Page 282 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
942
858
Wildcat Lake (WCL) Specs
Dies2223
Threads12688
Max Clock5.4 GHz?5 GHz4.8 GHz
L3 Cache12 MB12 MB12 MB
Size96 GB32 GB128 GB
Bandwidth136 GB/s
RTNoNoYESYES
EU / Xe96 EU2 Xe8 Xe4 Xe
Max Clock1.3 GHz?2 GHz2.5 GHz
DavidC1
2,187
3,340
It's fake. Huge Intel fanboy that doesn't know anything and he's usually all the time around tech twitter trying to get leaks.
Anyway, you can spot on that it's fake due to him claiming CPU tile and SoC tile are separated tiles fabricated on different nodes. While, from what we know, CPU and SoC tile are merged on PTL. The CPU core configuration is also straight out of MLID videos.
@Tigerick You should have also spotted that he claims Pantherlake has the third LPE core, when they are abandoning it with Lunarlake, a predecessor product. So they have LPE with Meteorlake, abandon it with Lunarlake, and comes back with Pantherlake?
You were also posting leaks, which makes this even more questionable. Are your "leaks" even genuine then?
mikk
4,333
2,414
I wouldn't say that. Lunar Lake gets 4 LPE cores in a sense they are moved out from the ringbus, means they can shut it down when only the LPE cores are active. They could repeat it for Panther Lake and also add 8 E cores into the ringbus because PTL comes for UPH segment. Of course we won't see another MTL repeat with LPE cores on a different tile and worse node.
Tigerick
942
858
Interesting leaks from unknown user
Hoho, you guys are too fast. I have verified with my source, most of the info are correct: That's mean some of old info are no longer valid:-
  • PTL-H comes with 3 tiles, not 2 as previously leaked: CPU, GPU and PCD tiles.
  • CPU Tile: This round CPU tile is a main tile with 2 D2D connectors: CPU tile is connecting with PCD and GPU tiles. CPU tile consists of 4P+8E+4LPe core with NPU, MC, media/display engine and IPU. 4 LPe can function as MTL; they are being used to shut down main CPU. NPU should have ~48TOPS.
  • GPU Tile: Xe3 iGPU has 120 TOPS with 12Xe cores. 40-50% faster is believable cause Xe3 comes with extra 50% core.
  • PCD is the name Intel used to replace SoC tile. Consists of PCIE, USB, TB, sound, display, imaging, wifi/bt, security complex, sensor hub and some other minor stuff. And indeed, is made by N6.
  • "Up to 40% lower power and 3 hours more battery life." Sadly, Intel don't specify which one. But I believe it is compared to ARL-H, not LNL due to 3 tiles design...
Ghostsonplanets
774
1,228
Beautiful thing.
Speaking of LPE, I just learned that the 4C SKT cores in LNL are supposed to be more like cacheless low power usage cores than proper E cores. And the bulk of compute falls into the 4P cores complex.
It certainly will be a disadvantage in certain workloads. On the plus side, efficiency should be great given that the E cores will act more like Apple efficiency cores.
Reactions: Tlh97 and Elfear
Tigerick
942
858
Where have you heard about PCD??? I just heard from my source as explained above
Ghostsonplanets
774
1,228
This changes a lot of things, huh. At least doesn't sound something as broken down and expensive as MTL
Also, what's IPU? I suppose it's Image Processing Unit but then you claim imaging is on the PCD.
DavidC1
2,187
3,340
The Lunar Lake MX leak told us all that info. Two tiles. There are some folks in the crowd that exist they cannot believe it until they have seen it with their eyes, like they are run by AI or something.
That in itself is no guarantee. Execution of the team in fulfilling their vision is the rest. Lakefield in theory should have been great battery life but it sucked.
Tigerick
942
858
Isn't this a downgrade over 6+8 ARL-H with only 4+8, how does that make sense?
Intel is claiming 20% performance uplift. 4+8+4 we have 16 cores on the same die (18A) compared to 14 main CPU cores
DavidC1
2,187
3,340
@Tigerick Sure, sure. If the leakers were real then they wouldn't make such a radical change as going from 2 to 3 tiles. You should ask them that question, or even yourself, saying with authority that they are genuine.
@mikk I'm talking about the mostly-useless LPE core config in Meteorlake where in local video playback, the most optimistic scenario(which maybe 1% of the population uses nowadays) saves a mere 0.15W. My Kabylake-Y Yoga uses about 4W in Youtube video playback. Saving 0.15W is in the margin of error, or some would put it(despite the tiny area usage) "waste of silicon".
Also even if Tigerick's "new leak" is true, 3 hours over crap is still crap, since even Meteorlake is arguably behind AMD's in battery life, nevermind ARM, which probably needs 40% on top of that at the system level!
