Tigerick
919
834
Dies2221
Threads8688
Max Clock3.8 GHz?5 GHz
L3 Cache6 MB?12 MB
TDP7 WFanless ?17 WFanless
Size16 GB?32 GB24 GB ?
EU / Xe32 EU2 Xe8 Xe12
Max Clock1.25 GHz2 GHz
NPUNA18 TOPS48 TOPS100 TOPS ?
witeken
3,899
193
People like @uzzi38 who subscribe to the "Meteor Lake GPU was always 5nm" forget that besides the N3 slide at Investor Meeting, there have been rumors, from multiple sources, that Intel would be first in line for N3 (H2'22 production) as far back as 2020.
Those rumors were confirmed again in 2021. And again in 2022.
Reactions: Joe NYC
uzzi38
2,746
6,655
Such rumours are entirely meaningless. Where were they actually confirmed in thsoe articles btw? One of those is a dead link, the other is claiming that Intel would use N3 for it's i3 lineup in 2022, and N5 in 2021 (like that turned out well, right?).
Come on.
Reactions: Lodix and ftt
lightisgood
250
121
86
Frankly speaking, TSMC N3 is rotten process.
Intel must have revised first plan of MTL and reduced MTL's competitiveness.
However, IMO, rotten N3 could give Intel 4/3 process famiry much larger benefit.
This is recent article of N3.
jpiniero
17,006
7,406
There doesn't seem to be anything wrong with it now. It's just very overpriced. That was the strange part about using N3 - a $40 IGP chiplet makes zero sense.
The one thing I do wonder about is that if they are really using 22FFL for the base tile, where they would get the capacity. I imagine they probably still have the tools but they would need a lot of space.
Reactions: Joe NYC
DrMrLordX
23,114
13,215
All of the things shared by Intel thus far have been either with either a 2+8 or a 6+8 die afaik.
Indeed. If they have anything else planned, it somehow has flown under all the radars of various leakers.
eek2121
3,458
5,105
It. was. never. planned.
There are existing slides from Intel themselves long before the N3 rumor exploded. Intel communicated to the press that they would be using N6/N5 long before the rumor exploded.
You were misled by folks trying to drive up subscriber counts and views to videos and websites.
Do we know how much of an IPC uplift Intel plans to bring for both cores? Maybe they don’t need more cores. Otherwise I could see them simply adding a second CPU die to make 12+16.
Reactions: scineram
DrMrLordX
23,114
13,215
The Redwood Cove is apparently not a radical change from Golden/Raptor Cove. Supposedly. We'll see more next year perhaps. As for the new -mont? Uh, Crestmont? Complete unknown.
I've mused on that as well. Until we see desktop packages we won't know if Intel will try something like that. The 6+8 tile is pretty small . . .
Kaluan
515
1,092
IMHO if the slide would have also said "External N5" than maybe a lot of this rumour mess would've never existed.
Reactions: moinmoin
dullard
26,185
4,841
Psst: Reread your links as Arrow Lake. Those links do not mention Meteor Lake (although, the 2021 link doesn't work, so I didn't read it).
In order to have Arrow Lake in late 2023/early 2024, Intel needs N3 up and running in 2022 for engineering and qualification samples. Then, once they pass, to keep N3 running to have enough good tiles for Arrow Lake mass production ramp up.
19,203
Are they talking about Meteor Lake here? Or is the architecture the same for MTL (mobile) and Arrow Lake (desktop)?
IntelUser2000
8,686
3,787
I don't think it should be taken as anything specific. They are just saying it allows them to be that flexible.
@Exist50 The number of Xe cores being 4-16 shown above equals 64-192 EUs. If we believe some leaks are intentional we can also speculate it's meant to obfuscate.
The slides confirm Foveros Omni starts at 25um. It even suggests Lunar Lake might be Foveros, not Omni
Joe NYC
3,951
5,482
It does seem like an overkill for iGPU.
Another thing it tells me that the days of nVidia selling notebook dGPUs are likely numbered.
mikk
4,314
2,397
Core counts scalability tops out at 6+8, I think this will be the max core count on desktop. It makes sense considering the rumor says MTL is only for lowend-midrange on desktop. GPU scalability goes from 64EUs up to 192 EUs.
Saylick
4,099
9,578
Nvidia won't be completely ousted from the notebook dGPU market. For CAD workstations, they'll maintain their lock due to excellent drivers + Optix. They might lose the lower end of the notebook gaming market, but it will be much harder to lose the higher end.
Reactions: Joe NYC and ftt
witeken
3,899
193
Intel, America's biggest chipmaker, is working with TSMC on at least two 3-nm projects to design central processing units for notebooks and data center servers in an attempt to regain market share it has lost to Advanced Micro Devices and Nvidia over the past few years. Mass production of these chips is expected to begin by the end of 2022 at the earliest.
"Currently the chip volume planned for Intel is more than that for Apple's iPad using the 3-nanometer process," one of the sources said.
You've been warned before yet i'll inform you once again. You must include your own personal commentary when dropping links or other members quotes.
Daveybrat
AT Moderator
