Page 473 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
Wildcat Lake (WCL) Specs
Intel Raptor Lake UIntel Wildcat Lake 15WIntel Lunar LakeIntel Panther Lake 4+0+4
ModelIntel 150UIntel Core 7 360Core Ultra 7 268VCore Ultra 7 365
Dies2223
Threads12688
Max Clock5.4 GHz4.8 GHz5 GHz4.8 GHz
L3 Cache12 MB6 MB12 MB12 MB
TDP15 - 55 W15 - 35 W17 - 37 W25 - 55 W
Memory128-bit LPDDR5-520064-bit LPDDR5x-7467128-bit LPDDR5x-8533128-bit LPDDR5x-7467
Size96 GB48 GB32 GB128 GB
Bandwidth83 GB/s60 GB/s136 GB/s120 GB/s
RTNoNoYESYES
EU / Xe96 EU2 Xe8 Xe4 Xe
Max Clock1.3 GHz2.6 GHz2 GHz2.5 GHz
NPUGNA 3.017 TOPS48 TOPS49 TOPS
So this was FUD too?
@OriAr
Since when? That's news to me.
This is just one system for example, Supermicro has a bunch of them available in varying configs.
GNR-AP is also launching this month iirc, at this point I am fairly confident Intel 3 is yielding very well.
The Supermicro systems aren't available yet, they are listed but are "coming soon". Not sure when the projected date of availability is but I imagine it's not too far out.
This one is seemingly available now, I imagine the rest will come sooner rather than later.
I found the SuperMicro SYS-112C-TN, but I don't see anywhere to actually buy one? There are two other Sierra Forest server SKUs listed as "coming soon".
The closest I found was this:
They let you request a quote, but click/buy/ship? Nah.
It's like IceLake-SP all over again!
The incorrect interpretation of what's being said in the quoted source is, yes.
All the source post is saying is that if 3 hours are spent performing optical inspection of an Intel 3 EUV layer with the parameters provided in the table then a 1cm^2 die which 'passes' that optical inspection would be at least 62-63% yield rate for that layer. The post says absolutely nothing about actual Intel 3 yield rates.
Pretty sure it's not actually available either. If you look at the older models, you can actually configure and buy them from the website. Even that one you linked, all you can do is put down your info to be contacted for pricing. I'm not convinced it's a yield issue though, very well could just be that Intel 3 is still ramping and all available stock is going straight to the cloud companies (Google, Amazon, etc.) for the time being.
Okay. Yeah, AMD's Data Center revenue and margins are increasing but it's entirely due to their small piece of the AI pie.
If you instead go with the Mercury Research figures for market share and revenue of x86 server CPU between Q1 2024 and Q1 2023... AMD market share increased from 18% to 23.6% for a 31.1% increase while revenue share increased from 27.8% to 33% for an 18.7% increase. Yeah, I know, kinda puts a damper on the favored narrative that AMD is dominating in the server space that their market share is increasing more than their revenue share. aka, AMD server ASPs are decreasing while Intel server ASPs are increasing.
I'm confident in the accuracy of the narrative. Some people feel the need to correct the record but MI300 isn't causing Intel to reduce their operating margin and lower their DC forecast. That's Epyc.
Moreover the Mercury estimates you give are from a quarter earlier. Notably missing the quarter where INTC dropped 50%. Mainly on the foundry failures but also due to their revised, downward, outlook.
Epyc is at 36±2% x64 server market revenue in Q2 with a 38% YoY growth.
It places an upper bound on what yields could be for the process, if in fact the statement is true.
No it most definitely does not.
I see no reason to doubt the statement is true, but it's just based on published metrics for the Intel 3 process. And it's just providing an example of the problem with optically scanning for defects on EUV layers.
Let me try to explain again. After all the lithography steps are taken for a given EUV layer the wafer can be optically scanned for defects. The statement is that if 3 hours are spent performing that optical scan and no defects are found, that optical scan only provides confidence that there are no defects in 62-63% of the 1cm^2 die. If less time was spent on the optical scan the confidence rate would be lower. More time spent would give a higher confidence rate. It says nothing about actual Intel 3 defect density.
The most elementary maths tell you that if you hold 33% of the revenue for 23.6% volume marketshares it means that your ASP is 33/23.6 = 39.8% higher than the one of your competitor.
And since the revenue % increase without the volume % matching this number it also means that your competitor is selling at prices increasingly lower, if that s what you re calling higher ASPs for Intel so be it.
Yes, it is simple math. AMD went from 27.8/18 = 54.4% higher ASP to 33/23.6 = 39.8% higher ASP. Nowhere did I claim that Intel's ASPs are higher than AMD. Though I should have said that Intel server ASPs are increasing more than AMD serverASPs over that time period rather than stating that AMD server ASPs are decreasing. I'd guess that they are, but that can't be determined by just the percentage numbers.
Why are you tricking the numbers.?.
18% is the evolution, i explicitely said revenue/marketshare in volume.
But you got right in a way, if AMD revenue increased by 18% in a same revenue TAM and that Intel has the same volume marketshare it means that Intel s prices decreased by 1 - 1/1.18 = 15.2% lower ASP.
I'm not. According to the Mercury Research data, AMD's server unit share in Q1 2023 was 18% - https://www.anandtech.com/show/21392/amd-hits-record-high-share-in-x86-cpus-in-q1-2024
I agree it's EPYC that's main killer for Intel's DC group. AI is just cherry on top.
Emerald Rapids performance only allows at best mid-range selling figures. The juicy profits increase greatly as you go up the stack, so Intel is missing out on a big portion of it.
Based on their revenue vs spending for DC group, 33% decline in revenue is enough to get their profits to become zero.
Sierra Forest: Even if it is successful, it hasn't been in the market for long enough to make big enough financial market. Plus it's not the main chip so it further limits the impact.
Granite Rapids can't come fast enough. But with news such as Qualcomm exploring to buy Intel division, their main divisions suggest that Intel's conditions may be even worse than the already gloomy news is.
You divide the revenue share by the volume share and you ll know what is the ASP ratio in respect of the competition.
If one get say 40% revenue share for only 20% volume share it means that his ASP is 2x the one of its competitor.
I did the math for 33% revenue share and 23.6% volume share , and that means almost 40% higher ASP than Intel, what is difficult to understand here..?
And if your revenue increase by 18% without your volume increasing in a market whose total volume and revenue are constant then it means that in the same time your competitor s ASP has decreased by 15.2%, that s also basic maths.
The problem is that the Board wants to do literally anything but spin off the foundry.
Intel's DC division went from $6 and $4.6 billion in Q1 and Q2 of 2022 to $3 and $3 billion in Q1 and Q2 of 2024.
$10.6 billion to $6 billion. That's a huge loss.
Do you know with AMD reporting MI300 selling at $1 billion a quarter it alone has 33% of Intel's entire DC business?
AMD's DC revenue only looks impressive because the MI300 props it up by contributing 40% of the revenue.
Intel DC stuff is almost entirely Xeons, which isn't so hot at the moment.
And then you have NVIDIA whose Gaming revenue is roughly the same as AMD's DC revenue.
Give it a few more quarters - the AI hype will die down, and AMD will have the same hard time as Intel selling mostly Epycs.
Considering what I know about Genoa, and what Turin is supposed to be, Intel may have a problem for years to come, especially if they don't fix their financial problems soon.
EMR is competitive with Genoa at similar core counts, and Granite Rapids will bring performance and core count parity with Turin.
Intel has nothing to worry about.
Just curious, you have benchmarks to back that up ? I have not seen anything.