Reactions: spursindonesia
Tigerick
942
858
Don't worry, my source is the one mentioned about 12 XE3 before. Time will tell if above info are correct...
@mikk I'm talking about the mostly-useless LPE core config in Meteorlake where in video playback, the most optimistic scenario saves a mere 0.15W. My Kabylake-Y Yoga uses about 4W in video playback. Saving 0.15W is in the margin of error, or some would put it(despite the tiny area usage) "waste of silicon".
DavidC1
2,187
3,340
They need to move away from local video playback battery life tests. I mean abandon it.
Almost no one does that nowadays. Intel chips had Youtube acceleration since Kabylake.
My Yoga 11 uses 4W in Youtube playback. If it had a giant 75WHr battery such as "ultraportables" nowadays, I'd be able to watch for 12 hours before I plug in to charge at the optimal ~40% mark. The CPU package power is 1-1.2W with it.
IPS display means zero worry of burn-in, despite being a used device. OLED is fancy trash.
Ghostsonplanets
774
1,228
Pretty much. And if we're being charitable, the fact LNL used 2 tiles + dummy die was known for 3 years at least given that Exist had shared this info.
True, true. Lakefield one can chalk up to 10nm issues. But if Intel isn't able to execute a low power core on N3B, then their execution is terrible. Let's wait and see.
To this day I still don't understand how Intel has regressed from the nice battery life and low power improvements they had with Haswell -> Broadwell -> Skylake -> Ice Lake -> Tiger Lake (And I'm being charitable with the later two). The fact Core M/Y series were dropped around ICL is pretty telling.
Hulk
4,128
Anandtech did a MTL review:
This review is quite good. I would love to have known frequencies during some of the benches to figure out IPC but I know that is hard with laptops.
As I was reading through I was getting more and more depressed about MTL thinking, "not gonna buy one of these." Then I saw the battery life and my mind immediately switched to "gonna buy one of these!"
tamz_msc
3,865
3,730
I hope that Gavin can post an updated result with newer drivers as there is a vast difference in performance between 5176 and what is available currently. That said, the Company of Heroes result is quite interesting, as even with DX9 translation using DX12, Arc is pretty competitive with Radeon.
Ghostsonplanets
774
1,228
You need to take these tests with a grain of salt, though. The VideoPlayback one is basically local playback and can be chalked up to the Compute Tile being deactivated while only the Media Engine, Display Unit and LPE cores being active.
The Office test is way more impressive. But I'm not sure if these numbers translate to real world conditions (But the test is legit and would be a common office day workload).
I do prefer Geekerwan test bench. Where he uses a Python script to do a timed loop through a bunch of applications, from Office work, Web Browsing, etc until the battery is depleted. MTL did really well in his test and was able to get more battery life than a AMD 7840 equivalent.
Either way, MTL is a impressive step up for Intel in battery life department.
Reactions: Tlh97 and SpudLobby
Hitman928
6,755
12,502
UL Procyon Battery Test, Video Playback - 50% Brightness
UL Procyon Battery Test, Office - 50% Brightness
These results are stunning! Almost 2X efficient than competition. But still, why is there so much discrepancy when compared to previous test results. What has changed?
And they should've also included 13500H or 13700H in the mix. Would have provided better clarity.
Question is, is it roughly 2X efficient when compared to previous gen? If yes, then it means MTL is terrific. If not, then it's better to wait for next gen.
They are not really comparable models. Anandtech is terrible about this in laptop reviews to the point that they use desktop CPUs in their benchmark comparisons (probably because they do so few so their comparison options are limited). The AMD unit has an RTX 4070 in it and is meant as a gaming laptop. The Zenbook with MTL is meant as an ultraportable and geared for battery life. That's why the MTL gets crushed in the performance benchmarks but wins convincingly in the battery life ones.
MTL should not lose this bad in performance, but the configurations of the laptops are basically at opposite ends of the spectrum. Using a more comparable model with an AMD chip would see the performance be much closer, but battery life would be roughly equal as well.
Ghostsonplanets
774
1,228
Well, the jury is still out on that one. But it appears the newer models are working well as advertised. Something has changed apparently. Wish someone can shed more light on that.
I think we had enough testing to conclude that MTL is on par or better in battery life with AMD Phoenix. And, in some scenarios, MTL can shine due to shutting off the Compute Tile. MTL problem is that it's truly a marvelous mess of engineering and costs.
Had Intel released MTL in early 23 like it was planned, it would have been a decently competitive part with AMD.
Hitman928
6,755
12,502
Thats the problem with these tests. They should have used a similar 13500H or 13700H ultrabook. Would give more clarity. But still, these tests show significantly improved battery life over previous tests. Would be nice if they let us know what has changed since.
Nothing has changed. . .
