Page 440 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
Wildcat Lake (WCL) Specs
Intel Raptor Lake UIntel Wildcat Lake 15WIntel Lunar LakeIntel Panther Lake 4+0+4
ModelIntel 150UIntel Core 7 360Core Ultra 7 268VCore Ultra 7 365
Dies2223
Threads12688
Max Clock5.4 GHz4.8 GHz5 GHz4.8 GHz
L3 Cache12 MB6 MB12 MB12 MB
TDP15 - 55 W15 - 35 W17 - 37 W25 - 55 W
Memory128-bit LPDDR5-520064-bit LPDDR5x-7467128-bit LPDDR5x-8533128-bit LPDDR5x-7467
Size96 GB48 GB32 GB128 GB
Bandwidth83 GB/s60 GB/s136 GB/s120 GB/s
RTNoNoYESYES
EU / Xe96 EU2 Xe8 Xe4 Xe
Max Clock1.3 GHz2.6 GHz2 GHz2.5 GHz
NPUGNA 3.017 TOPS48 TOPS49 TOPS
The average is low because Blender has several cycles, at the start it is idling for 15s and then it goes at full throughput for 3 phases with some interrupts, the 275W are the phases of full throughput, that s not just short peaks as you seems to believe.
For the rest there will be reviews in less than two moths, and we ll surely have some leaks in the meantime, so we ll see how things pan out in the next weeks or so.
So now you ignore point #1 and #2. Okay Abwx, you do you. Changing the goalpost and posting conflicting information isn't making your case though.
Up to 10 ms is the limit of time for power spikes above PL2 unless Computerbase had malfunctioning equipment. That isn't what I personally call a long duration.
Problem is not the 14900K as such, it s that in the 2 ST benchs already known they are below not only this CPU but also below the 9950X, we are no more talking of GB here but of actual browsing perf, so far the IPC in those tests is below Zen 5, i posted them in my previous post and here they are again.
Guess that currently Intel is devising about the exact power they ll use since at 250W they will have a win only in CB R20/R23 for MT, and a marginal one.
They may well set 297W as PL2, or use an extended 297W PL4 since that s their apps performance profile for ARL, otherwise they ll lose in too much benches to be convincing, so we ll surely be good for another round of exagerated TDPs.
And likely that AMD limiting their CPU at 200W has somewhat disrupted their plans as they surely expected 230W, wich would had rendered their own 250W/297W TDP acceptable.
Those aren’t verified real web browsing results. The GB5/GB6 scores are at least tangibly verified.
As far as web browsing performance, ARL seems ahead of Zen 5 in the HTML5 & text processing subtests in GB. Who knows how it ends up when we get actual benchmark results for WebXprt and Speedometer. In the IgorsLab leak, both of those were projected to be up by a decent margin.
He has no clue what he’s talking about.
That was obvious when he confused PL2 and PL4 and then in defense again confused peak power with PL2. I'm just enjoying seeing how deep of a hole he'll dig for himself. The chart of Ryzen frequency over time was the cherry on top--it really proves that Intel is going to 297 W PL2. Somehow.
He has no clue what he’s talking about. Just wants to say competition is better than intel with aome useless numbers.
Let me put it straight. ARL & competition, when it comes to power efficiency, is gonna be in the same ballpark. Overall power usage per hour under normal circumstances is gonna be very similar.
That particular poster has a long history on this forum, going back to the Bulldozer days, of being somewhat shall we say "selective" in his posts and benchmark choices. I thought he had disappeared for a while, but unfortunately he has returned. Trying to have an objective discussion with him is an exercise in futility. Better to just put him on ignore and not waste your time.
I really dont know what "average" means there, because rendering a scene with Blender doesnt sit in those suposed average values, at all.
I assume it is what Abwx alluded to on this graph here:
https://forums.anandtech.com/thread...akes-discussion-threads.2606448/post-41282823
Basically the test lets the CPU sit idle, then runs the benchmark, then lets it go idle again. That way they measure the idle power, peak power, and probably average the whole thing together. It would simulate how a user typically runs a computer (some idle, some high power) but it is not how we typically think of power consumption during a task and ignoring idle power.
From the computerbase benchmark site (translated)
"The Blender benchmark is suitable for various considerations regarding the CPU's power consumption thanks to its staggered testing method and three subtests. First, the PC does nothing for a few seconds, then it goes into full load, sometimes it is only partially loaded, and then it disappears into sleep mode again at the end. In this way, in addition to the lowest energy consumption, the maximum and an average can be derived in the test."
