don’t see why we’ve had to go back and forth like 4 times about that.
To me yes 479 is a very low score considering people are framing LNL as an M3 class chip. An M3 does 650 in MT. Perhaps because of throttling, and the sustained 17W what I was saying about scoring high-600s is too much. I’ll admit that.
People are expecting way too much. That 17w tdp is probably also lowering st score so that explains why results are bit lower than just scaling 288v down. Apple cpu cores are still miles away for efficiency.
Are we expecting 288V to get close to M3 in MT?
It uses 30 watts as well in Cinebench R23. Intel's Skymont E-cores are more powerful than Apple's so it might.
People are expecting way too much. That 17w tdp is probably also lowering st score so that explains why results are bit lower than just scaling 288v down. Apple cpu cores are still miles away for efficienE
Expecting too much in reference to what?