Maybe a 12 p core arrow lake is coming?
Intel has Core Ultra 285K and then 265K
The 285K is 8 + 16 and 265k is 8 + 12.
Where is the 275K. It's missing. Maybe intel sandbagging and the 275k is a 12 p core only gaming chip.
Probably not but one can hope.
Though it is interesting they are skipping 275k all the way down to 265k for 8 + 16 to 8 + 12.
Makes you wonder given the i9 to i7 was 8 + 16 to 8 + 12???
Wouldn't they change the digit 2 to 3?
It’s either that, or a mid cycle revision (pre-refresh) and the first digits start with 2 (akin to the X3D release). Seems a bit ambiguous how they would do it here. My guess is ARL-R will start with a 3, based on how they dealt with RPL-R.
They could do that. They are just identifiers after all. But it would bump into Panther Lake numbers, making them confusing. And they'd run out of 3 digit numbers quite quickly.
They are moving from generations to series in their numbering. It makes sense to keep all Arrow Lake chips, including refreshes, in the same series.
Arrow Lake and Lunar Lake are the 2 series.
N3B means business afaik.
This isn't black and white you know? Intel processes and designs are absolutely optimized for high frequency. Thus it's easier for them to reach high frequencies than others. The sacrifice is density and the ability to perform well on lower clocks.
If you look at say Alderlake mobile and desktop, the desktop chip uses less voltage to reach the same frequency as the mobile part. The mobile part can't clock as high without consuming more. So why do it this way? Because battery life is determined significantly by idle power, and it is affected by leakage. The mobile parts reduce leakage significantly.
Intel themselves admit that compared to the predecessor, it has 18% perf/w gain at the lower clocks but gets to only little over 10% at the peak. It's because TSMC process has a steeper curve that benefits low power chips. They optimized it for low power on the 22nm process but after the backlash on Ivy Bridge, they must have changed it for 14nm and future process generations again.
TSMC isn't getting low power efficiency for free, and Intel isn't getting high frequency advantage for free either. They are tradeoffs each decided to make.
For the other opoints about fixing the power so far there s no official info about the power that is dedicated for ARL, so how can you say that it s already fixed..?
As for allegedly changing the goalpost fdrom PL1 to PL2 same answer, there s no official TDP, so i can make any speculation and it cant be negated by any official number, what is sure is that at 250W they ll be good against a 253W limited 14900K but not against the competiton.
The slide at IGL say 7-10% and 9-13% for WebXPRT an Sepeedometer in respect of the 13900K wich is clocked 0.97x the 14900K, so those numbers in respect of the latter are 4-7% and 6-10% respectively, this also apply to GB btw.
I looked up, your post still says that Intel is currently changing power levels. So, no your post it isn't fixed. I would not associate the word "fixed" with my recent posts to you.
Again you are confusing power levels. You specifically stated PL2 is going to 297 W. As "proof" you posted an estimate that PL4 is 297 W in an extreme profile of two chips. Then as more "proof" you posted a 275 W peak example (and remember peak is PL4, peak is not PL2). And now all of a sudden, out of the blue, you mention PL1. Do you know what the 4 power levels are and how they are used? For a hint, I posted the link to you.
There definitely is a set known official TDP shared between Intel, corporate customers, and suppliers. The public just haven't seen it yet from Intel. It is not currently being "devised" as you claim. You can feel free to speculate what it is, but the actual value is set in stone not currently being devised.
Umm...A win using 24 real threads vs. 16 real and 16 virtual threads is worth celebrating? What happens if AMD brings a 24 real core part to the party, with SMT?
They will price themselves out of the game. There is a reason Intel is 8+16 currently and AMD is 16, die size.
Doesn't matter One has SMT and one doesn't. What matters is the end result.
If you want really be fussy then it's 8P+16E vs 16P cores so I would say it evens out. Now if it was 24P cores on the Ultra 9 then that's not a fair comparison.
Doubt it.. A 24c part would wipe the floor with top arrow lake so bad it could command a decent price premium as a halo part. Not sure what chiplet sizes we'd be roughly looking at on 3nm, nothing drastic though I don't think.
You'll notice I wrote "currently."
That would be another chiplet. Not insignificant.
If you know something about Intel s communications with OEMs please let us know, for the time the general public is aware of nothing and can rely only on past Intel s behaviours.
